bradself Samba Member
Posted: Sun Aug 03, 2014 3:58 pm Post subject: Distributor lube reco please: 205A advance weights |
Hey all, I've got a 205A out of a 914 2.0 Porsche number 0 231 174 011. The advance weights, stamped with # 281, have plastic sliders that I don't want to disintegrate from fresh lubricant. Regular dizzy lube or something special? Thanks! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Sun Aug 03, 2014 4:05 pm Post subject: |
It's hard nylon.... don't worry about the lube.
The heat is the real problem and makes them hard and brittle. _________________ Glenn
Member #1009
#BlueSquare |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21518 Location: Oklahoma City
Posted: Sun Aug 03, 2014 7:55 pm Post subject: |
Yes...and nylon still wears. It ahould be good for a, long time....but if you want to lube to keep it from eventually wearing out.....go to napa or on line and buy a product called "slip stick". I think its made by the same people who make sil-glide.
It is silicone and high temp paraffin. No dropping point....goes on dry as to nit attract dust and is made for lubing nylon and UHMW. Its about $6 for a 5/8" X 4" stick in a tube. Its also what virtually all dealers used to grease trunk locks and window channels in the 70's. Ray |
