kentat2 Samba Member
Posted: Sat Jul 26, 2014 9:21 am Post subject: '65 1200cc Squealing Noise Help? |
Hey everyone...Ken from Tucson here. It's my first post, and my first VW.
After driving the car for two days (approximately 62 miles, total) the engine began making a noise that sounds EXACTLY like a squealing fan belt. After many headaches adjusting, I removed the belt and ran the engine for a couple seconds...
The squealing noise is still there. No joke, even mimics the belt sound on shutdown.
Any insights? |
joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
jzjames Samba Member
Joined: September 27, 2007 Posts: 1921 Location: Windy Point, WA
Posted: Sun Jul 27, 2014 10:30 am Post subject: |
Hate to say it; a bearing, possibly. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Sun Jul 27, 2014 2:32 pm Post subject: |
Stick a rubber hose in one ear, and move the other end around the engine bay. The source will then be obvious. |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Sun Jul 27, 2014 7:10 pm Post subject: |
KTPhil wrote: |
Agreed, a mechic's stethoscope or similar tool should be used to narrow down exactly where the noise is coming from... could be the distributor is at fault here or maybe something has fallen in between the case an pulley and is rubbing. _________________ 1960 Ragtop w/Semaphores "Inga" |
jimwar Samba Member
Posted: Mon Jul 28, 2014 10:31 am Post subject: Squealing noise |
I had a loud squaling noise in my 54 beetle that ended up coming from the speedo cable. |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Mon Jul 28, 2014 12:44 pm Post subject: |
All the squealing in my VWs comes from the passengers!
Any update from the original poster?
Check to make sure nothing fell down into the lower pulley well. Tools and other things have a way of disappearing in there sometimes and they can make funny noises or sparks. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Sun Aug 03, 2014 12:34 am Post subject: |
Well...there's nothing rubbing on the tin, no extreme play at the crank pulley (lateral or axial), and my redneck stethoscope says it's coming from the distributor region. Will be getting new cap/rotor/plugs/wires on Thursday. Read somewhere a gnarly cap can get really noisy. On the upside, will also be doing some suspension work soon, and getting the guts out to refresh all the gaskets and seals.
Ken |
mukluk Samba Member
Posted: Sun Aug 03, 2014 3:16 am Post subject: |
Noise from the distributor, quite likely it is worn out then. Pull the distributor out and check for excessive play between the shaft and housing. _________________ 1960 Ragtop w/Semaphores "Inga" |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sun Aug 03, 2014 12:17 pm Post subject: |
Not necessarily worn out but the distributor does require some maintenance attention that is VERY often overlooked. The squeeling is it's way of telling you that it needs lubrication. Vacuum advance distributors need a little dab of Bosch grease or similar on the points cam. In addition mechanical advance distributors need a bit of oil down where the weights move and the little wick under the rotor needs some oil too. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Sun Aug 03, 2014 7:28 pm Post subject: |
Will be servicing/inspecting the distributor post-haste. Triple checked, and the noise is definitely coming from there. Will post an update NLT Thursday. Thanks for all the great help, everyone! |
