Jason vw Samba Member
Joined: February 18, 2004 Posts: 194 Location: WinterPark Fla
Posted: Thu Aug 14, 2014 7:56 pm Post subject: |
got the bus on my bd jig and from these shots i really tried to capture just how wavy the raw metal was. this type of waviness isnt caused by grinding but by bad planning. there is going to have to be a lot of filler used to make this panel straight again.
_________________ Jason Stratton 407 497 9944
Stratton Motorsports, Winter Park, Florida
follow me on instagram "Strattonmotorsports"
http://www.thesamba.com/vw/forum/viewtopic.php?p=6855439#6855439 |
beetleboy58 Samba Conquestador
Posted: Fri Aug 15, 2014 6:52 pm Post subject: |
Hansolo99 Samba Member
Joined: December 04, 2010 Posts: 524 Location: So Cal
Posted: Fri Aug 15, 2014 7:40 pm Post subject: |
beetleboy58 wrote: |
Double-no quadruple that! No wonder you had it picked up!! Look forward to seeing how this gets fixed........................ |
wcfvw69 Samba Purist
Posted: Fri Aug 15, 2014 9:34 pm Post subject: |
Holy hackery! _________________ Contact me at [email protected]
The Samba member since 2004.
ezcamper Samba Member
Joined: January 10, 2001 Posts: 897 Location: Atlantic Beach, FL
Posted: Sat Aug 16, 2014 4:30 am Post subject: |
Seems like the owner would want the long panel replaced....and the other hacks. _________________ I make HWE style roof racks, Jim-Dandy racks, SO-33 metal parts, Dormobile racks, HWE style ladders, engine crank start handles, Westy rack tags, Binz tags, Sundial badges, State of California tags, steering lock electrical covers and single / double cab gate latch friction blocks.
instagram is http://instagram.com/bullidriversteelworks |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Sat Aug 16, 2014 8:18 am Post subject: |
ezcamper wrote: |
Seems like the owner would want the long panel replaced....and the other hacks. |
The long wall was already replaced with a new Klassicfab piece while at KCW - it was mentioned in the thread that it came out awesome and was perfectly straight - what happened to it?
Was this caused by being blasted 80 times or maybe parts shifting around while in transport? That looks like someone played handball on it for months - not sure if it's poor install or got damaged since then - but that looks wasted. |
bubba Samba Member
Posted: Tue Aug 19, 2014 11:45 am Post subject: |
My guess would be from the heating up of the metal from plug welding... Looks like it was pushed in in spots to meet the inner structure .. pretty common.. then welded for a nice tight fit to the structure... Hard to tell if the structure was original... and if it was ever damaged in its long life time. Not an easy panel to replace with that style of welding and keeping it truly flat and straight. The factory spot welded the panels in place, and this is the proper type of welding Jason does at his shop. _________________ ***WANTED***
SO-23 Cargo net hooks...
for sale
curtain Bungee cords for SO23, 22, 33 ,34 ,35
http://www.thesamba.com/vw/classifieds/detail.php?id=1587591 |
Posted: Tue Aug 19, 2014 1:06 pm Post subject: |
bubba wrote: |
The factory spot welded the panels in place, and this is the proper type of welding Jason does at his shop. |
In 10 years on this site and reading 100's of restoration threads, I can't recall ever seeing another person/shop use that spot welder that Jason used on Gerson's BD.
I can't imagine doing that kind of panel repair/replacement for a living and plug welding and grinding! What a time killer vs. just spot welding... _________________ Contact me at [email protected]
Posted: Wed Aug 20, 2014 8:40 pm Post subject: |
campingbox wrote: |
Definitely not from transport. _________________ Jason Stratton 407 497 9944
Posted: Wed Aug 20, 2014 8:44 pm Post subject: |
bubba wrote: |
My guess would be from the heating up of the metal from plug welding... Looks like it was pushed in in spots to meet the inner structure .. pretty common.. then welded for a nice tight fit to the structure... Hard to tell if the structure was original... and if it was ever damaged in its long life time. Not an easy panel to replace with that style of welding and keeping it truly flat and straight. The factory spot welded the panels in place, and this is the proper type of welding Jason does at his shop. |
Very well put and i agree not an easy panel to replace but thank you for the very kind words. we are trying to keep them as straight as we can and make them look as original as we can. theres no sense in taking short cuts just because interior panels will coverup the metal work. you know what they say "Just because you cant see it doesn't mean it shouldn't be done correctly." _________________ Jason Stratton 407 497 9944
Posted: Wed Aug 20, 2014 8:45 pm Post subject: |
wcfvw69 wrote: |
bubba wrote: |
I can't imagine doing that kind of panel repair/replacement for a living and plug welding and grinding! What a time killer vs. just spot welding... |
Thank you for the very kind words. _________________ Jason Stratton 407 497 9944
Posted: Wed Aug 20, 2014 8:56 pm Post subject: |
well we were going to try to save what was there but after seeing the condition of everything
we thought it would be best to remove everything we felt was wrong so it could be done correctly
Posted: Wed Aug 20, 2014 9:21 pm Post subject: |
this picture shows how close the other guys didnt get the panels together before they welded them. this is when a compression spot welder really is worth the money. make it right, make it tight.
