DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Wed Jul 30, 2014 6:37 am Post subject: 67 question |
I'm sure this will be met with an answer quickly. Did all 67 buses come with reverse lights? In particular the 67 Deluxe? _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4561 Location: St Charles, MO
Posted: Wed Jul 30, 2014 7:02 am Post subject: |
Early '67's didn't have the back-up lights, and the later ones did, can't recall the cut-off date, but it is here in a thread somewhere, and when I get home I could look it up. Anyone else have the date/chassis # handy?
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Wed Jul 30, 2014 7:18 am Post subject: |
BulliBill wrote: |
Bill |
I'll research that part Bill. Thanks for your help! I just assumed all 67s had reverse lights. _________________ Anthony
SBS #1
SBS #1 on FB
olliehank47 Samba Member
Posted: Wed Jul 30, 2014 7:22 am Post subject: |
BulliBill wrote: |
Bill |
^^This is the answer^^
I have an early (Aug) 67 deluxe and it doesn't have the back up lights. Many of the 67 only pieces were added throughout the model year and will not be found on all 67 buses. For example, my early 67 does not have the one-year-only rear view mirror, the dual cylinder master cylinder, nor the larger radio hole in the dash. One of the few ways to visually tell any 67 from an earlier bus is the missing finger indent under the button for the rear hatch. A 67 will be the only wide hatch bus that does not have that indent.
Posted: Wed Jul 30, 2014 8:58 am Post subject: |
Thanks Ollie _________________ Anthony
SBS #1
SBS #1 on FB
toydude111 Samba Member
Joined: September 23, 2002 Posts: 841 Location: So.Cal.
Posted: Thu Jul 31, 2014 5:30 pm Post subject: |
It has always been my understanding that March was the month that reverse lights were added. _________________ Do you want fries with that? |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5501 Location: 1st Coast
Posted: Thu Jul 31, 2014 5:43 pm Post subject: |
Makes sense mine is April 67 with reverse lights.
toydude111 wrote: |
It has always been my understanding that March was the month that reverse lights were added. |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Rippers Samba Member
Joined: September 08, 2011 Posts: 255 Location: London, England
Posted: Wed Nov 25, 2015 6:13 pm Post subject: Re: 67 question |
Mine is March 15 1967 and has the reversing lights its part for the M425 package
North American export package including :
- Twin reverse lights
- Compteur en Miles
- Sealed beam headlights
- Hazard warning lights
- Mounting for safety belts in driver's and passenger's compartment
- Laminated windscreen
- Ram protection (bumper with guards)
- Dual-circuit brake system |
Tyler 5447 Samba Member
Posted: Thu Nov 26, 2015 6:42 pm Post subject: Re: 67 question |
Rippers wrote: |
- Compteur en Miles
Mine is December of '66 production. I also have the 425 m code but no reverse lights on my bus. |
Clara Samba Member
Posted: Thu Nov 26, 2015 10:01 pm Post subject: Re: 67 question |
Tyler 5447 wrote: |
Rippers wrote: |
- Compteur en Miles
That package is often mislabeled. It only included reverse lights when reverse lights were standard equipment. ditto for dual circuit brakes, etc.
ie the actual meaning of 425 changed over the years, but the online decoder doesn't have that programmed in. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Fri Nov 27, 2015 1:06 am Post subject: Re: 67 question |
Clara wrote: |
Tyler 5447 wrote: |
Rippers wrote: |
- Compteur en Miles
ie the actual meaning of 425 changed over the years, but the online decoder doesn't have that programmed in. |
I'm working on the theory the list is the most likely the last revision of the M425 which is relevant to my '67 and I have everything on that list. Where as my 64 which also has M425 does not so only parts are relevant to that. |
GTV Samba Member
Posted: Fri Nov 27, 2015 5:50 am Post subject: Re: 67 question |
I currently have two 67's: a September 27, 1966 Standard and a May 26, 1967 SO42. They share all of the same 67 only features (fuel door, radio, rear view mirror, trigger rear hatch, etc. The 9/66 bus does not have back up lights, the 5/67 bus does. I have not compared master cylinders yet... _________________ EMPI Power Rules! |
Posted: Fri Nov 27, 2015 6:18 am Post subject: Re: 67 question |
I don't even recall why I asked this question in the first place. LOL _________________ Anthony
SBS #1
SBS #1 on FB
Clara Samba Member
Posted: Fri Nov 27, 2015 9:14 am Post subject: Re: 67 question |
Rippers wrote: |
Clara wrote: |
Tyler 5447 wrote: |
Rippers wrote: |
- Compteur en Miles
There are earlier and later versions of 425. Where did your list come from?. It does look like it came from a late split list which is correct for a 67, not a 64ish list or bay window list.
I have not seen a decoder that takes into account the date of production to spit out the correct version of 425.
Also, IIRC, there are multiple codes where the details changed over time.
re dual circuit:
