Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Tue Aug 19, 2014 2:48 pm Post subject: |
just spoke to Cip1, the high quality one they sell its Chinese made.
The usa one is crap. Ive seen them in person. Really floppy.
Probably going with the steel reinforced westcoast one... _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
talljordan Samba Member
Joined: January 10, 2012 Posts: 968 Location: San Francisco, CA
Posted: Tue Aug 19, 2014 3:00 pm Post subject: |
Hmmm ok, fair enough.
Chinese doesn't always mean shit but it sure isn't a good sign. Did they comment on the fit and quality? I am tempted to try it out because I don't pay shipping with CIP so it would end up being around $200 cheaper. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
jhicken Samba Member
Joined: October 24, 2003 Posts: 9466 Location: Fallbrook, CA
Posted: Wed Aug 20, 2014 5:41 am Post subject: |
You get what you pay for. The Wolfsburg West dash is far superior to any of the competition in fit and finish. I bought one from a popular vendor that referred to it as OEW [it has a big VW logo embossed into it], after trying to install if for a couple hours, I dumped it and bought the WW dash. It went in like butter.
-jeffrey _________________ Der Kleiner Kampfwagens |
Posted: Wed Aug 20, 2014 6:10 am Post subject: |
jhicken wrote: |
-jeffrey |
I called Wolfsburg west, they get their dashpads from West Coast Metric _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
Posted: Wed Aug 20, 2014 7:03 am Post subject: |
Great quality, to be sure. |
Posted: Wed Aug 20, 2014 9:52 pm Post subject: Wednesday- 20 August, 2014 |
Updated list: right rear star adjusters cleaned an lubed. Brakes adjusted and waxed the car.
1. Dash lights inop- no power at the bulbs. Maybe switch
2. Rear shocks are shot.
3. Driver's door window regulator stripped- not just the crank but also the actual regulator shaft. (Regulator will be here Friday)
4. Left front turn signal is a little dim
5. Ball joint boots all shot
6. Left inner tie rod loose |
Posted: Wed Aug 20, 2014 10:15 pm Post subject: Driving impressions |
So far this week I've put 98.2 miles on the little bug. My gas tank tank is sitting between 1/2 and 3/4 tank. I'll top off the tank this weekend to check mpg.
Overall she drives very nice. Tracks straight down the road. I've checked camber angle on the front. It's off... Visibly off.
With a spec of 0 degrees 30' +/- 20' my camber is actually 3 degrees, so I guess I'll be doing an alignment pretty soon, probably Saturday. The tires are pretty well shot from sitting and who knows how old they are. I would not call them a hazard yet, but they should be replaced.
The car also makes a thumping noise from the rear when I hit any bump in the road. I've determined this is coming from worn out lower bushings in the rear shocks. I replaced the axles and CV joints back in 2009. We did not replace the shocks but I'm wondering if my Dad did and he might've tossed the little metal sleeve in the bushing. Won't know till I pop the bolts out. Another Saturday project.
Also, today when I adjusted the brakes, the left rear and right front adjusted easily. The right rear, as I mentioned before this required disassembly of the star adjusters and clean and lube. Now it works great. Wouldn't you know it? The left front wouldn't adjust! Right now everything is adjusted right, no pulling and plenty of stopping power so I'll just add that to my to-do list. |
Posted: Thu Aug 21, 2014 6:23 am Post subject: |
If the shocks are not shot, sometimes having loose shock bolts makes a funny noise in the rear when going over bumps.
Also, You may want to look at NEXEN tires for your bug, at walmart.
Its what im running on mine. Still good after 12k miles.
http://www.walmart.com/ip/Nexen-SB802-Tire-165-80R15/19473481 _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
wcfvw69 Samba Purist
Posted: Thu Aug 21, 2014 6:57 am Post subject: |
Order a set of rear shocks from Wolfsburg West. They have the same feel and dampening as the originals and are priced nicely. I installed them on my stock 69 and they are great. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Thu Aug 21, 2014 7:23 am Post subject: |
Will the 165-80r15 tires fit 5.5Jx15 rims? |
Posted: Thu Aug 21, 2014 7:53 am Post subject: |
flyboy161 wrote: |
Yes.
Posted: Fri Aug 22, 2014 6:47 am Post subject: |
Window regulator and new peanut bulbs are out for delivery. The rheostat portion of my headlight switch is most definitely bad causing the dash lights to not work. Amazingly though in my monkeying around with it they started working...in one specific spot on the switch. It's touchy, kind of like, pull the switch ON and then rotate the dimmer portion vigorously <sic> until the speedo lights come on and then just step away.
Ordered rear shocks but they won't be here until Monday.
So, up for tomorrow...
1. Window regulator
2. Change out the tie rod end
3. Front end alignment (camber adjust) |
Posted: Sat Aug 23, 2014 4:59 pm Post subject: |
flyboy161 wrote: |
Toe in set to 1/8"
I don't have a wrench to fit the eccentrics on the upper ball joints, so camber adjustment will just have to wait.
Gonna take her for a spin now! |
Nice job! FYI, you don't need a big wrench on that eccentric nut. Simply loosen the ball joint nut below it a fair amount. Leave the nut on there so if you miss on the next step, you won't damage the threads. Get a BFH and whack the spindle where the eccentric rests in. It should pop loose. Smack it until it does. Then get a pair of channel lock pliers to turn it. Understand it will have a small impact on the caster as well as you turn the adjuster. If you see the top of the spindle moving back towards the rear while adjusting the eccentric, that will increase the caster. The other way decreases it.
Once you done with that, make sure you recheck your toe setting. I know VW recommended 1/8" toe in but I found that 1/16" was the right setting when doing alignments on these bugs back in the early 80's to prevent outside tire wear. _________________ Contact me at [email protected]
Posted: Sat Aug 23, 2014 7:40 pm Post subject: |
It took 7.933 gallons after going 182 miles. That was a week of adjusting carburetor, timing, and driving back and forth to work, most of which is 55mph. For 22.94 mpg. Hmmm, we'll see what the next tank does. I'm going out on a limb and say the carburetor could probably use an overhaul. It's not stellar mileage but after sitting for the last 3 years it's not too shabby either.
My other vehicles are a Jeep Wrangler that at best gets 14mpg and a BMW that averages 24 with air and a heavy foot, because the Bimmer wants to be driven that way.
But neither car gets the attention the little red bug gets
_________________ My father's 1970 Beetle-
http://www.thesamba.com/vw/forum/viewtopic.php?t=603879
The 1964...Diamond in the rough
http://www.thesamba.com/vw/forum/viewtopic.php?t=612776
My 1958 Morocco Bug-
http://www.thesamba.com/vw/forum/viewtopic.php?t=611483 |
Posted: Sat Aug 23, 2014 9:25 pm Post subject: |
flyboy161 wrote: |
I got ya, so, I whack the spindle with the ball joint nut loose. Not whack the ball joint. Ball joint stays pressed in the eccentric nut. Ball joint nut is loosened to allow the eccentric nut to turn in the spindle.
Thanks, I had to type it out to visualize what was happening. I wouldn't have gotten the bit about caster either. Thanks, great advice! |
Yup, that's exactly it. I wouldn't worry too much about the caster though. Bugs were not sensitive to caster spread between the RF or LF wheels along as the spread wasn't 1* or more which usually indicated something was bent. When we saw a big spread in caster, it was usually a bent front beam that could straighten out on a frame machine.
To your comment about attention- You're right. It's amazing how much attention old VW's get. I have a restored 69 convertible and it's like I'm driving a Ferrari for the amount of attention, looks, thumbs up, etc.. that car gets. _________________ Contact me at [email protected]
Posted: Sun Aug 24, 2014 7:55 am Post subject: |
This morning finish the alignment:
My passenger wheel checks at 3 degrees positive camber and drivers wheel at 1.5 degrees positive.
(Bentley says this has to be done with weight on wheels. I rationalize that lower trailing arm on Jack stand does the same thing. Besides, I'm 6'-2" and oldish and don't like laying on the floor anymore)
Step one jack vehicle and support lower trailing arm at the shock mount with a Jack stand.
Step two, remove tire
Step three, loosen upper ball joint after soaking everything with PB Blaster.
Step four, get the BFH out and rap on the forward part of the ball joint mount on the spindle
Step six, using a pair of channel locks, turn the eccentric nut
Step seven, check the camber angle periodically and adjust as needed.
Mine now reads about a half a degree.
Super easy! Thanks Bill, for the advice!
I will recheck everything once it is on the ground. I have a digital protractor and then will convert it to degrees and minutes. Bentley says 0 degrees 30' +/- 20'. I think I'm in there! _________________ My father's 1970 Beetle-
