semipixel Samba Member
Joined: July 22, 2014 Posts: 56 Location: Nova Scotia
Posted: Mon Jul 28, 2014 11:03 am Post subject: Changing '74 Front disks brakes from 4 lug to 5 - options? |
As the title says, I have a 74 Ghia and I'm looking at options to convert to 5 lug (open minded on the exact pattern) disk brake, from the stock 4.
Has anyone done it? Not looking to break the bank. So far adapters are the only option I've come up with, haven't narrowed the beam yet so I can compensate for that when I do if needed, but I rather find a proper rotor.
Obviously will need to sort out something matching for the back, but I plan to stick with the drums and there seems to be some options there.
Thanks,
Justin |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Mon Jul 28, 2014 12:05 pm Post subject: |
It depends on your desired lug pattern. If you are considering 5 x 130 mm Porsche or 5 x 4.75" Chevy pattern, that's easy. Conversion rotors and drums are readily available.
However, if you are considering 5 x 205 mm, you have to buy a 5 x 205 mm front disc brake kit, as those kits are specially made so the wider bolt pattern can clear the caliper. I doubt that a wheel adapter would clear the stock caliper. Plus, that's a lot of unsprung rotating weight to add. Conversion 5 x 205 mm rear drums are available though. _________________ 1966 Karmann-Ghia convertible |
Posted: Tue Jul 29, 2014 5:47 am Post subject: |
That's great, just had a search around, didn't know you get get rotors/drums with the 5 x 130 pattern. That will do the trick! |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Tue Jul 29, 2014 7:16 am Post subject: |
5 on 130 _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Tue Jul 29, 2014 10:12 am Post subject: |
Scott, how much did you lower that baby? Looks nice. _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Tue Jul 29, 2014 6:08 pm Post subject: |
5x130 Porsche bolt pattern... Adjustable beam & drop spindles yet to be installed
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
