Danpa Samba Member
Joined: August 21, 2007 Posts: 1248 Location: Valparaiso, in
Posted: Thu Jul 31, 2014 3:57 pm Post subject: A buddy needs advice |
A friend at work has a 79 911. He checked the compression a while ago and it was OK in all cylinders. The other day he started it and he said it REALLY was smoking bad, burning oil in BIG clouds.
Any suggestions?
Thanks,
Dan |
jt912 Samba Member
Joined: March 16, 2006 Posts: 207 Location: Eugene, OR
Posted: Fri Aug 01, 2014 7:11 am Post subject: |
Has the car been sitting for a long time? Oil tends to collect in the exhaust system in cars that sit for long periods. Takes some time to burn it off.
There are many other possible causes. |
thesatanicmechanic Samba Member
Joined: November 30, 2008 Posts: 102 Location: Charlotte, NC
Posted: Sun Aug 03, 2014 12:27 pm Post subject: |
If coming from the tail pipe, i would suspect oil level too high, or engine has "wet Sumped", ie. most of the oil has drained from the tank into the crankcase & some has gone past the piston rings. |
Danpa Samba Member
Posted: Sun Aug 03, 2014 2:34 pm Post subject: |
Thanks for the advice! I talked with him the other day and he did say the car has sat for a while, so maybe either of these might be the case.
Any good way to drain the oil out of the exhaust, short of drilling a "drain hole", if this is the case?
I was thinking that however the oil drains back from the heads to the crankcase might have some blockage and the heads might be filling up with oil and leaking past the valve seals, but I really don't know much about Porsches (except that I want one).
Dan |
HarryFD Samba Member
Joined: February 24, 2012 Posts: 751 Location: Portland, OR
Posted: Fri Aug 15, 2014 9:26 pm Post subject: |
It does not take much oil to make a huge cloud. Have him drive it for about 20 minutes. If it is just oil leaking by the piston rings it should resolve itself. Be sure he has a fire extinguisher in case the stuff ignites. _________________ 1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1973.5 911 Targa
2009 MB C300 |
