BTalbs Samba Member
Posted: Fri Jul 25, 2014 2:19 pm Post subject: 914 Fuel Injection |
I have a 2000cc engine from a Porsche 914, it is basically ready to go other than the fuel delivery system. I have the start of the fuel injection system; wiring harness, injectors (although they are old and look like they could be replaced) and the piping that leads from the throttle body to the heads, but finding the rest of the parts I need (affordably) has proved to be difficult.
My questions is, would it be worth it to track down the remaining fuel injection parts needed, or should I just switch over a carburetor?
Thanks for your help, any insights or opinions will be appreciated. |
Bleyseng Samba Member
Posted: Fri Jul 25, 2014 11:55 pm Post subject: |
Depends on what you like. The FI in a 914 is pretty nice and it runs strong with it, great MPG.
Dual carbs like 40 Webers are nice but a cam change should be done.
A single carb is a dog with crappy MPG and running do to the long steel runners.
What do you need? _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21512 Location: Oklahoma City
Posted: Sat Jul 26, 2014 6:53 am Post subject: |
I guess it should be said....it really depends on your commitment to the vehicle and how much you are really willing to work on it.....as compared to.....are you just in a hurry to snap it together and drive it.
The parts.....should not be that hard to find. The issue is that you need all of them. The vacuum system must be clean, all hoses connected ...no leaks allowed. Everything has to work well.
Distributor must be in good shape, wiring harness cant be ratty and frayed all seals and lines should be renewed.
The D-jet efi ran very well. With more careful tuning than what the factory did....and a better ignition coil than stock and a points replacement module.....really helps.
D-jet is simple....23 wires and 4 sensors. But its not just a drop in and run. It takes a little work to get it tuned. But its performance when properly tuned is better than carbs.
Really D-jet can use a better cam than stock....but if its a euro 2 liter its cam is better than the 1.7/1.8 and can do for now. If its a us spec. 2.0...it has the same cam as 1.7.....and will perform better with a better cam (web 120?).
Ray |
BTalbs Samba Member
Posted: Sat Jul 26, 2014 8:19 am Post subject: |
It doesn't matter too much to me how long it takes to get this done. I'll work on it for as long as I need to get it done right. I'm leaning towards sticking with FI, but it is a little intimidating to me because I've only ever worked with carbs. I'm sure I'll be asking more questions on here once I dive into it more and have all the parts I need. |
VWTortuga336 Samba Member
Posted: Sat Dec 06, 2014 9:39 am Post subject: |
BTalbs wrote: |
It doesn't matter too much to me how long it takes to get this done. I'll work on it for as long as I need to get it done right. I'm leaning towards sticking with FI, but it is a little intimidating to me because I've only ever worked with carbs... |
I'm in the same boat you are. My 914 came with dual 40 IDFs that are toast, plus the cam wasn't ever changed over. I'd like to go back to FI, but not really sure on all the details. Let me know how you progress on your build. Good luck! _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
