Jerry39218 Samba Member
Joined: June 23, 2014 Posts: 182 Location: Brandon, MS
Posted: Wed Aug 13, 2014 6:51 am Post subject: |
Was hoping that spring was fine. Hmmm.... can't go any further till I get the new cable on tho |
Posted: Wed Aug 13, 2014 7:01 am Post subject: |
Well... not having any luck so far of finding one. |
Posted: Wed Aug 13, 2014 7:48 am Post subject: |
Now that I've had my coffee let me correct myself.
Yes the arm spring is broken.
And I can install the cable... but the spring has to go on first lol.
Yeah..I'm awake now. |
Posted: Sat Aug 16, 2014 9:58 am Post subject: |
Forgot how much I disliked working on these things without all the right maint. Equipment
What's the trick of getting the clutch arm off after removing the snap ring?
(Replacing the clutch arm spring)
I can attempt to pry hard but didn't want to damage the arm.
Any suggestions?
I have wd40. No torch. No puller. And no lift. Do have it on stands tho |
167luckycharm Samba Member
Joined: January 17, 2007 Posts: 328 Location: Kauai Hawaii
Posted: Sat Aug 16, 2014 10:38 am Post subject: |
All the clutch arms I've removed in the past, required to have the outer top edge of the shaft filed down a little. I used a short 3-corner file to remove the peened-over metal that prevents the arm from sliding off the shaft. If you think that part is difficult since the trans is installed in the car, wait until you try to preload that spring onto the arm. Keep your fingers clear of the short end and the bell housing. You'll need some stout screwdrivers or a prybar for that. I'm hoping that it will all go easy for you!
Sending some positive vibes your way...
Good luck!
John _________________ Humble Pie, it might be good for you, but it always tastes like sh!t
See my 009 Distributor page on Facebook, search for VW 009 Distributor Discussion
http://www.facebook.com/pages/VW-009-Distributor-Discussion/499742640126712 |
tgodber Samba Member
Joined: May 02, 2004 Posts: 410 Location: Okanagan Falls B.C. Canada
Posted: Sat Aug 16, 2014 10:39 am Post subject: |
I keep a piece of threaded rod and a couple of cable clamps for this kind of problem. After using this method to attach the shortened cable I have not had to repair or replace the clutch cable in 6 years.
You can just clamp the rod to your broken cable and done. The threads on the threaded rod grip the cable. Does not slip. Buy a new cable for a spare.
_________________ My wife said I never listen to her.
Or something like that! |
Posted: Sat Aug 16, 2014 11:26 am Post subject: |
Already threaded the new clutch cable. Gonna do the loop thing.
BUT.
The clutch arm spring is broke.
Now I'm trying to get the clutch arm off, and install the new spring. I can't get the thing to budge at all.
Half a can of wd40 and 4 hours so far. But it just will not budge at all...not even enough to get it to the edge to where I would need to file hah.
And yes, the snap ring is off...finally. been prying, beating, cursing, prying some more...beating some more.
Trying to find a small enough puller now...maybe that will work. |
Posted: Sat Aug 16, 2014 3:34 pm Post subject: |
Frustration has set in.
It has beaten me today. I give up. Time to step back and chill. |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Sat Aug 16, 2014 5:43 pm Post subject: |
To get it to start moving, wedge the tip of a flat screwdriver (or two if possible) behind it, then use a drift punch to hammer on the end of the shaft. |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Sat Aug 16, 2014 7:01 pm Post subject: |
Get a can of penatrating oil ,pb blaster is often recomended,then get 2 hammers,position 1 hammer against the arm at the bottom of the arm then gently tap on the opposite side,take your time,it will loosen up,and do has luckycharm said clean the end of the shaft.toss the wd 40 in the garbage can. |
joescoolcustoms Samba Member
Posted: Sat Aug 16, 2014 9:58 pm Post subject: |
I just wind the spring around the arm. I do not take the arm off to replace that spring. Kind of like spinning a bolt on. It takes some finesse with some screw drivers to flip the arm end over the arm, but about 10 minutes I have it done. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Sun Aug 17, 2014 5:06 am Post subject: |
Drift punch?
This thing is still in the car...on a jack stand. I have maybe 2 feet underneath of room.
I can't see how I can get to the back side of the arm.
I tried spinning it on..quite cumbersome with the axle in the way but I did make a bit of headway ....had to release the level lockout screw and move it out a bit...
I may try that route again. Hands are quite sore this morning from this endeavor tho.
I do not have the raw strength needed I'm afraid. |
Posted: Sun Aug 17, 2014 5:11 am Post subject: |
joescoolcustoms wrote: |
I just wind the spring around the arm. I do not take the arm off to replace that spring. Kind of like spinning a bolt on. It takes some finesse with some screw drivers to flip the arm end over the arm, but about 10 minutes I have it done. |
So you loop the main winding over the arm...Then pry the bottom into place I take it?
How do you get all 3 windings in place?
Guess I'm gonna just have to fell my way thru this one. Can't recall ever replacing one of these.
If anyone is close to Jackson MS and wouldn't mind showing me how to do this please do. |
Posted: Sun Aug 17, 2014 6:03 am Post subject: |
Ok...I screwed the spring on there. Surprisingly easier than I anticipated. Still have the last winding to get behind the arm and the hook around the arm. |
Posted: Sun Aug 17, 2014 6:44 am Post subject: |
Got it!!!!!!
Now I know the trick!!!
Thanks guys |
Posted: Sun Aug 17, 2014 6:48 am Post subject: |
Jerry39218 wrote: |
Got it!!!!!!
Thanks guys |
Cool!
Now finish and go drive that buggy! _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Sun Aug 17, 2014 8:32 am Post subject: |
would love to, however the pedal assembly does not want to cooperate.
I need to unbolt the master cylinder and get that rod outta the way, also the brake pedal spring came undone and now I can't find where it was connected to.
No, the haynes manual isn't clear enough on the pics.
I had the pedal assembly almost back in there, and the clutch cable came off the arm.
(would be easy if I had help holding the cable taught from the other end, but noooooo... hah) |
Posted: Sun Aug 17, 2014 8:47 am Post subject: |
Use electrical tape, or masking tape to hold the cable end to the hook. Spring can be twisted around after the peddles are bolted up and into place. The spring prys off of the floor and hooks around the brake master cylinder push rod boss on the brake peddle. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Sun Aug 17, 2014 10:50 am Post subject: |
you by chance have a pic of the spring end that does not hook on the brake pedal?
You're saying it hooks on the master cylinder rod? behind the ring that the pedal pin goes into? |
Posted: Sun Aug 17, 2014 12:58 pm Post subject: |
Sorry for the delay, replacing plumbing in the house.
A few from the gallery.
For late chassis:
For early chassis.
