rlucas Samba Member
Joined: April 28, 2011 Posts: 70 Location: Netherlands
Posted: Thu Jul 31, 2014 11:24 am Post subject: Kubel? 1946? |
Hi all,
Calling the all knowing people about the earliest beetle (and deratives). I saw a early chassis today that supposedly is a 1946 chassis. Unfortunately the tag with the chassisnumber that is welded normally close to the handbrake has been removed makingit hard to identify... Can anybody perhaps identify the chassis from these two pictures? Do the numbers near the body/suspension mounting make it possible to narrow it down? To my relatively untrained eye it did look like a 46 chassis, but looking at pictures of kubelchassis they seem quite similar. Judging from some of the kubel chassis they seem to have two drain holes in the front in the pan halves?
Many thanks in advance!
virtanen Samba Member
Joined: January 08, 2006 Posts: 1462 Location: Finland
rlucas Samba Member
Posted: Fri Aug 01, 2014 12:35 am Post subject: |
Ah, yes, I see now in pictures yes... Thanks for that! Would there be any other numbers on a chassis like this? I know the later split chassis have framenumber punched in other location too. This chassis seems to have quite a bit of it's other metal still, so if there should be other numbers they might still be there. There are 46 papers with the chassis, so it seems to add up. |
rlucas Samba Member
Posted: Fri Aug 01, 2014 1:17 am Post subject: |
Unfortunately I didn't take a good picture of that area; but I am quite sure the remains of the welding remains were behind the gear shift, making it as you post may 1945. I cropped the area from the high resolution picture to have a better look also. Now, looking at this picture there seems to be some evidence of maybe welding in front of the shifter too? Would have to check in reall life, I only checked behind the shifter area...
Mike Sal Samba Member
Joined: May 28, 2014 Posts: 195 Location: Southern Illinois
Posted: Fri Aug 01, 2014 5:16 am Post subject: |
Wasn't there a battery box impression on the drivers side of the pan in the early vehicles?
Mike Sal |
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 986 Location: Bath, England
Posted: Fri Aug 01, 2014 7:32 am Post subject: Pre May 1945 |
I tend to agree with Mika that this chassis could be pre May 1945. The Cog logo is generally only found on wartime vehicles. I've come across one or two Kubels that are said to have the original or correct vintage, floorpans, but are missing this logo! i.e. Not a wartime chassis. This is the easiest way to check, although hard on the knees! |
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Fri Aug 01, 2014 2:26 pm Post subject: Re: Pre May 1945 |
Martin Southwell wrote: |
The Cog logo is generally only found on wartime vehicles. |
Well, that´s not really that way.
I have two 1949 chassis with still that logo at that location.
And there are lots of other places wher the cogwheel was still seen far after wartime. On some rubber parts well into the 50s.
The chassis in question may be very old but the cogwheel logo is not such an age indicator. _________________ Master of my domain! |
rlucas Samba Member
Posted: Fri Aug 01, 2014 5:04 pm Post subject: |
It is very interesting to read the comments about the chassis; to maybe add; although the floorplans were original they did have some traces of repairs here and there. in that way it would have been possible that it had a battery tray on the other side as well. I do think in general they are the original pans, but just heavily repaired. In any case, I am gratefull for all the input! |
iwlego Samba Member
Posted: Sun Aug 03, 2014 11:18 am Post subject: |
Hi all,
ok, my five cents:
The heater outlet makes it a beetle (not a kuebel), that is pretty clear. If it would be a KdF (pre 45), it should have then a nut on top of the channel in front of the firewall for mounting the gas tank holder (barrel tank). This was only on KdF (type 60, 92 and 82e), not on Kuebels.
Cog wheels were common until 1949. In my 46, 47, 48 and 49 cars they are all over the place.
That means, it looks like a late 45 to mid 49 chassis.
I hope this helps.
Richard _________________ ____________
4-43 Type 60 KdF
4-43 Type 92 KdF
4-43 Type 82e KdF
5-43 Type 82e KdF
8-46 Standard
7-48 Standard
9-48 early Export
7-49 Standard
2-50 Hebmüller
4-50 Export
10-51 Export ragtop
10-50 Barndoor Minibus
5-52 Export
8-52 Barndoor Magirus fire truck
3-53 Barndoor Smoothgate Pickup
6-53 Barndoor Ambulance
9-54 Barndoor Deluxe Samba |
Posted: Sun Aug 03, 2014 12:25 pm Post subject: |
Some pics from the Gallery.
A Kübel
A 1947
My mid 1949 Export
Posted: Mon Aug 04, 2014 3:29 am Post subject: Kubel Chassis |
Another way of telling if a Kubel chassis or not, is the two captive nuts that Kubels have, welded onto chassis, in the area of the gearbox nose cone, which are the front anchor points for the rear skid/under belly protection pan. |
Posted: Mon Aug 04, 2014 3:41 am Post subject: |
Wasn´t the Kübel out of the race with the heater cable tube present? _________________ Master of my domain! |
rlucas Samba Member
Posted: Mon Aug 04, 2014 6:03 am Post subject: |
Have some more pictures; not sure if it makes it more clear or less...
Dashboard seems a bit odd; the glove boxes are the KDF type and seem welded to the dash. But then it has a non removable "blank" plate (KDF had removable plate right?) Then it seems some late 45's had these boxes still, but did these have a removable blank plate or not? If I check the pictures from the 51 of the Grundmann collection
http://www.vw38.de/home/index.php?option=com_joomg...n#category
Besides the removable blank plate it seems quite similar. Maybe it could be an early 46 then? I didn't find online any pictures of very early 46. Otherwise I am guessing it could be very late 45. But I cannot find anywhere this combination of KDF style glovebox and integrated blank plate....
RichOakley Samba Member
Joined: August 30, 2004 Posts: 1108 Location: Midlands, UK
Posted: Mon Aug 04, 2014 7:22 am Post subject: |
rlucas wrote: |
I think your guess is pretty correct. Body is definitely post-KDF/'45 with the less pronounced central rib under the window. Gloveboxes are the early rounded style which I always assumed were discontinued in early '46. Solid dash with non-central logo replaced the blanking plate in early '46. I would guess Jan-Mar '46. _________________ 1947 Beetle
1956 RHD Karmann Cabrio
1956 RHD Beetle
1957 RHD Pitt-Moto Type 2 Camper
1959 RHD Beetle
1966 RHD Type 3 Fastback
1976 RHD Sun Beetle |
iwlego Samba Member
Posted: Mon Aug 04, 2014 7:32 am Post subject: |
Ok, the body is definitely a post war. There were three different central ribs in 1946!
The first style was like KdF, the second was somewhat round, but with a kind of welding in the middle (my August 46 has this one and I know another 46 with the same) and the third one is the one of your car which went into 47 and later years.
The five ribs changed to 3 in late 47 I believe.
This narrows it down to a later 46 or 47 car.
The chassis is definitely not kuebel and not war time!
Mika is correct in that there have been KdFs with square tanks in 44, but the heater knob outlet and the missing water holes are clear indications of a not Kuebel chassis.
All in all, I would say it is a great car with a correct chassis and a pretty good body to restore from 46 or 47. Hard to find vintages ...!
4-43 Type 60 KdF
4-43 Type 92 KdF
4-43 Type 82e KdF
5-43 Type 82e KdF
8-46 Standard
7-48 Standard
9-48 early Export
7-49 Standard
2-50 Hebmüller
4-50 Export
10-51 Export ragtop
5-52 Export
Posted: Mon Aug 04, 2014 7:34 am Post subject: |
Wow, there´s a whole car and not just a floor.
Isn´t there a tag still or a body number at the front of the body in the spare wheel area? _________________ Master of my domain! |
Posted: Mon Aug 04, 2014 7:43 am Post subject: |
I still think those gloveboxes hold a clue to the dating the body more precisely. I'm sure the rounded shape ones were only used up until about March 1946. I've seen later '46s with the later style metal gloveboxes. Offset VW-logo in the dashboard is also '46-only from what I recall- by late '46 this logo was centralised. _________________ 1947 Beetle
1956 RHD Beetle
1959 RHD Beetle
