scottmc Samba Member
Joined: January 10, 2014 Posts: 197 Location: patchogue ny
Posted: Sun Aug 17, 2014 8:55 pm Post subject: Rustoleum paint job |
So i painted my bug with rustoleum this weekend. Before everybody jumps on me about doing it with auto paint. ... I've never used a spray gun before and didn't know how it would turn out. With this I said well $500 worth of paint primer gun or 125$ total. Gun to paint and sand blocks. I'm impressed with my ability to lay paint. Kind of wished I used the right paint now but my body work isn't up to my liking. I'm my own worst critic. I knowi need another coat bit should I wet sand now or after. I thinned it50/50 with acetone and the dash looks like glass but the body shows the imperfections . I'm thinking thin it even more and it should fill the small spots and sand the major before the next coat. My steps were strip all moldings cut all weatherstripping around windows and sand with 220 on a da spot prime and shoot color. Overall or looks good but not great so should I sand now or after 2nd coat. |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Mon Aug 18, 2014 11:08 am Post subject: |
Check the can to see about top coating & when. You could end up with a big wrinkled raisin if you are not careful. The issue with some of these products is they are designed to be applied & left. I understand the want to be perfect, (you might have thought that way from the start). Try a small test spot to see if it will take another coat. Take a little of your reducer on a rag and wipe a small spot, if it shows color the paint is not cured enough for you. Hope this helps. I would use 400 wet & try not to over thin the paint, it might try to lift off what you have on there. PM me if you want more help |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Mon Aug 18, 2014 12:54 pm Post subject: |
That's a lot of thinning 50/50 with acetone. I have sprayed some Tremclad, which is the Canadian equivalent, and I thinned it at most 25% with lacquer thinner. _________________ 1958 Karmann Ghia owner |
Posted: Mon Aug 18, 2014 7:46 pm Post subject: |
Yeah it was a lot but it layed out super smooth and dried real quick. Today was mid 70 and low humidity so I did 2nd coat. Came out great. Going to let it harden for at least a week before I touch any thing on it. I'm dying to drive it againbut don't want to rush it. I will never paint a car again. This was a total pain in the ass. Rebuild the motor, sure. Rebuild the transmission sure. Rebuild the brakes front end whatever sure. Paint a car f no. Divorce and paint jobs are expensive because they are worth it. |
kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Mon Aug 18, 2014 11:56 pm Post subject: |
Where are the pics!? _________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
Posted: Tue Aug 19, 2014 6:24 am Post subject: |
Just loaded pics to my gallery |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Tue Aug 19, 2014 9:22 am Post subject: |
Not a fan of non original color that came on the car, but that seemed to turn out pretty damn decent. Good job man. You spraying a clear over it? _________________ Gotta give my props to:
Dubbers Toy Box
4inbore.com
Posted: Tue Aug 19, 2014 10:15 am Post subject: |
I probably should being it's rustoleum after all. If I wet sand it flat then clear coat then wet sand it again and polish it should be pretty close. Grainger sells rustoleum clear 39$ for a gallon. I figure I should stick with rustoleum so I don't have any issues with the paint not taking to the clear. I'm going to post more pics of the car out doors. Still can't figure out how to tie them to my post though. |
vwkirb Samba Member
Joined: January 16, 2007 Posts: 812 Location: Athens, GA
Posted: Tue Aug 19, 2014 3:55 pm Post subject: |
Look into putting hardener into rustoleum. I've been messing around with that, and it seems to work pretty well. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17968 Location: Eugene, OR
Posted: Tue Aug 19, 2014 5:20 pm Post subject: |
scottmc wrote: |
Open your picture & copy/paste the Forum Code: with the (img) on each end. You can also Preview your post before you Submit it to see what it will look like. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
irun5k Samba Member
Joined: February 21, 2014 Posts: 335 Location: St. Petersburg, FL
Posted: Sun Aug 24, 2014 9:39 am Post subject: |
That looks a lot better than I was imagining when I read the first post. To go to all that work, I agree, it is too bad you didn't use a 2K paint, be it single stage or base + clear.
*If* you could use a 2K clear on top, you'll get a lot more durability and wouldn't have to worry about stuff like a drippy gas nozzle ruining your paint job.
Maybe you could do a test on something to see if it would work. |
GraysonM Samba Member
Joined: July 17, 2013 Posts: 98 Location: United States
Posted: Sun Aug 24, 2014 8:15 pm Post subject: |
Looks rad! How much prep did you have to do? |
Posted: Mon Aug 25, 2014 6:22 am Post subject: |
Car had no rust. Big plus. Very little body work needed. Bigger plus. Replaced engine cover and rear fender for $40. Another plus. Totally stripped down car to shell. Used random orbit with 220 grit to knock down what shine was left then sanded whole car with foam sanding blocks from depot. Spot primed filler and bare spots with rattle can. Wiped whole car down with acetone and sprayed away. I already have the new window seals. Need to order a body gasket kit from jbugs and get a new windshield. I broke it removing it. Still want to do another coat before assembly and possible clear |
Posted: Mon Aug 25, 2014 8:11 am Post subject: |
Put 3 coats of that $39/gallon clear on it or you will regret it! _________________ https://imgur.com/user/FisherSquareback/posts
bvd Samba Member
Joined: September 17, 2010 Posts: 207 Location: Long Island, New York
Posted: Wed Sep 03, 2014 9:13 pm Post subject: |
Looks good in the photos, but please, be careful and make sure the clear is compatible before doing anything!!! If it's not compatible it could wrinkle or ruin the finish. Rustoleum cures from the outside inwards through solvent evaporation, so just spraying something over it may trap in those fresh, uncured solvents. DEFINITELY DO NOT SPRAY A CATALYZED CLEARCOAT OVER THE RUSTOLEUM. This would likely cause a compatibility disaster, as a catalyzed paint should only be sprayed over a known cured surface (oem or cured urethane auto paint)
Even though the Grainger Clear Coat you mentioned says Rustoleum on the can, the clear might be part of a different system of Rustoleum paints, perhaps their industrial line or something like that (they make a lot of products besides the ubiquitous rattlecans and quart/gallon cans you find at home depot).
Take a look at this thread from the "Jalopy Journal" Forums for further details about clear coating Rustoleum: http://www.jalopyjournal.com/forum/threads/clear-coat-rustoleum.381388/ _________________ "I paid 2000 for my MR2 with the back quarters rusted out, 900 for the bug. So rice is more costly than kraut."--doc1369 |
peteandvanessa Samba Member
Joined: July 01, 2009 Posts: 931 Location: Sacramento
slagathor Samba Member
Joined: December 08, 2012 Posts: 253 Location: Oakland, CA
Posted: Tue May 12, 2015 9:50 am Post subject: |
looks good peteandvanessa
below are picture of my 73 standard with rustoleum paint job, sunrise red, with a clear coat
a couple layers of sunrise red (sanded a few high spots) and a couple more of clear coat. wet sanded the clear coat with 1200 grit and them used meguiars ultimate compound then waxed the whole car
even with dirt on it, it still shines
VW_Buggsy Samba Member
Posted: Tue May 12, 2015 10:01 am Post subject: |
Thanks for these posts folks, this looks like a perfect plan for my beater bug. I don't want to invest a ton on paint but it would be nice if it were all one color. |
Posted: Tue May 12, 2015 10:50 am Post subject: |
8 months and I still haven't wet sanded mine. It did dry rock hard though. If anybody else is planning this and wants to mix colors to create a custom, make sure you keep a record of your ratios. I believe mine was 7 parts royal blue and one part silver. Also could be navy blue, I am sure the home depot by me only sells one of them in quarts so it should be easy to find out. Unless they sell them both now. |
