1956vw Samba Member
Posted: Thu Aug 07, 2014 6:56 am Post subject: All 4 Wheels on my Oval date stamed 11/72??? Head Scratcher |
My 56 oval is from the Monterey/Seaside area. It spent all it's life there until 2010. I swapped the wheels for a set of powder coated ones until I restore these and was very surprised by how clean the wheels were on the inside (between the beads, where hidden by the tire). Every wheel has the remains of shipping stickers from VOA to the dealer at the Monterey Peninsula (Wester) dealer. I thought that was odd so I stripped the paint to find the date stamp and they are stamped 11/72. This car is very original and has only been painted once, back in 2010.
I wonder if the wheels were stolen at some point? I have been theorizing and that is the only reason I can come up with so far for replacing all 4 wheels back in the 70s.
Any thoughts?
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Thu Aug 07, 2014 7:41 am Post subject: |
Maybe they are 1872. _________________ Mother Nature is a Mean Evil Bitch! |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Thu Aug 07, 2014 6:56 pm Post subject: |
I see a zip code on the sticker those started in the early 70's. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
3foldfolly Samba Member
Joined: March 08, 2009 Posts: 894 Location: Edwardsville, Il
Posted: Thu Aug 07, 2014 7:11 pm Post subject: |
I believe zip codes started in early to mid 60s. |
stale air Samba Member
Joined: August 23, 2007 Posts: 5154 Location: Senoia Ga, formally NorCal
Posted: Thu Aug 07, 2014 8:00 pm Post subject: |
That is definitely the date stamp, and I would say that they are just what you think they are, dealer replacement wheels dated 1972. It makes sense to me. It had only been 5 years since VW had stopped running smoothies on the the beetle, so I'm sure there was enough of a demand to continue manufacturing them. _________________ WANTED: Henry Veale Santa Rosa plate frames
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1276 Location: australia
Posted: Thu Aug 07, 2014 11:56 pm Post subject: |
the only time I have heard of a car needing 4 new wheels was a car that hit a cattle grid at 100mph or so and destroyed all 4 alloy wheels, not too likely with steelies and a 36hp... |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Fri Aug 08, 2014 6:16 am Post subject: |
Do your wheels have a safety bead on the rim? I think VW started with the safety bead in late 67. Perhaps the replacement wheels with hub cap clips also had the safety beads, hence the owner decided to play it safe and go with a more modern rim design. There was a lot of hype when radial tires started coming to the market about tires rolling off rims, not much of it true unless you were pushing a huge amount of weight around a corner with very low air pressure. |
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 24131 Location: Southeast USA
Posted: Fri Aug 08, 2014 7:19 am Post subject: |
Snort wrote: |
Exactly what I was going to post. The replacement rims should have safety beads. It was the law that all new rims sold had to have them. And the replacements I've seen also used the narrower air stem, and not the larger diameter ones like the originals. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
1956vw Samba Member
Posted: Tue Aug 12, 2014 1:50 pm Post subject: |
Blue Baron wrote: |
Snort wrote: |
Exactly what I was going to post. The replacement rims should have safety beads. It was the law that all new rims sold had to have them. And the replacements I've seen also used the narrower air stem, and not the larger diameter ones like the originals. |
In this picture it looks like they do have the safety bead, sightly raised prior to dropping towards center of wheel.
