Spindle/ Hub Threads
Page: Previous  1, 2
Riff Raff
Shivering Sambian
Riff Raff is offline
PostPosted: Wed Aug 27, 2014 8:19 am    Post subject: Reply with quote
Kevin
I have had good results using a thread file to clean up abused threads.
I'm a little surprised how often I use it, now that I have it.
One other nice thing about them is that they don't care if the threads are left handed.
The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin
DubStyle
SBS Hit Squad
DubStyle is offline
PostPosted: Wed Aug 27, 2014 10:09 am    Post subject: Reply with quote
If you don't have a thread file, use a triangle jewlers file.
Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club"
BarryL Premium Member
BarryL is offline
PostPosted: Wed Aug 27, 2014 10:41 am    Post subject: Reply with quote
electronictofu wrote:
It was just going on really hard and I was afraid of damaging the threads.
Obvious question but I have to ask it, you are using a right hand thread nut? Sometimes they get mixed up easily.
BarryL is offline
PostPosted: Fri Aug 29, 2014 12:58 pm    Post subject: Reply with quote
Figured I'd go ahead and do one for you.
Here's a crusty candidate. Granted it doesn't have crossed threads but it is as bad and will be as hard as if it did.
Here's how to chuck it up and insert the blade. You must have already figured all that out if you made your own.
Just pick how many cuts you want and go for it.
I made this one with six cuts.
Gently start it on. I use magnifiers to see if it's going straight.
Then start turning in 1 to 1/2 turn and back up a smidge if it gets tight before going farther but don't be afraid to go for it. You can go dry or use oil. I chose to go dry just to prove a point that it will cut.
After not long I was all the way in.
It was so clean I could back off the nut by hand.
All ready to clean up and go.
If you want I'll send you this nut as it's the same side as you but it's for a '67 as long as that's good for you.
williamM
williamM is offline
PostPosted: Fri Aug 29, 2014 2:05 pm    Post subject: Reply with quote
paint some muriatic acid on that poor thing before you do your thread repair and it will not clog up so bad. then neutralise with baking soda
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
KombiMadness
KombiMadness is offline
PostPosted: Fri Aug 29, 2014 3:04 pm    Post subject: Reply with quote
You should also be using WD40 or something similar when you're re-cutting the thread. A few turns on, then back it off, clean any swarth off, then a few more turns, back it off, clean swarth....... Over & over until you're done.
My brother & I on the roof of Dad's Splitty circa 1967 - I'm the half pint with the skinny legs!
BarryL is offline
PostPosted: Fri Aug 29, 2014 3:24 pm    Post subject: Reply with quote
True all that ^^^^ guys.
I was just showing the guy with the stripped spindle that he could carefully chase his thread dry or wet if he went slow using the Jypsy die.
Pacmanfever
Pacmanfever is offline
PostPosted: Fri Aug 29, 2014 6:28 pm    Post subject: Reply with quote
I second this, it's a brilliant simple solution. Great pictures and nicely written up too.
PostPosted: Fri Aug 29, 2014 9:19 pm    Post subject: Reply with quote
I prefer to use actual cutting oil for stuff like this although I have used PB Blaster too.
Great photo tutorial above, thanks for posting that.
KombiMadness
PostPosted: Fri Aug 29, 2014 9:55 pm    Post subject: Reply with quote
Hey Barry, wasn't trying to rain on you..... Smile
It is an excellent tutorial and great close up photos. Also, my bad because I didn't read your post properly and missed you saying you could use oil or go dry.....
Smile Cool
RPGreg2600
RPGreg2600 is offline
PostPosted: Fri Aug 29, 2014 10:43 pm    Post subject: Reply with quote
Just buy a die.
http://www.ebay.com/itm/1pc-Metric-Left-Hand-Die-M...338cfb4dcc
15 bucks on Ebay. I bought one a couple years ago, worked great. Also, you don't need the special giant die holder, you can just use vice grips or channel locks.
Page: Previous  1, 2
Page 2 of 2
