Jerry39218 Samba Member
Joined: June 23, 2014 Posts: 182 Location: Brandon, MS
Posted: Fri Jul 25, 2014 8:28 am Post subject: Headlight mounting location?? |
I have noticed a good many headlights are mounted off center on the fender.
That would solve a problem for me as my front amber turn signals are crap.
My question is... what are the measurements on where precisely to install them? Mine are mounted where the surface beetle turn signal needs to go. |
Hecubus Samba Member
Joined: March 28, 2005 Posts: 206 Location: Calgary Alberta
Posted: Fri Jul 25, 2014 8:36 am Post subject: |
From what I have seen many Manx style buggies have an obvious headlight mounting point on the fender right beside the hood. If you do not have that you would likely need to build something similar to have the headlight mounted firmly above the hood/fenders.
Here is the mounting point on my Rascal body.
Posted: Fri Jul 25, 2014 3:20 pm Post subject: |
Posted: Fri Jul 25, 2014 3:22 pm Post subject: |
Bottom strip is steady burn with headlights on.
top unit is turn signal... but you cant see it straight on or in sunlight.
I think a monkey with a duncehat installed these |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sun Jul 27, 2014 6:10 am Post subject: |
An option.. use headlights with a portion built in for turn signals...
Not the best idea for turn visibility with the headlights light on... but they combine two units into one neat package.
http://www.speedwaymotors.com/ ... search headlights..
If you want to move the lights.. and dont have the molded in "pod mounts"
Buy cut down (chopped) 33-34 Ford Headlight stands and bolt them on..
They come in chrome or basic black...
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
desertwrx Samba Member
Joined: January 18, 2007 Posts: 351 Location: Borrego Springs, CA
Posted: Thu Aug 07, 2014 4:53 pm Post subject: |
_________________ 2 fiberglass buggies, 2 non-running Corvair Sandrails!
SCCA |
Posted: Fri Aug 08, 2014 7:12 am Post subject: |
Those Ford mounts don't look to be the correct angle? |
Posted: Fri Aug 08, 2014 7:26 am Post subject: |
Jerry39218 wrote: |
You simply attach the Ford headlight mounts to the body at the best angle that suits the pod lights you plan to use to create as close to a horizontal lamp base as possible.
Keep in mind. Most pod lights have a base that pivots as well which allows them to mounted at many angles.
Drill and add a second smaller upper bolt hole to the base help secure.
These have a little more flange meat.. (my preference).
Called "Shorty Ford Headlight Stands"
Posted: Fri Aug 08, 2014 10:46 am Post subject: |
Cool deal. Works for me
Added to my wish list |
