Bloku Expert Noob
Joined: April 09, 2013 Posts: 559 Location: Tulsa/Jenks Oklahoma
Posted: Sun Aug 17, 2014 6:03 pm Post subject: Fuel Pump Pumping Some Air FIXED |
The video says it all except that, that is a new pump that I got about 2 years ago. Also a brand new filter, lines (soft only) ,and a with a tank.
It could be that it is just cheap. I still have the original one, so I could buy a rebuild kit.
Also, sometimes after going down a road about 50 mph in 4th gear it will die when you go to a stop, but run perfectly other than that.
At first it was the belt flipping and not grabbing the generator, but I have a brand spanking new belt on so that is not the problem anymore.
_________________ 1971 Karmann Ghia
1975 Porsche 914
1975 BMW 2002
1976 BMW 2002 (Bored and Stroked w/ 5-Speed)
1981 BMW E21
1986 Toyota 4Runner (Dead engine and trans)
1989 Toyota 4x4 PU
1994 BMW E36 (Daily)
trbugman Samba Member
Posted: Sun Aug 17, 2014 7:06 pm Post subject: |
I had that style of pump, I would check what your fuel pressure is. Mine would lean out at freeway speeds. I swapped to another pump that I bought some 15 years ago for my bug with an alternator conversion kit and my Ghia now runs better.
Also put the fuel filter under the car by the trans or fuel tank. When they're in the engine compartment they are known to cause or accelerate fires in there. Fuel line takes a lot more heat to burn or melt through. _________________ 2333(103x70) Type 4 DTM MS3+X on 73 Karmann Ghia ignition only with LS2 truck coils firing in sequential, fuel next. |
Bloku Expert Noob
Posted: Mon Aug 18, 2014 1:25 pm Post subject: |
I need some help here..... Anyone? _________________ 1971 Karmann Ghia
1975 Porsche 914
1975 BMW 2002
1981 BMW E21
1989 Toyota 4x4 PU
1994 BMW E36 (Daily) |
c21darrel Samba Member
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Mon Aug 18, 2014 1:50 pm Post subject: |
Something isn't right. A filter half full or air is normal, but 95% air isn't. Either the pump is sucking up air from a break in the line, or there is a tremendous restriction in the inlet and it's pulling vaccum. It's hard to believe that it doesn't run the carb dry of fuel when cruising. Unless the pump delivers more fuel at higher rpms. Still, I would check for breaks in the fuel line running into the pump, and check for restrictions in the fuel line from the tank. Perhaps test the pump by running it from a jug of gas. _________________ 1958 Karmann Ghia owner |
carl4x4 Samba Member
Joined: March 20, 2012 Posts: 679 Location: United Kingdom
Posted: Mon Aug 18, 2014 2:28 pm Post subject: |
Check the oil, if it's higher than the last time you checked and smells of petrol, you've got a leaky fuel pump diaphragm. I'd second moving the fuel filter, and changing the flexible hoses from the hard line coming out of the frame horn, plus in the engine, plus the one under the tank. That eliminates any collapsed or problem flexi hose.
While you're at it you could check the state of the hard line going through the tunnel to see if it flows freely. I just blew mine through with a foot air pump with a container on the framehorn end, if it runs free then no blockage there.
The usual safety caveats apply to messing around with petrol obviously! _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
Bloku Expert Noob
Posted: Mon Aug 18, 2014 2:58 pm Post subject: |
I have new soft line, new tank, filter, and pump. When I got the car I blew through the line and a bunch of crap came out, but from then on it has been working fine.
After pulling out the dip stick and sniffing the oil, I can say that the problem is that the diaphragm is letting the gas go in the oil. I will be getting a new pump and a oil change.
Thank you to all who helped! _________________ 1971 Karmann Ghia
1975 Porsche 914
1975 BMW 2002
1981 BMW E21
1989 Toyota 4x4 PU
Bloku Expert Noob
Posted: Mon Aug 18, 2014 3:12 pm Post subject: |
'Tis, but not problem solved yet. Tomorrow, I will be getting a new pump from the Bughaus in Tulsa, so lets just see how it goes _________________ 1971 Karmann Ghia
1975 Porsche 914
1975 BMW 2002
1981 BMW E21
1989 Toyota 4x4 PU
Bloku Expert Noob
Posted: Wed Aug 20, 2014 8:12 pm Post subject: |
I got my new pump, and moved the filter under the wheel well.
The filter runs at only about 1/2 full still.... I have a half a tank full, so it makes sence .
All my lines are tight, and the pump is mechanical and not a cheapo Brazilian one.
Anyone have any ideas why I am only running half filter full?
Could it be that my car has a raked look (high back and very low front)? You said the pumps are weak.
Thanks _________________ 1971 Karmann Ghia
1975 Porsche 914
1975 BMW 2002
1981 BMW E21
1989 Toyota 4x4 PU
Posted: Wed Aug 20, 2014 9:57 pm Post subject: |
The filter having air in it is nothing to worry about. You will never get all of the air out of it. _________________ 2333(103x70) Type 4 DTM MS3+X on 73 Karmann Ghia ignition only with LS2 truck coils firing in sequential, fuel next. |
Bloku Expert Noob
Posted: Thu Aug 21, 2014 5:00 pm Post subject: |
Thanks. Now she is running like a top! No stalls of random to even speak of! Thanks again everyone! Who would think one pump would fail in so little miles and time! It just shows that cheap is not always better. _________________ 1971 Karmann Ghia
1975 Porsche 914
1975 BMW 2002
1981 BMW E21
1989 Toyota 4x4 PU
