DadaCheese Samba Member
Joined: April 15, 2008 Posts: 837 Location: Richmond, CA
Posted: Tue Nov 24, 2015 3:28 pm Post subject: Re: 1967 SO-42 |
Pinetops wrote: |
You're right they did. However mine came with just a piece only covering the speaker as you can see on my original speaker bracket pictured. |
This seems to have been consistent/true for Tourist Delivery of SO-42s during 1967.
Here's our original speaker grill cloth (1967 Westfalia SO-42):
_________________ ----------------------------------------------------------
Dada as in dadaism.
Cheese as in the stuff I love to eat. |
Pinetops Samba Member
Posted: Tue Dec 01, 2015 2:36 pm Post subject: Re: 1967 SO-42 |
Thanks DadaCheese, our buses are so very similar.
I installed the speaker/bracket. This bracket and speaker is absolutely the largest you could get in there. I had to unhook the passenger wiper arm behind the dash to get it to fit with the speaker. Also, I mounted it as far to the right as possible and it still pushes up hard against the radio. When I get the radio repaired I think I will cut just a little off the speaker bracket so it fits better.
_________________ "A rolling bus gathers no rust." |
Posted: Sun Dec 06, 2015 4:32 pm Post subject: Re: 1967 SO-42 |
I installed a second extinguisher by the driver's door. Now I have the 2 and the blazecut.
Random nighttime pics:
Posted: Mon Dec 14, 2015 5:41 pm Post subject: Re: 1967 SO-42 |
I'm supposed to be using my bus in a wedding this coming weekend so i went to change the oil and adjust the valves and found a surprise. Three of my cylinder studs were stripped in the case. I suppose if three have stripped the others may not be too far behind.
I debated on what to do but since I don't have time to strip it down and install case savers and rebuild it so I decided to use some oversized studs. Hopefully this engine gets me down the road for a little while longer until I can rebuild it or replace it.
One installed:
I'll clean everything up while it's out, its amazing how dirty an engine can get over a short period of time.
Also my oil cooler seems to be leaking (it has new seals in it) so I ordered one, just one more thing....
Posted: Mon Dec 21, 2015 4:19 pm Post subject: Re: 1967 SO-42 |
Installing new oversized stud:
Back in with engine and bay cleaned up:
Look what came a day late I'll pull the motor again soon and install the new cooler and do a few other things while it's out.
It made the wedding and ran great:
Ran When Parked Samba Member
Joined: September 26, 2013 Posts: 781 Location: Birmingham, AL
Posted: Mon Dec 21, 2015 6:31 pm Post subject: Re: 1967 SO-42 |
Is that a spring in the photo? What is it's use? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Mon Dec 21, 2015 7:42 pm Post subject: Re: 1967 SO-42 |
Sh*tBird wrote: |
Think that to which you refer to is the aluminium/magnesium threads of the engine case that were pulled out by the head stud. _________________ In Stereo, Where Available! |
Posted: Tue Dec 22, 2015 6:32 am Post subject: Re: 1967 SO-42 |
Eric&Barb wrote: |
Think that to which you refer to is the aluminium/magnesium threads of the engine case that were pulled out by the head stud. |
That is correct. _________________ "A rolling bus gathers no rust." |
nice dad Samba Member
Joined: July 25, 2013 Posts: 317 Location: Honolulu, HI
Posted: Sun Apr 17, 2016 4:58 pm Post subject: Re: 1967 SO-42 |
Super awesome bus! _________________ 1967 Single Cab |
Posted: Sun Apr 17, 2016 5:08 pm Post subject: Re: 1967 SO-42 |
Thanks Nice Dad _________________ "A rolling bus gathers no rust." |
Posted: Wed May 04, 2016 4:14 pm Post subject: Re: 1967 SO-42 |
I've been working on the hubcaps some.
I cleaned up these thick layers of paint on the backs:
In progress:
Primed and then painted rustoleum smoke grey:
Posted: Thu May 05, 2016 10:51 am Post subject: Re: 1967 SO-42 |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Thu May 05, 2016 8:51 pm Post subject: Re: 1967 SO-42 |
I went through the whole thread just now, great stuff, you are the right person to get the bus out of the trees. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
Posted: Thu May 05, 2016 11:37 pm Post subject: Re: 1967 SO-42 |
Thanks Red, I really appreciate it. _________________ "A rolling bus gathers no rust." |
Posted: Fri May 06, 2016 11:33 am Post subject: Re: 1967 SO-42 |
These two are almost done. This pic makes the emblems look greenish but they are blue. I used a brush:
Posted: Thu Jun 09, 2016 4:40 pm Post subject: Re: 1967 SO-42 |
Just a small update. I let the hubcaps cure for about a month and finally put them on. I need to paint the wheels white at some point.
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Fri Jun 10, 2016 2:33 am Post subject: Re: 1967 SO-42 |
Wow steady hand Pinetops, nice job. What is that metal u-shaped or upside-down staple shaped rod welded to your bumper? I was thinking a step of sorts and is it stock?
Pinetops wrote: |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Posted: Fri Jun 10, 2016 4:54 am Post subject: Re: 1967 SO-42 |
Thanks. The metal brackets on the front bumper are still a mystery to me. They are in an odd position if you actually wanted to use them as a step but they look like they could be stock. They are bolted on. _________________ "A rolling bus gathers no rust." |
Col_Forbin Samba Member
Joined: November 25, 2011 Posts: 84 Location: Austin, Texas
Posted: Fri Jun 10, 2016 3:37 pm Post subject: Re: 1967 SO-42 |
nice! I really like the way it looks with the blue front emblem and on the hub emblems.. balances really well. awesome bus and build! _________________ Goin' where the climate suits my clothes
Levon the 66 Westy:
http://www.thesamba.com/vw/forum/viewtopic.php?t=655780
71 Deluxe Bay |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Fri Jun 10, 2016 5:08 pm Post subject: Re: 1967 SO-42 |
Pinetops wrote: |
Thanks. The metal brackets on the front bumper are still a mystery to me. They are in an odd position if you actually wanted to use them as a step but they look like they could be stock. They are bolted on. |
can you post a pic of how they bolt on? could it be they are installed backwards? _________________ regards
Uli
