Mike C Samba Member
Joined: September 18, 2008 Posts: 303 Location: Albuquerque
Posted: Fri Aug 15, 2014 7:20 pm Post subject: Number 9 fuse keeps blowing |
1970 bus all stock
This morning driving to work the gas gauge suddenly dropped to empty. Then turn signals stopped working. I got to work and saw that the gen and oil light were not turning on when I turned the key. I figured it was a fuse and that it would be an easy fix. I replaced the fuse and it blew. Checked out the connections--looked fine and the fuse blew again. I searched and found a few ideas on how to make a fuse testing light so that I don't keep blowing fuses. I can work on that tomorrow.
Where would I start trouble shooting? This is the first time the bus has had fuse issues. It starts and runs fine, but don't like the idea of driving without the oil and gen light working. Just as I was about to try to trouble shoot it began to rain...go figure. I appreciate any feedback. Thanks. _________________ Bone stock 1970 non-walkthrough "Station Wagon" bus
[quote="1977_L63H_P27"]As mentioned before, it's a 9-passenger Deluxe. The true "station wagon" of buses. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51130 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Aug 15, 2014 7:49 pm Post subject: |
You'll have to find what's touching a grounded surface, the back of the fuel gauge is a common one as well as multiple parts of the signals starting with the hazard switch. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Mike C Samba Member
Posted: Fri Aug 15, 2014 8:04 pm Post subject: |
Thanks Busdaddy. I appreciate the help. _________________ Bone stock 1970 non-walkthrough "Station Wagon" bus
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3551 Location: San Diego (Encinitas)
Posted: Fri Aug 15, 2014 11:34 pm Post subject: |
Be sure to check the hazard switch itself to see if it has popped apart and shorted against something.
Be sure to disconnect the battery before messing with the switch - it's 'hot' (terminal 30) all of the time... _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Sat Aug 16, 2014 5:28 am Post subject: |
This diagram is for a later bus. But if you look at current tracks 39-50 you will see everything that is fed by the S11 fuse (equivalent to the one you are blowing).
Double click to enlarge
Tcash Samba Member
Mike C Samba Member
Posted: Thu Aug 21, 2014 5:32 pm Post subject: |
So, I can't find anything out of the ordinary--grounding, etc. The hazard switch is working fine and isn't related to the #9 fuse (at least on my bus). I've traced the wires behind the panel and nothing. The one thing I did realize since I'm having fuse issues is the PO replaced the fuse box to fit 7.5 fuses instead of 8:
The problem #9 fuse slot:
So, the only thing I haven't done is take all of the wires out and make a mess of them (electrical is beyond me).
The bus is running just great and have held off driving it to work (I'm a Homebound special ed. teacher which takes me all around the Albuquerque area) since the oil and gen light are not working.
Would you still drive it even though those lights weren't working? What should my next step be besides taking it to the local VW shop?
I was even thinking of replacing the fuse box to a stock VW one, but all electrical have been working fine until this blasted #9 fuse. _________________ Bone stock 1970 non-walkthrough "Station Wagon" bus
Posted: Thu Aug 21, 2014 7:11 pm Post subject: |
From the Gallery:
Cobb together one of these. Use it to jump the fuse that keeps blowing. It will light up. Start disconnecting stuff and moving stuff until the lamp goes out. Whatever made it go out is the problem.
Note: 7.5 is close enough to 8. No fuse runs near max ratings, so it should be OK. _________________ '71 panel, now with FI
Mike C Samba Member
Posted: Thu Aug 21, 2014 8:30 pm Post subject: |
telford dorr wrote: |
From the Gallery:
Note: 7.5 is close enough to 8. No fuse runs near max ratings, so it should be OK. |
Thanks! Will do. I was supposed to make one of those but I got lazy. I'm also glad that 7.5 amp is fine. _________________ Bone stock 1970 non-walkthrough "Station Wagon" bus
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Fri Aug 22, 2014 12:16 am Post subject: |
From the Gallery:
Wouldn't this accomplish the same tests and fit into the tool box easier?
It can also be used to test power to the running lights by laying it on the ground and viewing in the mirror or through the windshield.
Aloha
tp |
Tcash Samba Member
Posted: Fri Aug 22, 2014 7:44 am Post subject: |
Aloha
tp[/quote]
Compared to a 8 amp fuse the filament is much smaller. The filament in the bulb would overheat and melt-blow, when the current in the circuit became too high. |
Posted: Fri Aug 22, 2014 10:06 am Post subject: |
It can also be used to test power to the running lights by laying it on the ground and viewing in the mirror or through the windshield. |
Generally, that's true, but for the purpose of this test, no. Your test light is perfectly fine for general purpose troubleshooting, and is highly recommended. However, for fuse substitution, a much larger lamp with lower resistance is desired. Otherwise, current flow will be limited.
What we are trying to do here is to allow as much current to flow as possible without damaging anything or melting wires. With both filaments of a standard headlight wired in parallel (about 110 watts worth), about 10 amps can flow into a short circuit. That's enough to power most bus electrical loads (except headlamps...)
Note that in the setup shown (and with a little modification to the connector), the lamp connector can be rotated 180 degrees, shedding the center lamp pin, thus reducing the short circuit current to 5 amps, if desired. _________________ '71 panel, now with FI
Tcash Samba Member
Posted: Fri Aug 22, 2014 10:37 am Post subject: |
A Circuit breaker of the correct amperage wired in place of the fuse works well too.
Posted: Fri Aug 22, 2014 12:24 pm Post subject: |
In this case, it's not very convenient. Until the short is cleared, the breaker will open instantly, giving little time to troubleshoot. The lamp will just light up, dumping limited current into the short. This allows troubleshooting (the lamp will go dim/dark when the problem is found). _________________ '71 panel, now with FI
Posted: Fri Aug 22, 2014 5:19 pm Post subject: |
Note that in the setup shown (and with a little modification to the connector), the lamp connector can be rotated 180 degrees, shedding the center lamp pin, thus reducing the short circuit current to 5 amps, if desired. |
I knew there was a reason. Just too lazy to analyze. Thanks for sharing your expertise and knowledge.
Aloha
tp |
Mike C Samba Member
Posted: Fri Aug 22, 2014 5:35 pm Post subject: |
Tom Powell wrote: |
Aloha
tp |
+1 _________________ Bone stock 1970 non-walkthrough "Station Wagon" bus
