1954 23 window- Frankie's Deluxe
campingbox Premium Member
campingbox is offline
PostPosted: Mon Nov 24, 2014 8:44 pm    Post subject: Reply with quote
I would have thought enclosed transport would have been a wise investment, especially considering the fact that there was a pile of loose parts inside. That would have kept it from being exposed in bare metal too.
mr white
mr white is offline
PostPosted: Tue Nov 25, 2014 10:51 pm    Post subject: Reply with quote
Where is this bus at now? What is being re-done?
Jason vw
Jason vw is offline
PostPosted: Sun Nov 30, 2014 11:25 am    Post subject: Reply with quote
Okay so time to update the thread.
removing the old long panel.
cutting out individually all of the previous shops plug welds.
Jason Stratton 407 497 9944
Stratton Motorsports, Winter Park, Florida
follow me on instagram "Strattonmotorsports"
http://www.thesamba.com/vw/forum/viewtopic.php?p=6855439#6855439
Jason vw
Jason vw is offline
PostPosted: Sun Nov 30, 2014 11:33 am    Post subject: Reply with quote
new drivers side b-pillar going in also note the beltline hackery has been removed as well.
setting in the new separation panel
Jason vw
Jason vw is offline
PostPosted: Sun Nov 30, 2014 11:34 am    Post subject: Reply with quote
Jason vw
Jason vw is offline
PostPosted: Sun Nov 30, 2014 11:44 am    Post subject: Reply with quote
installing the rear most (deluxe) pillars above the wheel tubs.
early compared to late
Jason vw
Jason vw is offline
PostPosted: Sun Nov 30, 2014 11:48 am    Post subject: Reply with quote
finalizing the long side reinforcements
more drivers b pillar detail. note using door seals to set proper placement of pillar.
Jason vw
Jason vw is offline
PostPosted: Sun Nov 30, 2014 11:59 am    Post subject: Reply with quote
details of the klassic fab panel being used to replace the outer b pillar and semaphore hole.
Jason vw
Jason vw is offline
PostPosted: Sun Nov 30, 2014 12:12 pm    Post subject: Reply with quote
we had to replace the passenger wheel tub due to this
Jason vw
Jason vw is offline
PostPosted: Sun Nov 30, 2014 12:47 pm    Post subject: Reply with quote
when we removed the short side panel we found this.
and that wouldnt stand so we put and entire pass c pillar in
Jason vw
Jason vw is offline
PostPosted: Sun Nov 30, 2014 1:04 pm    Post subject: Reply with quote
getting rear corner mocked up
took corner off and short side panel and joined then together as one piece before attaching permanently to the body
door gaps look pretty good on finished product
Jason vw
Jason vw is offline
PostPosted: Sun Nov 30, 2014 1:13 pm    Post subject: Reply with quote
after the short side panel was on and the new lower c pillar was attached the door didnt close properly. the cargo door rocker had been installed too high and had to be removed. the previous shop probably never checked this prior to making the lower rockers a solid unit
a special guest stopped by to help work on the bd23 during bulli brigade weekend
this is hopefully the last piece of metal the the previous shop installed that we will have to remove
Jason vw
Jason vw is offline
PostPosted: Sun Nov 30, 2014 1:48 pm    Post subject: Reply with quote
rear corner repair and prep. using the frame machine to draw the metal as tight as possible
photo credit MrPolak
Jason vw
Jason vw is offline
PostPosted: Sun Nov 30, 2014 2:10 pm    Post subject: Reply with quote
tubdub
tubdub is offline
PostPosted: Sun Nov 30, 2014 2:13 pm    Post subject: Reply with quote
Very nice work.
55samba
55samba is offline
PostPosted: Sun Nov 30, 2014 3:02 pm    Post subject: Reply with quote
Wow, that is an amazing amount of work. Very impressive.
low54
low54 is offline
PostPosted: Sun Nov 30, 2014 3:41 pm    Post subject: Reply with quote
Great to see this coming together again what a difference.
65 original paint so42 dormobile
52 original paint 52 split beetle
Hansolo99
Hansolo99 is offline
PostPosted: Sun Nov 30, 2014 5:36 pm    Post subject: Reply with quote
Wow. Sometimes I feel bad about my welding, but after seeing that-I'm really not that bad. Thanks for boosting my confidence level!
BTW great job.
ibjack
ibjack is offline
PostPosted: Sun Nov 30, 2014 6:11 pm    Post subject: Reply with quote
I just stumbled onto this thread, as I'm a type 3/34 guy. Just wanted to say wow. Nice to see a car getting the touch of a craftsman who does it right.
'68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074
grailoc
grailoc is offline
PostPosted: Sun Nov 30, 2014 8:29 pm    Post subject: Reply with quote
you Guys just know your work, impressive Exclamation
My 59 low light ghia: https://www.thesamba.com/vw/forum/viewtopic.php?t=452128
My 56 beetle convertible: http://www.thesamba.com/vw/forum/viewtopic.php?p=7796259
My 60 SO23 westy: http://www.thesamba.com/vw/forum/viewtopic.php?t=341539
My oldspeed 36hp autotechnik express build: https://www.thesamba.com/vw/forum/viewtopic.php?t=670827
My garage build: http://www.garagejournal.com/forum/showthread.php?t=199438
Page 5 of 9
