spidershackov Samba Member
Joined: September 06, 2014 Posts: 5 Location: Oak View Ca.
Posted: Sat Sep 06, 2014 11:53 pm Post subject: |
Nice car. Hard decision to make. I agree that once modified it never goes back. |
85burb Samba Member
Joined: February 26, 2014 Posts: 220 Location: Lindale Tx
Posted: Sun Oct 05, 2014 11:52 am Post subject: |
Had some idle problems last weekend when I pulled the car out to get to my mower. Would not idle. I found the issue and fixed it today. It was a plugged idle jet. On a side note the car is listed for sale. Not set on selling. Just seeing if there is any intrest in it. So far none. |
85burb Samba Member
Posted: Sat Oct 11, 2014 2:43 pm Post subject: |
It looks like I will be keeping the beetle. Got a very old carb kit from local vw shop and the carb top gasket felt nice and flexible still. Removed carbs top and replaced leaking broken gasket with new one. The car has a very harsh shake when you let clutch out in first or reverse. Checked front motor mount and it is ok. The rear mounts look kinda scarry so I will change them. Didn't look at clutch cable tube sag but I bet the clutch it self is junk. Just a side note the motor has shaken when starting in first and reverse before the carb issue ever came along. |
85burb Samba Member
Posted: Thu Jan 08, 2015 6:30 pm Post subject: |
A bit of a update. Car is for sale and has been for a while. Have had lots of interest in it. I also put a new set of tires on it. I figured I should take it out and drive it to make sure everything works as it should. I really wish I didn't. It drove as good as a new car. Good heat. Drives strait. Stops great. Does everything it should. Even went 60 mph with no issues at all. Only issue was the window was so dirty it was hard to see when a car was coming at me with there lights on. It ran so well I am thinking about keeping it. It drives way better then my 70 does. The power it has is pretty good too. It does not feel a whole lot slower then my 70. Other then a bit of clutch chatter it was perfict. _________________ 1964 beetle
1974 standard beetle |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1275 Location: australia
Posted: Thu Jan 08, 2015 8:25 pm Post subject: |
i'm playing devils advocate here, but, you know if you sell it you'll regret it.
you know how nice it is to drive... just register it and drive it as is... you won't regret it. (unless you do something stupid and crash it... so don't crash it) if you get bored, strip off the respray and detail it within an inch of it's life. it will feel like a new car.
i'm driving my stock 58 daily. i've got stuff sitting here to tweek it a little, but haven't bothered yet, cause i'm having so much fun with it as it is. every time i drive it i find another reason to love it more.
Last edited by henry roberts on Thu Jan 08, 2015 8:32 pm; edited 1 time in total |
Joined: June 14, 2002 Posts: 1663 Location: Palominas AZ
Posted: Thu Jan 08, 2015 8:27 pm Post subject: |
Ahhhh now you know what a well and truly tuned / maintained older beetle feels like. Unlike a lot of newer beetles who are de-truned and not kept up properly. A good 36/40 HP engine properly tuned with the proper distributor and carb is great for around town. A mismanaged 1600 SP / DP is not much more powerful with a 009 and odd carb combo.
Keep it - you'll enjoy it a lot more in the end! _________________ Ryan
1963 Beetle
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Fri Jan 09, 2015 5:14 am Post subject: |
Keep it. Keep it. Keep it
_________________ .ssS! |
85burb Samba Member
Posted: Sat Jan 10, 2015 6:47 pm Post subject: |
I have decided to keep it. I can't get what I have in it out of it so I will keep it. I hope to get it registered in a few weeks. It needs window seals all the way around. And I have to figure out how to put seat belts in it some how. Are there holes in the car for them already? I have not looked. Thanks for the help deciding. _________________ 1964 beetle
payin_vw Samba Member
Joined: November 27, 2012 Posts: 117 Location: Colorado USA
Posted: Sat Jan 10, 2015 7:05 pm Post subject: |
No holes on a 59, I believe they started on 62, plenty info here if interested in adding belts just do a search. _________________ 61 work in progress restoration, more work than progress actually. |
85burb Samba Member
Posted: Sun Jan 11, 2015 6:50 am Post subject: |
From what I seen is most have welded the belt mounts in. I don't have a welder. Some also used large fender washers and a bolt threw the floor. I may do that. My brother has a welder but he just moved away. _________________ 1964 beetle
vwsonmybrain Samba Member
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
Posted: Sun Jan 11, 2015 10:49 am Post subject: |
I see your car on craigslist every time i go looking for spare parts or a good deal hiding around. I'm like an hour away, so if you need help sometime, or want to borrow a welder, just hit me up. Gas is cheap right now, so i wont mind the drive, plus I would like to see an original 59. Been building mine from scratch
Bret _________________ 1959 baja beetle ragtop( going back to Full body)
1959 beetle
1960 Beetle frame Custom buggy
1962 Karmann Ghia
1967 beetle( august 66, first car)
1967 beetle (parts car)
1977 Westfalia Camper
1972 Plymouth Duster
Just another 22 year old jackass who caught the bug, and lives by the motto " NO fatchicks allowed" , I've got too many cars as is (buses N/A) |
Posted: Sun Jan 11, 2015 12:30 pm Post subject: |
An old mantra from my HCCA days "They're only original once."
I'm in the same boat as you. My 63 is bone stock. Sat since the late 70's early 80's. Did a brake job on it, and drove it 90 miles to put it in a nice dry garage in Tucson. I WAS going to restore it. Now?
Replace upholstery, window seals, decklid seal, hood seal, and leave it alone to drive once in a while. Maybe send the old motorola radio out to see if it can be fixed and replace the speaker. Other than that, I'm keeping mine bone stock. Even the beat up old hubcaps!
If you want something that will go fast / etc why not focus on the 70? _________________ Ryan
1963 Beetle
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24759 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jan 11, 2015 4:44 pm Post subject: |
85burb wrote: |
From what I seen is most have welded the belt mounts in. I don't have a welder. Some also used large fender washers and a bolt threw the floor. I may do that. My brother has a welder but he just moved away. |
Places like a muffler shop would probably weld in the mounts for not much. _________________ In Stereo, Where Available! |
85burb Samba Member
Posted: Sun Jan 11, 2015 4:53 pm Post subject: |
[email protected] wrote: |
If you want something that will go fast / etc why not focus on the 70? |
I will be keeping this one stock. Needs pan 1/4 that the battery sits on and upholstery and window seals and King pins have some play. Other then that some rust repair in the future. I will be doing all go fast stuff to the 70 only. _________________ 1964 beetle
85burb Samba Member
Posted: Sat Feb 28, 2015 7:21 pm Post subject: |
I sold the car today. Sold it to a collector that will restore it properly. Sad to let it go but it will get done correctly now. _________________ 1964 beetle
117harv Samba Member
Joined: June 13, 2009 Posts: 188 Location: MEDFORD OR.
Posted: Sun Mar 01, 2015 12:02 pm Post subject: |
Good on you, thanks for saving another one. |
