chubaca6613 Samba Member
Posted: Sat Jul 26, 2014 8:48 pm Post subject: vw to corvair |
Hey guys iv never messed with corvair anything but iv got a guy wanting to buy my type one engine will they mate up with no problem? |
jsturtlebuggy Samba Member
Posted: Sat Jul 26, 2014 9:33 pm Post subject: |
No, the VW engine will not bolt up to the Corvair transaxle.
Anything is possible to do, making a adapter would be required.
Also the Corvair engine spins in reverse of the VW engine so a reverse camshaft would have to be designed and installed to make the VW engine spin in the correct direction for the Corvair transaxle. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Jul 26, 2014 9:52 pm Post subject: |
jsturtlebuggy wrote: |
Also the Corvair engine spins in reverse of the VW engine so a reverse camshaft would have to be designed and installed to make the VW engine spin in the correct direction for the Corvair transaxle. |
Or you have to reverse ring gear in VW transaxle.... Why would you want Corvair.... They have a lot less power than a lot of newer engines that are easier to adapt.... Adapters are available for Corvair to VW though... And reverse rotation cams are available for Corvair...
Brian Samba Moderator
Posted: Sat Jul 26, 2014 10:23 pm Post subject: |
I think the Hibbard's book said something along the lines of "unless you have unlimited funds and are married to the brands, don't use Porsche or Corvair" _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
BUGGUTZ Samba Member
Joined: March 13, 2007 Posts: 537 Location: Luzerne Mich
Posted: Sun Jul 27, 2014 7:40 am Post subject: |
I believe he wants type 1 engine to corvair trans. |
Posted: Sun Jul 27, 2014 12:58 pm Post subject: |
I have a vw engine I'm trying to sell and a guy that text me bought a rail that had a corvair in it so I just came to get info from you guys |
DuaneL Samba Member
Joined: February 02, 2012 Posts: 511 Location: Spokane WA
Posted: Sun Jul 27, 2014 3:56 pm Post subject: |
chubaca6613 wrote: |
Then more then likely it will work since it probably is a vw transaxle that they had used the conversion plate to mate the Corvair engine to it though there is a chance they swapped the side the ring gear is on to reverse the tranny rather then changing the cam to reverse the corvair engine so that would have to be changed back if that was the case. But then again there is a possibilities they actually used a corvair tranny _________________ ____________
1971 std bug, 1776, ACN Super Stock 34-3, dvda dist, 27x8.50 14 tires |
beaudonahue Samba Member
Joined: March 31, 2012 Posts: 29 Location: littelock ca
Posted: Sun Jul 27, 2014 11:42 pm Post subject: |
My dad has a corvair to vw trans all you need to do to make the vw tranny work is flip the carrier he has the 140 motor with four card set up |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2647 Location: West Coast (Michigan's)
Kurt B Samba Member
Joined: December 16, 2009 Posts: 5 Location: Dana Point, CA
Posted: Wed Apr 29, 2015 8:06 pm Post subject: |
140 HP corvair reverse rotating engine, dual 44 webers
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5408 Location: Holland, MI
Posted: Thu Apr 30, 2015 6:54 am Post subject: |
That is pretty slick! I would like to see more of it, lots of custom parts from my angle. _________________ 66 Baja
73 standard
14 Jetta TDI
95 Escort
89 CUMMINS in whats left of a dodge body
Everyones gotta be somewhere! |
Kurt B Samba Member
Posted: Tue May 05, 2015 5:01 pm Post subject: |
Kurt B Samba Member
Posted: Tue May 05, 2015 5:03 pm Post subject: |
Orange county buggy body, 091 trans , 4 wheel disc brakes with a parking brake, custom fuel tank, 140 HP reverse rotating Chevy Corvair engine with dual 44 webers. Finishing up a few small details and it will be ready for its fist drive. |
