craigman Samba Member
Posted: Tue Jul 29, 2014 6:02 pm Post subject: Frigg'n axle seals..... |
Ok fellas, need your help....
Putting new axle seals on my swing axle tranny. What is the trick to getting them in without destroying them?
BTW, it's the seal that's pressed in the seal housing that bolts on the end of the axle tube. |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Tue Jul 29, 2014 6:43 pm Post subject: |
You need something large as the seal is across, and flat to press, or tap the seal in without distorting it. I used a piece of plate steel last time, and set the bearing retainer flat on my welding table. Tapped around in a circle, after smearing just a little bit of sealer on the outside of the seal. Soon as the seal is flush with the retainer, your done. |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Tue Jul 29, 2014 8:09 pm Post subject: |
I used a flat object as suggested above, them squeezed them in using the jaws of a vice. The vice kept it square as it went in. _________________ 1958 Karmann Ghia owner |
smkn_vw Samba Member
Posted: Tue Jul 29, 2014 8:44 pm Post subject: |
This guy makes it look easy, fast forward 5 min. into the video he uses a 46 mm socket and slowly taps around.
http://www.youtube.com/watch?v=DDXwz4ftvyw _________________ "So didja?" -Bob Hoover |
Posted: Tue Jul 29, 2014 8:56 pm Post subject: |
If it was only that easy! LOL |
maplesyrup Samba Member
Posted: Tue Jul 29, 2014 11:50 pm Post subject: |
In the past I've used the old seals to press the new seals partway in and then finished with a correctly sized socket.... Tiny bit of grease helps. |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Wed Jul 30, 2014 2:29 pm Post subject: |
My problem has always been those STUPID paper gaskets that go behind the retaining plate, they NEVER fit and don't seal worth a shit. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
OLDveedubs Samba Member
Posted: Wed Jul 30, 2014 9:10 pm Post subject: |
maplesyrup wrote: |
^^ _________________ -Ryan
Restoration Updates
www.my59bug.com
"Perfection through inspection." |
