356A with 741 transmission
ezvelarde
ezvelarde is offline
PostPosted: Sun Aug 17, 2014 10:45 am    Post subject: 356A with 741 transmission Reply with quote
Hi, I have a porsche 356A 1958, (T2A reutter) but the orignal transmission don't exist,,,,
I found transmission of a '63 (type 741),,,,,,
I can use this transmission in my car without problem?
I need any modification???
All transmisions can be used in any 356???
Greetings from Venezuela
Ezio Zambrano
My restoration 356A 1958
http://www.forocoches.com/foro/showthread.php?t=1113773&highlight=
ensys
ensys is offline
PostPosted: Sun Aug 17, 2014 10:54 pm    Post subject: Reply with quote
Mr.Zambrano:
Yes, the 741 can be used in the T2 A.
Basically, you need two parts: a 644 nose cone and shifter rod (hockey stick). These will allow the shift rod to connect properly to the (e)monkey-motion of the A.
Keep 'em flying...
S.J.Szabo
ezvelarde
PostPosted: Mon Aug 18, 2014 10:19 am    Post subject: Reply with quote
ensys wrote:
Mr.Zambrano:
Thank you very much,
I will seek both parts....
P.S. No need any modification to the body??'
Jacks
Jacks is offline
PostPosted: Tue Aug 19, 2014 11:21 am    Post subject: Reply with quote
You will have to change the 3 shift rails as well. Clutch release parts are different.
Jack Staggs
Actual name
