Soundkillr Samba Member
Posted: Sun Jul 27, 2014 1:49 pm Post subject: |
The arm is welded to the pickup, and it goes to the bolt. Once the nut was tightened down for the deep pan, It actually backed the bolt up so it didnt hold that support arm in place.
btw, the washer is now above that arm instead of below it, as seen in that pic.. |
Posted: Sun Jul 27, 2014 2:03 pm Post subject: |
Guys, just so i can sleep easier. The.pickup that came loose inside the block....thats pressed in right? Again i want to make sure i dont have a clamp in the block somewhere. I should be able to tighten that bolt down and that pickup shouldnt go anywhere. |
BWD Samba Mailman
Joined: August 23, 2002 Posts: 2154 Location: In bed.
Posted: Sun Jul 27, 2014 2:04 pm Post subject: |
Did you get the nut back on the stud and tightened? _________________ BWD
JHC
member #2850
1966 Beetle
_____________________________ |
Joined: January 01, 2007 Posts: 16885 Location: sticksville, ct.
Posted: Sun Jul 27, 2014 2:07 pm Post subject: |
yes, the pick up is pressed into the block....like really pressed in...as in, a total bitch to remove from the block.
if it fell back into it's hole, you will still be sucking air. did i mention they are really pressed in _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Jul 27, 2014 2:20 pm Post subject: |
BWD wrote: |
Did you get the nut back on the stud and tightened? |
no yet, it is all lined up and im going to tighten the bolt with the double nut method. Once that is tight, ill shorten the stud just so it wont bottom out on the closed top nut, and ill put it back together. The pump did go in the hole well, and it didnt move around, and i know in theory it would pull air but i just wouldnt think it would be much of an issue. At this point, aside from taking the whole thing apart, all i can do is put it back together. Really think it would be an issue? |
Posted: Sun Jul 27, 2014 2:23 pm Post subject: |
I hate to break this to you, but the engine has to come apart to fix this properly. You may have the tube "close", but it certainly isn't in there sealed tight. If you choose to run it this way it's going to suck air and eventually a bearing is going to go, and take a lot of other stuff with it.
This is something that they missed during the assembly. It happens, and if they are a reputable vendor they'll apologize and fix it. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
mark tucker Samba Member
Posted: Sun Jul 27, 2014 2:47 pm Post subject: |
1st ntake it back to the guys that built it., 2nd it should have 3 oil & filter changes by now.3rd that looks like a 1.5qt sump. |
Posted: Sun Jul 27, 2014 3:40 pm Post subject: |
http://www.thesamba.com/vw/forum/viewtopic.php?t=166259
is the thread that covered the repair, but Mark Harney knew what he was doing. If you go too far you'll crack the case.
I also want to point out if you do much on this you give the vendor an excuse to say you messed it up further and there is no warranty. I'd give him the engine back and have him call you when it's fixed. _________________ It's just advice, do whatever you want with it!
Posted: Sun Jul 27, 2014 3:51 pm Post subject: |
Im not touching this thing any further. Ive got an email to the builder asking him to call me tomorrow. I really hope he makes it right. I have been told if the tube isnt in TIGHT it will suck air and foam the oil. I know i dont want that.... |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Sun Jul 27, 2014 4:00 pm Post subject: |
Wonder how many guys head to the garage to check their pickup tube after reading this |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Mon Jul 28, 2014 3:53 am Post subject: |
It's not that common, but the shop should make it right. They probably won't want to, because it is involved and thus expensive, but you have to take the good with the bad in this business. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
hooker Samba Member
Joined: October 07, 2004 Posts: 261 Location: Bend, Oregon
Posted: Mon Jul 28, 2014 8:13 am Post subject: Re: Please help, another oil pressure thread... |
[quote="Soundkillr"]I recently got a 2276 turn key motor from a vendor here, and while it runs great, I have noticed a new problem. The engine has not been fully broken in, and I'm running Lucas's 15w 40 break in oil with high zinc. I have a mechanical oil pressure gauge, going to an autometer gauge.
Over many years of racing I have found that the mechanical oil pressure gauges are very slow to respond to pressure changes. A larger oil line to the gauge helps a lot but the electrical units are much better for faster response but not as accurate as the mechanical units. I use a big red light (2" dia.) with a 20 lb sending unit on my engines and if they even flicker at rpm I shut the engine off. The quick response of the electrical units have saved the engines a few times. Good luck on getting your problem taken care of. That's an easy thing for an engine builder to miss. _________________ 2007 NHRA Division 6 Finals Champion air cooled Rabbit P/U rear engine compact/import class, 13.32 sec 1/4 Woodburn, Oregon
Pauter Big Block VW 2610 cc turbo mid engine roadster 9.69 sec @ 147 mph 1/4 PIR Oregon
I spent most my money on women and VW race cars. The rest I wasted. |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Mon Jul 28, 2014 6:20 pm Post subject: |
now I'm worried... I'm working on an engine I have, was built already years ago. Anyway, I had the sump off, and I accidentally rested the engine on the tube and it rotated a bit so it wasn't centered. It wasn't flopping around or anything, but I had to push on it and rotate it back into place. Am I in the same boat with sucking air problem? _________________ 1957 Beetle
1966 Bus |
Posted: Mon Jul 28, 2014 7:28 pm Post subject: |
Thanks for the advice guys. Glad you all spoke up, I would have put it back together not knowing better. Glad I didn't. I'm talking with the builder now to see what we can work out.... |
Posted: Wed Jul 30, 2014 6:11 pm Post subject: |
GLHTurbo wrote: |
now I'm worried... I'm working on an engine I have, was built already years ago. Anyway, I had the sump off, and I accidentally rested the engine on the tube and it rotated a bit so it wasn't centered. It wasn't flopping around or anything, but I had to push on it and rotate it back into place. Am I in the same boat with sucking air problem? |
I dunno man, I would certainly check it VERY well. Everyone I have talked to both on and off forum have said this is a very serious issue.... |
AlteWagen Troll
Posted: Wed Jul 30, 2014 7:27 pm Post subject: |
AlteWagen wrote: |
Is the case a single relief? The pickup tube looks REALLY small.
I would not build a "big" engine on a small oil passage single relief case. |
SUPPOSED to be dual relief full flowed. It was actually a fuel injected block. I believe I have worked it out with builder and will keep everyone posted once its all worked out. I pulled the engine the next day and it was on a pallet back to the builder the following day. |
AlteWagen Troll
Posted: Wed Jul 30, 2014 7:58 pm Post subject: |
AlteWagen wrote: |
If it really is a AJ block they did not use the large german pickup that it came with. The one you have looks like a small SR or late brazilian pick up. |
Mmm, interesting. Thank you for the feedback. I'm going to look into that.... |
