vtech Samba Member
Joined: August 15, 2006 Posts: 262 Location: CANADA,ONTARIO
Posted: Fri Jul 25, 2014 10:49 am Post subject: billet window crank handle |
hello want to get a pair of those billet crank handle from airkweld. i want to know how do they go on if anyone have ever used them. its on my 63 bug. the handle right now have pins and the billtets one have a bolt that seem to go through the centre of it to hold the handle in place. will my doors accept this style of handles? |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Fri Jul 25, 2014 12:47 pm Post subject: |
You will likely have to drill and tap the shaft for the screw. _________________ 1958 Karmann Ghia owner |
TMI Products Samba Member
Joined: February 14, 2014 Posts: 744 Location: Corona, Ca
Posted: Fri Jul 25, 2014 2:03 pm Post subject: |
usually the screw is more of a set screw to hold the handle on the shaft. I have use Lokar handles and that's how they worked. _________________ Mario De Leon
1965 Turbo Mustang Fastback
1966 Type 3 Fastback
VW Division Sales Manager
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Bobnotch Samba Member
Posted: Sat Jul 26, 2014 2:25 pm Post subject: |
TMI Products wrote: |
usually the screw is more of a set screw to hold the handle on the shaft. I have use Lokar handles and that's how they worked. |
Early type 3s have this problem too. What I did was drill out the stamped area of the pin from the back side (removing it), and just added a little loctite to the screw to assemble it. I got the billet knobs from Mid America though, and the screws from my local hardware store. Much cheaper that way.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
