TMI Products Samba Member
Joined: February 14, 2014 Posts: 744 Location: Corona, Ca
Posted: Sun Jul 27, 2014 9:15 pm Post subject: Question about wheel to fender lip clearance |
I was finally able to get my car running, but the previous owner rewired a lot of stuff and now I have to trace the dash wiring since I have no blinkers no tach. But it runs and I moved it 5 feet
But I noticed my drivers side wheel it touching the fender lip and passenger has about 3/4" of clearance. The drivers side also sits about 3/4"-1" lower. I pulled the drums off to have them drilled and put them on with only about 60 ft lbs. Do you think they aren't seated and that's causing the left wheel to stick out more???
_________________ Mario De Leon
1965 Turbo Mustang Fastback
1966 Type 3 Fastback
VW Division Sales Manager
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Mon Jul 28, 2014 5:58 am Post subject: |
Hey Mario, glad to see/hear the car moving. Check the rear subframe bushings. If they are worn or have been messed with you may be able to shift it over. I read some where on here about lowering your car may also affect the spacing left to right. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Jul 28, 2014 6:32 am Post subject: |
Russ Wolfe said it was quite common for the driver side to sit lower than the passenger side after 45 years. I had to raise the driver side 1 inner spline to get my '67 rear to sit level/even. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Mon Jul 28, 2014 7:46 am Post subject: |
im wondering if I raise the left side if will help my clearance issue or just roll the lip. The pass. side tucks nice and you can see the space at the rear of the wheel. I cant slip a piece of cardboard on the drivers side around the tire. _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Fiatdude Samba Member
Joined: April 20, 2009 Posts: 1218 Location: now in MO.
Posted: Mon Jul 28, 2014 7:58 am Post subject: |
A friend of mine once said -- " If you can slide a piece of paper in there it ain't rubbing" -- -- My tires are huge on my Ghia and they rub occasionally, like when it was on the dyno and it did some self clearancing during the squat at the big end -- You have to just look at it and see if you can live with it -- a little fender rolling is good -- maybe lifting the torsion -- Let your eyes be your guide --
and as far as what it looks like -- -- nobody can see both sides of a car at the same time LOL _________________ Remember, as you travel the highway of life,
For every mile of road, there is 2 miles of ditch |
Posted: Mon Jul 28, 2014 8:19 am Post subject: |
1 inner spline raised mine 3/4-1" as I recall. _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Mon Jul 28, 2014 8:40 am Post subject: |
Fiatdude wrote: |
and as far as what it looks like -- -- nobody can see both sides of a car at the same time LOL |
Ha, like the way you think
I'm used to rubbing, but I wanted a car that doesn't rub (this time) I will try and figure out why one side sits out further after I torque the axle nut down more and then roll the lip.
If that doesn't work good enough, then I will raise it 1 notch. The weight of a couple of kids in the back for cruising should bring it back down a little. _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Posted: Mon Jul 28, 2014 8:42 am Post subject: |
Mike Fisher wrote: |
1 inner spline raised mine 3/4-1" as I recall. |
that should put me very close to level on the rear (I hope).
The front came pretty easy after I figured out 1 side. Is the back hard to do or how long should it take? _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Posted: Mon Jul 28, 2014 9:02 am Post subject: |
I used a tow chain double wrapped around a floor jack & the upper bumpstop to lower/raise. It a took a week or more & I should have bought some kind of threaded spring compression tool. _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Mon Jul 28, 2014 9:09 am Post subject: |
I used a tow chain double wrapped around a floor jack & the upper bumpstop to lower/raise. It a took a week or more & I should have bought some kind of threaded spring compression tool. |
well that doesn't sound fun.
air shocks look real good right about now _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13270 Location: Tejas!
Posted: Mon Jul 28, 2014 9:21 am Post subject: |
Air shocks wont work on the back. Too much weight
A lot of things can cause this. Old accident repair that wasnt perfect, misaligned body panels, body bushings going bad, etc etc etc.
I'll be honest, only my super original 65 squareback sat level left and right. all my other type 3's have been just a little off. It takes time, but you can do combinations of inner and outer splines to get the rear just right. For instance up 2 inner, down 1 outer, etc. Something else that people have brought up before, having the front off a little bit can make the back look off. |
luckystiff Samba Member
Joined: September 28, 2005 Posts: 2252 Location: hickory,nc
Posted: Mon Jul 28, 2014 9:32 am Post subject: |
can't beleive no one has mentioned you don't have the drums torqued nearly enough. 60ftlb is about 1/4 of the way there... unless you like spun drums....
and if it's swingaxle you need to roll it back and forth a few times to get it to settle. and yes i have seen one settle more to one side afterwards. going from memory mine settles a tad more on the right after a few forward rearward rolls...... _________________ ITMC
Secret Service |
Posted: Mon Jul 28, 2014 9:50 am Post subject: |
luckystiff wrote: |
and if it's swingaxle you need to roll it back and forth a few times to get it to settle. and yes i have seen one settle more to one side afterwards. going from memory mine settles a tad more on the right after a few forward rearward rolls...... |
the drums were never torqued because I got the wheels put on, took it to work where it styed for a month for the interior and then rolled on/off the trailer a few times to a show. It has not been driven nor did I plan on driving it till I torqued the axle nut and went over all the work the previous owner did. _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
supersuk Samba Member
Joined: December 20, 2010 Posts: 958 Location: Honolulu, Hawaii
Posted: Mon Jul 28, 2014 11:30 am Post subject: |
What I found when I was putting the body back onto the chassis is that there is some room for adjustment. I was able to move the body about 1/4" to make the spacing even. It might be that a previous owner could've taken the body off for some reason and put it back on a little misaligned.
Also, as someone suggested, the subframe could be a little skewed. Maybe the fenders had some previous accident damage that wasn't fixed properly. Whatever the case may be, I'd just roll the fenders a little and go on your merry way. _________________ 68 Fastback Build: http://www.thesamba.com/vw/forum/viewtopic.php?p=5396323#5396323 |
Posted: Mon Jul 28, 2014 11:53 am Post subject: |
supersuk wrote: |
Also, as someone suggested, the subframe could be a little skewed. Maybe the fenders had some previous accident damage that wasn't fixed properly. Whatever the case may be, I'd just roll the fenders a little and go on your merry way. |
then im getting my bag of lead shot and a body hammer and going to town(after I toque that nut nut)
I plan to (or hope to drive it this week around the black at least) then get it registered and insured. _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
evlwevl Samba Member
Joined: February 13, 2007 Posts: 281 Location: On the streets of Bakersfield, CA
Posted: Mon Jul 28, 2014 1:16 pm Post subject: |
the drivers side fender had been repaired. The PO bought a replacement fender for it but the body shop just pulled out the dent. so it might be that. One inner spline should be good for the leveling but none of my cars were ever level and unless you put a ruler up to the fender, you couldn't tell _________________ Make it three yards, motherf*****, and we'll have us an automobile race
-The Driver(Two Lane Blacktop)
55 Prostreet Bug
59 Daily Driver Bug
63 Baja
00 Turbo New Beetle |
Posted: Mon Jul 28, 2014 1:29 pm Post subject: |
evlwevl wrote: |
the drivers side fender had been repaired. The PO bought a replacement fender for it but the body shop just pulled out the dent. so it might be that. One inner spline should be good for the leveling but none of my cars were ever level and unless you put a ruler up to the fender, you couldn't tell |
you tell me this now?
the whole left side sat lower since day 1, but this clearance issue is the hold up for the first drive. _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Posted: Mon Jul 28, 2014 1:47 pm Post subject: |
nah, you just don't remember. _________________ Make it three yards, motherf*****, and we'll have us an automobile race
55 Prostreet Bug
59 Daily Driver Bug
63 Baja
Posted: Mon Jul 28, 2014 3:28 pm Post subject: |
TMI Products wrote: |
luckystiff wrote: |
the drums were never torqued because I got the wheels put on, took it to work where it styed for a month for the interior and then rolled on/off the trailer a few times to a show. It has not been driven nor did I plan on driving it till I torqued the axle nut and went over all the work the previous owner did. |
just making sure you know castle nuts on the rear get torqued to 220-230 ftlb. MANY have come here wonder why they keep spinning drums and are only torqing to 50-100ftlb....ken.... _________________ ITMC
Secret Service |
Posted: Mon Jul 28, 2014 4:00 pm Post subject: |
luckystiff wrote: |
luckystiff wrote: |
just making sure you know castle nuts on the rear get torqued to 220-230 ftlb. MANY have come here wonder why they keep spinning drums and are only torqing to 50-100ftlb....ken.... |
Thanks I read that a few times. Looks like im gonna eat a heavy dinner and get out my breaker bar and extension. Hopefully thats the issue _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
