Racerrojo Samba Member
Joined: August 01, 2006 Posts: 827 Location: ALBUQUERQUE 87120
Posted: Thu Aug 14, 2014 11:54 am Post subject: Rear heater core options? |
Has any body used a different heater core for the rear.
A search on amazon, yielded some other core that would eliminate the need for the leak prone valve. _________________ Tight is tight... too tight is expensive!!!!
Too many vans and mostly all projects
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Aug 14, 2014 12:15 pm Post subject: |
Sounds interesting...Share the link...??? _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Thu Aug 14, 2014 12:19 pm Post subject: |
Ready-Aire / Vista-Pro 0399022 Heater Core by Ready-Aire http://www.amazon.com/dp/B000CH1HNK/ref=cm_sw_r_udp_awd_3Hq7tb1ZAQVRK
I like to order one to see how it compares or if there's a way to make it work _________________ Tight is tight... too tight is expensive!!!!
Too many vans and mostly all projects |
geo_tonz Samba Member
Joined: August 01, 2012 Posts: 1472 Location: Courtenay, BC, CANADA
Posted: Thu Aug 14, 2014 3:15 pm Post subject: |
The PO of my 9 passenger used something else that was the same size and had the right size fittings. no valve any more unless I want to put in a ball valve. He said he was at a FLAPS and just thumbed through a catologue 'till he found one that looked right and ordered it. Same price as an after market OEM style one though. No issues running it and it pumps out the heat. _________________ ---------------------------------------------------
"Ron Burgundy": 1991 Vanagon Multivan (Weekender) 2.1L Auto - Driver/Camper |
atomatom Samba Member
Joined: May 15, 2012 Posts: 1867 Location: in an 84 Westy or Bowen Island, BC
Posted: Thu Aug 14, 2014 3:20 pm Post subject: |
It would be great to find one that could be controlled by a remote thermostat... probably pricey. _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
Posted: Thu Aug 14, 2014 6:13 pm Post subject: |
atomatom wrote: |
It would be great to find one that could be controlled by a remote thermostat... probably pricey. |
I'm sure you could rig up a push/pull cable pretty easy to a ball valve.
Usually you just turn it on for the winter and off for the summer though. I haven't found it necessary to adjust the temp either, the fan speed adjustment works fine. _________________ ---------------------------------------------------
Posted: Thu Aug 14, 2014 6:27 pm Post subject: |
I leave mine on all the time and add a valve to the front one to close it completely on the summertime _________________ Tight is tight... too tight is expensive!!!!
Posted: Thu Aug 14, 2014 6:37 pm Post subject: |
I have wanted to eliminate the stock under seat heater and add a heater between the two front seats that blows to the rear. This would give way better heat to the back seat area than the stock one that just blows against whatever luggage or cargo that has been stored under the seats.
Another option would be to move the under seat heat off to the right side of the vehicle so it wouldn't get blocked off quite so easily. |
Posted: Thu Aug 14, 2014 7:13 pm Post subject: |
geo_tonz wrote: |
The PO of my 9 passenger used something else that was the same size and had the right size fittings. no valve any more unless I want to put in a ball valve. He said he was at a FLAPS and just thumbed through a catologue 'till he found one that looked right and ordered it. Same price as an after market OEM style one though. No issues running it and it pumps out the heat. |
So you have or can see a part number by any chance?
I have the dimension of the stock core and I could compare to others _________________ Tight is tight... too tight is expensive!!!!
1vw4x4 Banned
Posted: Thu Aug 14, 2014 7:48 pm Post subject: Re: Rear heater vote options? |
Its much easier just to fix the valve. This is one of about 20 things I do
on every new vanagon I own. I take the valve off, take it apart and seal
it with silicone. Then clean up the o-ring area and reinstall it, sealing with
silicone also. On all my water cooled vanagons and everyone I've ever
done like this, not one has ever leaked since.
Racerrojo wrote: |
A search on amazon, yielded some other core that would eliminate the need for the leak prone valve. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Fri Aug 15, 2014 9:17 am Post subject: |
Does the silicone still allow the valve to operate? Without leaking? Or do you simply put the valve in one position and silicone it in place permanently?
I thought they leaked from the o ring under the plug, so i got a new plug and O ring?
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
1vw4x4 Banned
Posted: Fri Aug 15, 2014 9:23 am Post subject: |
Yes , the valve operates fine. Although, most of the leaks I've found are
at the o-ring attaching it to the heater. May want to try just this first.
IdahoDoug wrote: |
Doug |
LandSailor Samba Member
Joined: October 30, 2009 Posts: 315 Location: Las Vegas, NV
Posted: Fri Aug 15, 2014 2:06 pm Post subject: |
Mine leaked from the pivot in the middle of the valve. I replaced it with the one from Rocky Jennings and couldn't be happier with it.
http://www.thesamba.com/vw/forum/viewtopic.php?t=584562
What's your time worth? $10? $20? $25 per hour?
The price difference between an unknown, "whatever they send you from Amazon" (since the reviews indicate you will NOT receive what's shown in the picture) and the genuine replacement is $65.
How much time will you invest into...
...finding the right fittings.
...purchasing the right fittings (time on internet/drive to parts store)
...rigging up a part that isn't the same size to fit the available space
...installing the part securely. (anything above thirty minutes is extra work)
Most of all, is knowing that you have the right part worth anything? The original core in mine held up for thirty years. This one may be fine for that long, too, but "rear heater core failure" is waaaaaaaaaaay down on my List of Things that will Ruin Our Vacation. |
Yondermtn Samba Member
Joined: November 21, 2007 Posts: 609 Location: Illinois
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Tue Oct 07, 2014 1:31 pm Post subject: |
I have purchased lots of VW/Audi parts from Hansauto..and some parts for my two Daughter's Audi A6 C4.and 1990 VW Cabriolet. If I have a problem, Peter..the owner..is quick to fix the issue with the correct part or refund.
Most of his parts are from China or suppliers in Europe..the quality is about the same as everyone else.
Got a brand new $76!! Vanagon 251959455M radiator fan from Hansauto that sells for a mind blowing $450 from everyone else (at the time..new from VW now $180) back in June 2012..The Hansauto fan works just fine.
In that it is a rear heater core and you don't have to pull the dashboard out to install it like the front heater core..spend the $14 and let us know how it goes?
Last edited by AtlasShrugged on Tue Oct 07, 2014 1:39 pm; edited 1 time in total |
squeegee_boy Samba Member
Joined: April 27, 2008 Posts: 762 Location: Langley, BC, Canada
Posted: Tue Oct 07, 2014 1:38 pm Post subject: |
My van didn't come with a rear heater (pulled long ago by one of the previous 4 owners). So I installed this one:
http://www.princessauto.com/pal/en/Auxiliary-Heating/24700-BTU-12V-Auxiliary-Heater/4240028.p
It works brilliantly; a nice, gentle, wafting heat, and plenty of it. Easily reaches the front of the van. It has 3 speeds just like the stock unit, and wires right in to the Vanagon harness.
Robyn _________________ 1984 FrankenSyncro Westy. EJ25 RMW kit
1971 Super Beetle with an EJ22. Oh yes. Daily driver |
Colorado Yeti Samba Member
Joined: August 25, 2013 Posts: 356 Location: Ft. Collins, Colorado
Posted: Tue Oct 07, 2014 2:26 pm Post subject: |
I trashed the original heater / vlave and installed this school bus heater. Incredible heat output and pretty afordable. 33,000 btu's.
climatecontrol.com/products/162/20048-Series-Under-Seat-Heater |
Posted: Wed Oct 08, 2014 11:12 am Post subject: |
What the heck? I ordered this thing. I'll post a review. _________________ 1977 Westfalia 2.0FI 4spd
1990 Multivan 2.1 Auto |
Honuak Samba Member
unibagel Samba Member
Joined: December 02, 2004 Posts: 529 Location: Bflo, NY
Posted: Wed Oct 08, 2014 12:06 pm Post subject: |
Only for use with the engine running? How many amps does that baby pull? |
