Fransolis94 Samba Member
Posted: Sun Aug 10, 2014 3:48 pm Post subject: VW Thing 1975 bigger carb for more power? |
Hi guys! I have been working on thing to make it off road, it has a 4 inch body lift, and MT big tires on, but i want to increase the torque for off roading and hil climbing. It has the stock factory carb, but putting a single bigger carb would help with the torque? Thanks! |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Mon Aug 11, 2014 7:33 am Post subject: |
Get a set of duals, don't go with a single dual barrel center mount. |
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1184 Location: Richmond, Va
Posted: Mon Aug 11, 2014 9:47 am Post subject: carbs |
Hey Fransolis94,
good question, and Bashr52 had a good suggestion, duals do seem
to make a difference.
But before you buy anything, note that VW engines like certain combo's
of "Carb, distributor, exhaust" setups to run at their best.
I had no idea till I was looking into upgrading my carb for more HP,
(I have a pict 30/31 carb single port, 009 dizzy and 73 stock Thing exhaust)
well, just bumping the carb back to the pict 34 wouldnt work right due to the 009 dizzy, and thus would prob have to get a SVDA dizzy to fix that.
all said n' done, I'd prob have to spend $900 to $1000 for carb, dizy and new exhaust, to get a matched set so to speak, so I held off for now.
So "I held off" for now, (Not saying you should) but please get mo' info, and Please share, as it seems to be the certain carb/dizy/exhaust combos work for the specific usages (ie: road driving, off roading, etc).
I'd be curious personally what to decide to run with and PLEASE post some photos man!
Good luck with it all, I'd still like to do this myself, have even pondered buying a beetle to muck with to make a street ripper, (the wife says, SURE GO AHEAD) but it's in the tone of voice that I probably shouldnt! LOL
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
Posted: Mon Aug 11, 2014 10:59 am Post subject: |
Thanks guys!! Really good info! I will think about what to do, thanks |
Posted: Mon Aug 11, 2014 11:39 am Post subject: |
Call John at Aircooled.net. He knows as much as anyone about carbs. |
iltis74 Samba Member
Joined: November 20, 2003 Posts: 826 Location: Anchorage, AK
Posted: Mon Aug 11, 2014 10:26 pm Post subject: |
Center mount carbs require pre-heat, which you'll lose when you put on a 1 3/8" header to take advantage of your new single carb. If I were you I'd first put on a decent header/muffler that you can live with, and figure out what dual carbs you are going to run, and then order up an svda distributor matched to the carbs. At this point you'll be able to justify 1.4:1 rockers. Good times. |
strelnik Samba Member
Joined: October 01, 2010 Posts: 352 Location: Michigan
Posted: Fri Aug 15, 2014 9:44 am Post subject: Re: carbs |
doublecanister wrote: |
Hey Fransolis94,
T |
It would be great to hear from anyone with a dual set-up, telling what size/brand carb/intake, distributor/exhaust combination they used and which possibly to avoid. _________________ L'audace! L'audace! Toujours l'audace! |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Fri Aug 15, 2014 12:52 pm Post subject: |
Wildthings wrote: |
X2. I purchased my dizzy from them.
You may want to check this out on their website. For off road applications they recommend a single center mount carb.
http://www.aircooled.net/vw-carburetor-options-selection-101/ _________________ Ghia Owner Emeritus |
Posted: Fri Aug 15, 2014 5:41 pm Post subject: |
NOVA Airhead wrote: |
Wildthings wrote: |
http://www.aircooled.net/vw-carburetor-options-selection-101/ |
Thanks for the info!
I read these articles and they are very informative and enlightening. Plus they are written by people who write plain English! _________________ L'audace! L'audace! Toujours l'audace! |
