Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Mon Jul 28, 2014 5:26 pm Post subject: |
TMI Products wrote: |
Mike Fisher wrote: |
I used a tow chain double wrapped around a floor jack & the upper bumpstop to lower/raise. It a took a week or more & I should have bought some kind of threaded spring compression tool. |
well that doesn't sound fun.
air shocks look real good right about now |
Yeah, but you have to remember Mike is old. We did my son's car with a floor jack, and some hand tools in a couple of hours (both sides). It's not that bad of a job to do (1 spline), but getting the right combo of, inner and outer splines is the hard part (what I like to call a combo move).
You could try loosening the 2 bolts above the rear shocks (forward square holes in the load floor), and the 2 bolts under the rear subframe to floor pan, and see if you can bounce/push the body over a little, to splitthe difference in the gap between the fender and the tire. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Tue Jul 29, 2014 7:00 am Post subject: |
Well, it was first time & method but Bobnotch just Looks old! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Tue Jul 29, 2014 11:37 am Post subject: |
Never discount the perversion of a PO.
(Rule #72)
Just because the right way to set torsions is with a bubble protractor,
Doesn't mean he did it that way. _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Tue Jul 29, 2014 3:59 pm Post subject: |
Clatter wrote: |
(Rule #72)
Doesn't mean he did it that way. |
On our cars, I use a magnetic angle finder. What I try to do is get both sides to match each other. If I find 1 side is still lower after that, then I've got a reference measurement to go from there with. Then it's just a combo move to get what I want for a setting, as the torsion bars WILL sag over the years. This is why it's covered in Bentley, as age does have an effect on the bars themselves.
Also, the rubber bushings that support the end of the spring plate can be worn, and that will effect height differences too.
But yes, you can't discount what the PO did either, as he may, or may not have known what he was doing. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
TMI Products Samba Member
Joined: February 14, 2014 Posts: 744 Location: Corona, Ca
Posted: Thu Jul 31, 2014 8:16 am Post subject: |
well this thing has some wiring issue.
Passenger headlight doesn't work, blinker is very dim. I can use a power probe at the light terminals and headlight is fine, will feed back power to left side headlight, so wiring must be good.
Fuel gauge has no illumination or anything. Speedo illuminates. So I need to pull the fuel gauge and see if it was converted already.
No running lights on rear. blinkers work fine. All bulbs illuminate with power probe. There's 3 bulbs, what are their purpose????
Found a loose tach wire, but the doesn't work. Its a new VDO tach, so I have to either use another tach to test the wires or make sure the dip switches are correct.
The wiring is all cut and spliced im guessing for the 12V conversion , but with anything, I don't know who did it and if it was done right.
its always fun going over somebody elses work. _________________ Mario De Leon
1965 Turbo Mustang Fastback
1966 Type 3 Fastback
VW Division Sales Manager
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Thu Jul 31, 2014 8:53 am Post subject: |
Sounds mostly like ground issues. Make sure your terminals are all clean as well. Converting to 12v doesnt require any wiring changes, people just like to go crazy with splicing and dicing. I'm no electrical genious, but the last couple cars I've bought I just sat down for a couple hours with a wiring diagram, cleaning terminals, making sure bulbs are good and making good contact with the spring loaded contacts, getting rid of previous owner hacks, etc etc. |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Thu Jul 31, 2014 9:01 am Post subject: |
I would second the previous. You are checking with a grounded tester, you should check the ground at the light as well. I will test the circuit , then check the ground (put power on the clip & stab the light housing. Best of luck |
Posted: Thu Jul 31, 2014 9:31 am Post subject: |
the headlight plugs are spliced, the taillight connectors are spliced, the harness form the column has butt connectors and loose wires.
I assume the car was driven before I got it. But being that it was disassembled and painted before I got it leads me to ground issues. _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
supersuk Samba Member
Joined: December 20, 2010 Posts: 958 Location: Honolulu, Hawaii
Posted: Thu Jul 31, 2014 11:02 am Post subject: |
The fuel gauge housing should be grounded in order for the fuel gauge and light to work. For the headlight issue, check the ground on the divider that separates the spare tire and the gas tank. There should be one on each side that grounds the headlight wiring. It is screwed into the compartment divider. As for the tail light running lights, that could be a whole bunch of things...if anything, i'd assume bad ground or bad connection at the light switch. I'm actually going through all of this at the moment. Finishing up all the wiring in my car right now so I can drive it up my driveway to have it towed to the painters.
Good luck! _________________ 68 Fastback Build: http://www.thesamba.com/vw/forum/viewtopic.php?p=5396323#5396323 |
Posted: Thu Jul 31, 2014 11:12 am Post subject: |
supersuk wrote: |
Good luck! |
thanks,
looking at the wiring diagram over and over, I am really tempted to rewire the car _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Erik G Samba Member
Posted: Thu Jul 31, 2014 11:13 am Post subject: |
being that it was disassembled and painted before I got it leads me to ground issues. |
This. Always this. Painters remove stuff, overspray everywhere, and slap it back together. I have spent a significant amount of time scraping paint off contact points, wires, connectors, you name it |
Fiatdude Samba Member
Joined: April 20, 2009 Posts: 1218 Location: now in MO.
Posted: Thu Jul 31, 2014 4:15 pm Post subject: |
With all the butt connectors etc, etc, stuff you're talking about I'd be seriously thinking about a good kit to rewire it --- simple insurance, because wiring gremlins are a bitch to chase as you're figuring out --
also that way you become one with your car LMAO _________________ Remember, as you travel the highway of life,
For every mile of road, there is 2 miles of ditch |
Posted: Thu Jul 31, 2014 5:56 pm Post subject: |
Erik G wrote: |
That's what it sounded like to me too (ground issues). This is also where I like to have a VOM, 2 jumper wires (1 about 20 ft long) with aligator clips on each end. That allows me to reach almost anywhere on the car, and test for power, a or good ground.
But, since the car was just painted, I'd bet most of your problems are related to that. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Aug 04, 2014 2:17 pm Post subject: |
Well I found the back of the fuel gauge loose and missing bulbs, hanging next to the fuse panel which is missing about 5 fuses and has over spray. That would explain why in not getting any lights. Its been miserably humid to be in the garage, but hopefully I can DRIVE it out of the garage tonight and start tracing some wires.
How does the fuel gauge come out? I removed the dash pad and my Bentley manual is on its way still. _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Erik G Samba Member
Posted: Mon Aug 04, 2014 2:24 pm Post subject: |
Its been miserably humid to be in the garage |
Paaaalllleeeesse, try Houston
Clock first if I'm not mistaken. Then you can get to the back of the speedo, and then fuel gauge. Maybe thats backwards, It's been a while
oh, and ANYTHING electrical, check the fuses first. Like take them out, look at them, make sure the contact points are good, etc.
I just fixed the broken A/C in a truck I bought by actually pulling the fuse. It was a little melted and didnt pop. Fuses today are shit |
Posted: Mon Aug 04, 2014 2:49 pm Post subject: |
Erik G wrote: |
hey that one day was REALLY BAD
Is there any type of retainter that holds the fuel gauge in the dash or is it the wiring? it moves in and out about a inch but something holds it in. Gremlin maybe? _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3692 Location: San Jose, CA
Posted: Mon Aug 04, 2014 3:10 pm Post subject: |
Erik G wrote: |
Is there any type of retainter that holds the fuel gauge in the dash or is it the wiring? it moves in and out about a inch but something holds it in. Gremlin maybe? |
There are two tabs on the gauge, one on either side. Squeeze them as you push the gauge out of the dash. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
Posted: Mon Aug 04, 2014 3:15 pm Post subject: |
squaretobehip wrote: |
Erik G wrote: |
There are two tabs on the gauge, one on either side. Squeeze them as you push the gauge out of the dash. |
Got it, I felt those, probably wasn't squeezing hard enough _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Posted: Mon Aug 04, 2014 7:33 pm Post subject: |
it moves!
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Posted: Mon Aug 04, 2014 10:27 pm Post subject: |
Nice car -- -- Come over to Adams Track (AMP) in Riverside tomorrow night for time attack and you can see how little tire clearance is really needed -- I'll have the Ghia out there trying to learn how to turn corners again ..... probably from 6 to 8pm _________________ Remember, as you travel the highway of life,
