volwing Samba Member
Posted: Mon Jul 28, 2014 10:26 am Post subject: Cooling 1641 Engine |
Other than the stock cooling tins is there another set of tins that offer better air flow for the cylinders or perhaps additional oil cooling? |
marklee Samba Member
Joined: March 24, 2009 Posts: 821 Location: Flintshire, North Wales
Posted: Mon Jul 28, 2014 10:36 am Post subject: |
AFAIK stock is best... _________________ CGLI qualified body repair and refinish tech
CGLI qualified motor repair tech
Qualified automotive Glass installer
Motor Insurance Repair and Research Centre,Thatcham, Advanced Vehicle Damage Estimator.
Police qualified vehicle examiner
Police Class 1 High performance, pursuit trained Advanced driver |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Brian Samba Moderator
Posted: Mon Jul 28, 2014 10:40 am Post subject: |
"dog house" cooler with all the tins. All of them. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Mon Jul 28, 2014 10:51 am Post subject: |
Now running stock but may change to 1641. I read that the thin walls lead to heat problems. Just trying to help the cooling while the conversion is being done. |
Posted: Mon Jul 28, 2014 10:56 am Post subject: |
If you're going bigger go bigger. 1776 with doghouse set up and you'll be happy. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Mon Jul 28, 2014 11:16 am Post subject: |
Looking at a 1776 Brian but too expensive. I can convert to 1641 for less than $400 vs $2300 for 1776. |
Danwvw Samba Member
Posted: Mon Jul 28, 2014 11:34 am Post subject: |
No real reason to do the 87mm cylinders now with the 88mm Thick Wall Piston and Cylinder set. They give your engine the thick cylinder wall, thicker than the stock engine plus the engine displacement is increased to 1679cc when used with a stock 69mm crankshaft and 1800cc when used with a 74mm crank. When having your heads done or ordering cylinder heads order the 88mm ThickWall, 90.5, 92mm head opening heads. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Mon Jul 28, 2014 11:55 am Post subject: |
I have a set of heads that accept 90.5 so I guess no machining needed. Thanks for the idea. |
gt1953 Samba Member
Posted: Mon Jul 28, 2014 2:49 pm Post subject: |
With all of the proper tin and stock doghouse cooler you should be just fine.
Do you or are you planning on temperature gauges? _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Mon Jul 28, 2014 3:04 pm Post subject: |
In re to temp gauge I have the dipstick version. |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Mon Jul 28, 2014 3:48 pm Post subject: |
Make sure you have the correct fan for the later Super-beetle (dog-house) cooling system...many, many people do not check this
That is ALL YOU NEED for a street-driven car up to around 75 ponies at the pavement
What car/body is it in? There are some other checks, tricks and tweaks... |
Posted: Mon Jul 28, 2014 6:06 pm Post subject: |
Its a 73 Super Beetle. Has all the tins and fan is good. |
Posted: Mon Jul 28, 2014 6:19 pm Post subject: |
Danwvw wrote: |
No real reason to do the 87mm cylinders now with the 88mm Thick Wall Piston and Cylinder set. They give your engine the thick cylinder wall, thicker than the stock engine plus the engine displacement is increased to 1679cc when used with a stock 69mm crankshaft and 1800cc when used with a 74mm crank. When having your heads done or ordering cylinder heads order the 88mm ThickWall, 90.5, 92mm head opening heads. |
Is there a problem with the 88mm slip ins due the thin cyl. at the case end? |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Mon Jul 28, 2014 7:44 pm Post subject: |
volwing wrote: |
where did you get those prices?
1641 sounds like no machine slip-ins (those are bad news) and the 1776 sounnds like you got the I dont want this job quote. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Danwvw Samba Member
Posted: Mon Jul 28, 2014 8:44 pm Post subject: |
Not the thick wall's but they are about as thick as a beer can at the base and brittle as hell. Just have to be careful with them during assembly. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Mon Jul 28, 2014 9:35 pm Post subject: |
the difference between a 1641 and 1776 is the jugs, that shop must not have liked you or they just have used ones on the shelf as apposed to having to order new ones. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
76VwBug1600 Samba Member
Joined: July 02, 2012 Posts: 575 Location: Lakeside, Arizona
Posted: Mon Jul 28, 2014 10:40 pm Post subject: |
volwing wrote: |
why add 2 horse power? Better off keeping the 1600 and adding Dual carbs and a merged header _________________ 1976 Fuely Bug
1973 Super beetle with 26k Original miles.
1968 1600cc
1973 1641cc
1966 Rat-rod
1981 VrRabbit
Not Just our cars.. They are our best friends. |
Posted: Tue Jul 29, 2014 4:30 am Post subject: |
2 HP??? Headers and duel carbs are very expensive and may be difficult to keep adjusted plus my car is a daily driver so the heat in winter is a must. Think I will stay with increasing the motor displacement. |
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Tue Jul 29, 2014 6:08 am Post subject: |
you can run a header and dual carbs and still keep your heat.. |
