Jerry39218 Samba Member
Joined: June 23, 2014 Posts: 182 Location: Brandon, MS
Posted: Thu Aug 07, 2014 3:50 am Post subject: Ok, this camber adjustment has now annoyed me.... |
As I am STILL waiting on the new shims.... I tried once again using the OLD shims and here is where I moved them around to.
A-2
B-6
C-6
D-2
Other than a little play in the lower linkpin bushing on one side everything seems fine....except..
for I still have a slightly camber-toed front end!!! (causing the outside of the tires to wear)
that's the max I want to go on the shims...nothing seems bent, everything appears ok.
Any ideas? Am I missing something?
Even had an old VW guy tell me that people used to weld steel Ibeams on the front end to counter that?? Seriously? |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Thu Aug 07, 2014 4:19 am Post subject: |
Do any of your shims have the O ring and are thicker? There are 2 different settings using 8 or 10 shims that I believe are dependent on that. _________________ D-Dubya Manx clone - 63 Short pan,1914.
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Thu Aug 07, 2014 5:34 am Post subject: |
Hmmmm .. why does this sound so familiar..
VOLKSWAGNUT wrote: |
On Link Pin Beams.. CAMBER IS NOT ADJUSTED WITH MOVING THE SHIMS..
Camber is cast into the carrier assembly.. using the correct shim chart IN THE SERVICE MANUALS... sets the carriers to torsion arm offset properly and "compensates" for manufacturing variances.
If you think you just set your camber by swapping a few shims around..... you actually are simply binding the assembly and quick wear in the bushings will result.
http://www.thesamba.com/vw/forum/viewtopic.php?t=449284&highlight=camber+front
And for the cheap seats.. read the upper left.....
You are fighting a battle that wont be won..
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Thu Aug 07, 2014 5:57 am Post subject: |
Fine... it's not adjustable.
Solution?
Replace the whole front beam?
Or just shim it (against the book yet it's what old timers say do hah) and possibly replace link bushings sooner than 5 years?
Suggestions please... |
Posted: Thu Aug 07, 2014 6:07 am Post subject: |
After reading up some more I'm thinking replacing the link pin carrier.
My question is how did both sides get SO much positive camber and the carriers do not look to be bad or bent?
This thing looks very pigeon toed on camber and the tires that were on it the outside was almost bald. |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Thu Aug 07, 2014 6:45 am Post subject: |
My Manx is set to the factory camber and the tires show no signs of wear with 30,000 miles on them. How many miles do your worn tires have? Replacing the beam will not affect the camber at all. The camber is dictated by the trailing arms, spindles and carriers in conjunction with the link pin shims. _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
Posted: Thu Aug 07, 2014 7:10 am Post subject: |
Then I can only presume that the wrong parts were installed at some point.
I suppose when money and time allows I can replace the carrier and spindles |
Posted: Thu Aug 07, 2014 7:13 am Post subject: |
The VW stock spec is slightly positive camber, and slightly positive toe.
Of course if you have any wheel or tire on it other than stock.. stock specs can be pissed out the window.
(new slot wheels ?)
Stock link carriers seldom have issues.
Trailing arms are usually the weakest link and issue.
Some have had success with a nice whack with a mallet.
BUT!!!
You would then need to remeasure and set up the shims according to the the charts for your application.
Could be what you see as exterme.. is perfectly fine and 100% normal
Wide tires amplify the looks, effects and tire wear of positive camber..
Do you have any idea what you car actually has for angles?
Toe/Camber/Caster..
If its toe'd in too much it will wear the outside edges as well.
Got pics of this pigeon from the front on a good level surface?
. _________________ aka Ken {o\!/o}
Dale M. Samba Member
Posted: Thu Aug 07, 2014 7:35 am Post subject: |
A possibility is you may have a set of bent tubes....
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Thu Aug 07, 2014 8:21 am Post subject: |
If the front camber really does exceed the stock VW specs after shimming according to the book, I think the most likely reason is the lower trailing arms have been bent inwards, it does happen but most usually on the curb side. VW supposedly had a jig to check the arm. I suppose you could compare them to another known good arm.
Another thing I've seen happen is the grub screw on the trailing arm wasn't adequately tightened right in the center of the dimple on the torsion leaf stack and the arm has worked itself outwards. |
Posted: Thu Aug 07, 2014 11:07 am Post subject: |
I believe there may be some pics posted.
Nothing appears bent and it's the same positive camber both sides.
No I have nothing with which to measure but it looks like 1" out on the top of the tires.
Since I adjusted the shims only looks about .5 " out.
The old tires were almost bald on the outer half...inside of the tires looked new. |
Posted: Thu Aug 07, 2014 11:48 am Post subject: |
Another factor is how worn are the shanks of the bolt that engages the spiral grooves machined in the link pins. I've seen them real sloppy.
These type of link pins are more positively held.
http://www.mooreparts.com/1200-AC405055/
Another possibility is your king pins are worn |
Posted: Thu Aug 07, 2014 11:58 am Post subject: |
^ Normally worn king and or link pins... create Negative Camber..
Unless you take an actual alignement measurement you are just quessing at what it actually is.
On a good solid level surface.
Use a plumb bob, string, level and a tape measure..
There are also handy dandy angle finders that work ok.. even smart phone Apps.
I looked through your pics and really didnt see anything abnormal.. It could all be a toe in issue that give the illusion of excessive positive camber.
Measure your angles... or get it measured by a professional. .
Posted: Thu Aug 07, 2014 1:35 pm Post subject: |
It's camber. Positive camber. Not a toe in issue.
I will see if I can get some kind of measurement. |
Iguana Samba Member
Posted: Thu Aug 07, 2014 1:50 pm Post subject: |
Jerry39218 wrote: |
What are your actual measurements in offset front top to bottom arm ?
You say you have moved shims around so u should have before and after ? or where you just chasing camber ?
Did you put in new king pin bushes ? If so what ream tolerance did you go with ?
Have you checked the carries ? 90% or more of the king pins I have done have been bent ... they are very weak and no doubt just one of the many reasons the BJ came along and was stronger and thicker. |
EVfun Samba Member
Posted: Thu Aug 07, 2014 2:02 pm Post subject: |
I can think of 2 things, one of which has been mentioned.
1. The trailing arms are bent by whacking curbs. Seems less likely when you have the same problem on both sides. It will twist the arms though, so when you strait edge them to get a measurement to determine where to put the shims you may (if it isn't severe) get a valid answer, but excess positive camber when done.
2. If you are using old shims they may be worn. The specs only work for new shims. If using old shims you have to measure the shims and put the correct thickness of shims in between the king pin carrier and trailing arms. The actual count could be wrong to get the measurement right. In my experience it is the upper inboard shims that wear the fastest. _________________
Wildthings wrote: |
Posted: Thu Aug 07, 2014 5:53 pm Post subject: |
BL3Manx wrote: |
I had an original test jig from VW back when I was racing. Typically a stock lower arm would be out of spec after one day of short course 1-2/1600 racing. A properly gusseted arm would last at least a season. _________________ Jerry...
RIP Morgan
My photos
Posted: Thu Aug 07, 2014 6:43 pm Post subject: |
Iguana wrote: |
Jerry39218 wrote: |
dunno--I don't have a micrometer..yet.
Shims moved as follows:
A=2
B=6
C=6
D=2
I haven't done anything with bushings, do not have the capability.
Carriers do not appear to be bent, but with Jackson streets, I suppose that is a good possibility.
I believe I'm just going to replace the whole damn thing and be done with it. Spindles with carrier built already--found them at SoCal I believe.
As I have no way and do not know anyone who can press in the kingpin stuff.
I did find a vw mechanic, however he's not familiar with the kingpin front end...yet |
RedBaronofRedBud Samba Member
Joined: July 05, 2013 Posts: 505 Location: Southeast Missouri
Posted: Thu Aug 07, 2014 6:50 pm Post subject: |
Jerry39218 wrote: |
Iguana wrote: |
Jerry39218 wrote: |
A=2
B=6
C=6
D=2
I had always heard that the king/links were stronger, but the turning radius of them suck (ask me how I know). Anyway, there is a shop in St Louis that can do your King/Link pin work. Archway Imports in St Louis. They have an ad in Hot VWs too. 314-638-7700. Jim is a great guy and very knowledgeable. They did my link/king pin spindles and did a great job. I would check them out first before you go out and get new. _________________ Or you can call me………Tim
My two pennies…your mileage may vary
I’m not a complete idiot, there are parts missing |
Iguana Samba Member
Posted: Thu Aug 07, 2014 7:01 pm Post subject: |
RedBaronofRedBud wrote: |
I had always heard that the king/links were stronger |
Nope K&L are the weakest front end made ... BUT they are easily modified to gain additional strength and more travel.
Strength Wise in order
K&L
BJ Type 1
BJ Type 181
Modified K&L
After Markey K&L ( King Kong etc)
That is if the Mods are done correctly, if not then they are open to be weak and fail. |
