Introducing The Ghost Ship
Page: Previous  1, 2, 3, 4, 5, 6 ... 11, 12, 13  Next
ServantOfElwood
ServantOfElwood is offline
PostPosted: Sun Aug 17, 2014 10:18 pm    Post subject: Plunder Reply with quote
Aargh, look at the fine precious metals I be pillaging!!
OK, they're just the propane feed lines - but they're out! Aargh!
When I disconnected the propane lines from the fuel tank, I heard a little hiss! So there was something in there still holding. Encouraging! I had to take the propane tank out. The manual said to remove the front bolts but just loosen the back bolts and slide it out. But that wasn't happening, so I just took them all out, with a paint can jammed under the tank so it wouldn't come crashing down. Done.
Then, remember this?
I pressure washed the gunk and undercoat from the plate holding the propane lines in place. And after Liquid Wrench and beating on the screws with a screwdriver and hammer, those 6 screws came out with scarcely a whimper. Then pried the plate loose.
Then went back up to the kitchen cabinet and disconnected the gas lines there, and removed the clamps.
Then back down under the van, and by kind of rowing the gas lines, I maneuvered them out from down below, without having to bend them. Booty!
OK, and then remember the kitchen shelf? And the fasteners I couldn't figure out?
Just noticed there's a mouse turd in the photo. Oh well. Welcome to my world. Smile Anyway, those are indeed shorty nails, so I used the same trim removal tool I used to pull the clips out of the sliding door panel, and pried out the nail, preserving the brown plastic grommet.
And then step by step unhooked things (took pics and labeled too). A few things needed the Liquid Wrench/hammer beating treatment. That final floor bolt was reaallly tough. But it finally gave up! And the kitchen is out!
And the carport is full of cabinetry!
All hail the Bentley manual!
The Ghost Ship - 1984 Westfalia 2WD
https://www.thesamba.com/vw/forum/viewtopic.php?t=602180
Install in reverse order of removal.
msinabottle
msinabottle is offline
PostPosted: Mon Aug 18, 2014 10:19 pm    Post subject: Sheer Determination Reply with quote
That's more than I've ever dared try on Winston's interior. You're in the groove now. With sheer determination, boulders can become sand.
Best!
'Winston,' '84 1.9 WBX Westy
many ways, but never, never, never in silence."
Crankey
Crankey is offline
PostPosted: Tue Aug 19, 2014 7:06 am    Post subject: Reply with quote
LOL !! perfect u tube link ! Thanks. Your very good at making camper rehab entertaining. Laughing
ServantOfElwood
PostPosted: Wed Aug 20, 2014 10:30 pm    Post subject: Reply with quote
Thank you for the encouragement!
mariusstrom
mariusstrom is offline
PostPosted: Thu Aug 21, 2014 9:46 pm    Post subject: Reply with quote
Looking good. The one spot I found a mouse carcass when I restored Otto the Vanagon back to good-as-new was above the headliner over the driver's seat. Make sure to pull that down as well, and wear a shower cap when you do...
Marius Strom Otto: 1988 Vanagon Syncro Westy Camper
[SOLD] Felix: 1967 Deluxe Beetle
ServantOfElwood
PostPosted: Fri Aug 22, 2014 4:28 pm    Post subject: The Great Insulation Debate; or, how I spend my Friday night Reply with quote
Jeez, why can't there just be ONE solution? Laughing Decisions decisions
ServantOfElwood
PostPosted: Sun Aug 24, 2014 8:41 pm    Post subject: Finally I get to scrub! Reply with quote
But first, panel removal. They're pretty easy, aren't they? Just a few little screws holding them in place. Some needed the Liquid Wrench/hammer treatment. And behold! (in these photos I haven't removed insulation yet; the mice have done that):
Port side:
Starboard:
I thought I'd loosen the headliner and just take a peek to see if... well, shoot. OK, down comes the headliner (thanks for the warning of wearing headgear):
OK, now to get to business. Sprayer of soapy water, check. Dust mask, eye protection and rubber gloves, check. Shop vac and trash bags, check. And behold:
no pic of headliner insulation removal. But trust me, it's not there anymore.
I haven't seen ANY sign that the mice have chewed any wires. Thanks, I could use a miracle! That deserves a celebratory popsicle!
I also took the air compressor and blew out cracks and crevices. Spritzed some bleach water into the air channels - along the top, where the wiring runs to the back, and there's a couple of vents... and blasted that too. Does that sound right? Not sure what else I can do.
Then I got a steaming hot bucket of Citrasolv and water and a rag and started cleaning. And another bucket, and another, and another. Started at the back, and I've made it to where the back seat would be. It's so awesome.
Starboard side inside wall on top of rear fender. You can do surgery in it now! if you were a very small surgeon:
Not so much the port side Sad There was a mouse nest really jammed in here. That probably did not help much.
you can see the rust on the outside as well:
So will probably get a dremel and a wire brush and knock that off, then paint some sort of rust-bonding paint on it.
But for now, it's scrubbing with Citrasolv time! Love that stuff, it smells like Valencia oranges. I can close my eyes and pretend I'm in a mouse-riddled, Liquid-Wrench-drenched orange grove Laughing
Was just trying to find a youtube clip of Bing Crosby saying "Sweet Valencia Oranges". I could swear he used to say that in his commercials.
The thing I will be pondering, as I scrub away in my orange grove, is the replacement insulation. I have read many wonderful threads here, with lots of different ideas. But I think what I'll do is just put fiberglass back. I know, I know, that's not too original. I might get some of that sound deadening stick-on stuff from GoWesty, and then put fiberglass in, and get on with things. Whatever it is can't take too much time or prep because I've got to get all those cabinets in the carport cleaned and back into the van. Will be raining before we know it!
Bing doesn't say "Sweet Valencia Oranges", but look, he's camping with a van!!
16CVs Premium Member
16CVs is offline
PostPosted: Sun Aug 24, 2014 9:09 pm    Post subject: Reply with quote
Great photo journal. The O2 sensor light is only actuated by mileage,it has nothing to do with engine operation.
looks like a great family Heirloom which should bring some great family memories for only a few hours of labor.
Stacy
Samba member # 14980
Crankey
Crankey is offline
PostPosted: Sun Aug 24, 2014 9:18 pm    Post subject: Reply with quote
you can get some sound deadener locally. I got a door kit of Dynamat at Speakerlab on Roosavelt. you going to use new fiberglass right ? not that old stuff soaked with mouse pee ? Laughing
you should find the mouse chewed wires when your trying to get everything running again. Rolling Eyes
maybe you could call your rig Algernon
http://en.wikipedia.org/wiki/Flowers_for_Algernon
excellent progress, keep it up Smile
ServantOfElwood
PostPosted: Sun Aug 24, 2014 9:20 pm    Post subject: Reply with quote
Laughing
ServantOfElwood
PostPosted: Sun Aug 24, 2014 9:26 pm    Post subject: Reply with quote
So, it was supposed to come on? Nothing is wrong? That would be a relief. I figured to tackle it when starting work on the fuel system.
aswah
aswah is offline
PostPosted: Sun Aug 24, 2014 11:05 pm    Post subject: Reply with quote
http://www.businessweek.com/articles/2014-08-21/ju...navy#r=rss
dude, love your bus... pretty cool
WIT WA DA DA (Peace and Unity)
Aswah, Lisa, Beaumont and Loose Lucy Too!
1989 Westy
2013 Jetta Sportswagon TDI
tarandusVDub
tarandusVDub is offline
PostPosted: Mon Aug 25, 2014 10:03 am    Post subject: Reply with quote
"Super Cavitation Technology" . My van has that. Right in the fuel pump.
1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD.
ServantOfElwood
PostPosted: Mon Aug 25, 2014 11:54 am    Post subject: Reply with quote
Very cool. Makes a bubble you can drive through. That would help with fuel mileage, I'll bet.
ServantOfElwood
PostPosted: Mon Aug 25, 2014 12:03 pm    Post subject: Reply with quote
Laughing
JudoJeff
JudoJeff is offline
PostPosted: Mon Aug 25, 2014 1:54 pm    Post subject: Reply with quote
I am most impressed! Keep up the good work!
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout)
djkeev
djkeev is offline
PostPosted: Mon Aug 25, 2014 4:22 pm    Post subject: Reply with quote
How to shut off the OXS light.......
http://www.thesamba.com/vw/forum/viewtopic.php?t=588690&highlight=oxs+light
Dave
Ghia
Vanagon
Beetle
oldhuldy67
oldhuldy67 is offline
PostPosted: Mon Aug 25, 2014 5:06 pm    Post subject: Reply with quote
A clean ship is a happy ship..well done, Bristol fashion..and I can't smell the mice in your pics now. 😉
ServantOfElwood
PostPosted: Mon Aug 25, 2014 9:00 pm    Post subject: Reply with quote
Got a long way to go, Captain!
ServantOfElwood
PostPosted: Wed Aug 27, 2014 9:12 pm    Post subject: Reply with quote
Page 5 of 13
