zac_atac44 Samba Member
Joined: September 18, 2011 Posts: 269 Location: Tennessee
Posted: Wed Jul 30, 2014 7:21 am Post subject: Rear main seal question? |
I went to put my flywheel on last night and thought I did everything right but when I went to torque the flywheel down the crank didn't want to turn. It still turned but it was very difficult. I think it had something to do with the rear main seal. I feel like the rear main seal needs to go back further in to the case because it is hindering the flywheel from moving when it is torqued down. My question is...... How far does the seal go back into the case? When I pull the flywheel back off just a little bit it turns a lot easier. Here are some pictures.
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Wed Jul 30, 2014 7:50 am Post subject: |
I would be mo suspicious of the end play setting than the seal- That one could stand to be a bit (1/32 ") below the case. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
esde Samba Member
Joined: October 20, 2007 Posts: 5927 Location: central rust belt
Posted: Wed Jul 30, 2014 7:56 am Post subject: |
What he said. Did it turn freely w end play set and the flywheel installed and torqued to spec? I set enday when my case was apart, the double checked it after assembly, and again after installing the seal. |
mark tucker Samba Member
Posted: Wed Jul 30, 2014 8:10 am Post subject: |
also make sure the flywheel isant contacting the bolts holding the engine to the stand....been there done that. |
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1329 Location: miami florida
Posted: Wed Jul 30, 2014 8:56 am Post subject: |
I dont think the seal is in all the way . |
risk Samba Member
Joined: June 24, 2004 Posts: 710 Location: Stumpbroke, Arkansas
Posted: Wed Jul 30, 2014 9:04 am Post subject: |
Aftermarket flywheel? Could be the radius on the flywheel snout needs turned down some. I have an aftermarket aluminum case and chromoly flywheel, and had the same issue. Turned down the radius on the flywheel and everything fits fine. |
Posted: Wed Jul 30, 2014 9:08 am Post subject: |
Obviously the problem is that the rear seal is at the other end of the crankshaft. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13842 Location: White Mountains Arizona
Posted: Wed Jul 30, 2014 11:32 am Post subject: |
Your seal needs to be a lil further in, just below the case. Doubt that is the issue. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
