gt1953 Samba Member
Joined: May 08, 2002 Posts: 13846 Location: White Mountains Arizona
k@rlos Samba Member
Joined: October 04, 2012 Posts: 485 Location: Suffolk, England
Posted: Sun Jul 27, 2014 10:29 am Post subject: |
May have to make a simliar thing for my '70 bus. The 2110 can get a bit hot on motorway runs in the summer. |
Brian Samba Moderator
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76897 Location: Sneaking up behind you
gt1953 Samba Member
Posted: Sun Jul 27, 2014 12:04 pm Post subject: |
Glenn glad you responded. I did use the tennis ball for a while, then an empty soda can. Now this I made up for both cars. The Vintage Speed one is nice also. Mine was scrap aluminum and not permanent. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Sun Jul 27, 2014 2:18 pm Post subject: |
k@rlos wrote: |
BAD idea with a bus, lots of cooked engines from people trying that.
more so with type 4s but still an issue with type 1s.
All it does is let all the hot air coming from underneath off the heads and muffler recirculate back into the fan.
if you really need extra air in the engine bay run some hose in through firewall tin and run it down to torsion bar tubes were it scoops in fresh air away from all the heat.
a friend had to to this in his early bug to get enough air to it.
made a big difference in temps _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Sun Jul 27, 2014 4:56 pm Post subject: |
Joel wrote: |
k@rlos wrote: |
All it does is let all the hot air coming from underneath off the heads and muffler recirculate back into the fan. |
X2
As for adding more air into the engine bay, put a manometer in the engine bay and hit the highway. On a bay window bus you will actually create pressure in the engine bay because the bay window bus intakes are actually scooped and will in fact pressurize the engine bay. Adding more intakes may actually bleed off this pressure and reduce cooling.
On a split bus, adding more air as mentioned is a VERY good idea. A stock 1600 DP w/doghouse wants to consume more air than the stock louvers can provide. Provide enough extra intake into the engine bay (that wont recirculate) until your manometer shows zero vacuum going down the highway. _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Mon Jul 28, 2014 3:46 am Post subject: |
Even on a Beetle propping open the rear tends to create vacuum. Propping open the front of the engine lid works because air is still flowing down over the top of the body. At the lower edge eddies are creating vacuum and it works in reverse.
Sorry. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Mon Jul 28, 2014 2:41 pm Post subject: |
Surely the pull of the engine and fan overcome that small vacuum easily though....? _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Mon Jul 28, 2014 4:00 pm Post subject: |
andy198712 wrote: |
Surely the pull of the engine and fan overcome that small vacuum easily though....? |
yeah... just like you breathing through a scarf |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
Posted: Mon Jul 28, 2014 4:22 pm Post subject: |
Quokka42 wrote: |
Sorry. |
So your saying this is a bad idea in a type 1 ?
_________________ F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023 |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Mon Jul 28, 2014 5:14 pm Post subject: Air intake |
I also agree that propping open the bottom of the deck lid is a bad idea, under certain driving conditions, even in a Beetle. If you are stuck in "stop-and-go" traffic, the fan may end up sucking hot air from under the engine. That is why engine compartment seals are so important. Out on the open highway, a bottom propped lid can certainly improve air flow, but you need to be careful in the city. _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
rgdedge Samba Member
Joined: October 17, 2006 Posts: 862 Location: Seymour, TN
Posted: Mon Jul 28, 2014 7:47 pm Post subject: |
I don't see the reason to prop a decklid open on the bottom if it has a convertible/vented one on it. If all the tins and seal are in place, wouldn't the hot air exiting from under the engine be drawn up into the engine compartment? There is a seal there for a reason.
Tim _________________ ()o\|/o() |
Joel Samba Member
Posted: Mon Jul 28, 2014 8:31 pm Post subject: Re: Air intake |
neil68 wrote: |
I also agree that propping open the bottom of the deck lid is a bad idea, under certain driving conditions, even in a Beetle. If you are stuck in "stop-and-go" traffic, the fan may end up sucking hot air from under the engine. |
A guy on volkszone proved this with his bug only a few days ago.
propping the bottom opened helped at speed but when idling the temp was higher with it propped at the bottom than left closed _________________ Quick little bug, you got a Porsche motor in that?
Posted: Mon Jul 28, 2014 8:41 pm Post subject: |
Its kinda like the principal of the "66 air conditioning"
The air conditioning works best at 66 mph, and by air conditioning I mean open windows. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Tue Jul 29, 2014 12:51 am Post subject: |
With regards to a bus...propping the lid or not has no effect on CHT's. This has been proving on several instances. Colin recently confirmed the same as well. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
VWCOOL Samba Member
Posted: Tue Jul 29, 2014 1:25 am Post subject: |
hot air rises, folks |
Posted: Tue Jul 29, 2014 5:35 am Post subject: |
And rain falls from the skies..... Get my drift?? Horses for courses _________________
Alstrup wrote: |
Posted: Tue Jul 29, 2014 6:02 am Post subject: |
udidwht wrote: |
With regards to a bus...propping the lid or not has no effect on CHT'wouldn'tswget very far at all all allouldn't. This has been proving on several instances. Colin recently confirmed the same as well. |
Not the results I observed with my old buses (bay and splits) and their head temps. I wouldn't get very far at all before head temps were getting over 400 just driving around. I only measure head temps at the spark plug. I also measured ambient air temps in the engine bay with all my testing. A good sealed engine bay with enough intake to keep vacuum away would have ambient temp air going into the fan. Propping the bus lid open raised this temp significantly (again, never got very far before head temps were climbing and i pulled over).
On my 79 bay removing the panel inside the bus above the engine wouldn't make it run hotter on the streets, but head temps went higher on the highway.
These were my results anyway. This was ten years ago, so maybe air and physics has changed since then. _________________ Eric Allred
gt1953 Samba Member
Posted: Tue Jul 29, 2014 7:20 am Post subject: |
Lucky for me I do not live where stop and go traffic exists. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
