Boo-Koo-Z Samba Member
Joined: February 03, 2004 Posts: 437 Location: Tri-cities … South Eastern Washington State USA
Posted: Sun Aug 17, 2014 9:04 pm Post subject: Project Black 55 Vert |
I've been itching to build an early vert. When I first set out on the search I was looking for 58-63 but what I came across is this 1955. This 55 Body was switched some 25+ years ago to its donor pan.. IRS 1970 so I know that is not correct but I'm completely OK with that. Every car I build is a custom so when I found this one I was pleased to snag it up as I wouldn't feel terrible switching things up with custom suspension and a cool new look. The body work and paint was done some 20+ years ago and the car was tucked away and never finished. I purchased it just like this minus the wheels. I've never built an early vert so this will be a major learning lesson. Below are the pics of my inventory session of what came with the car and I'm hoping if any of you knowledgeable folks see something that is the wrong year or wrong about this car let me know as I'm stepping into this one blind.
Here are a couple things I noted...
Front fenders don't have bullet turns or drain tubes under neath
Pan is obviously 4 lug and there are adapters on there right now
Plan is to change to 4 corner disk brakes so no biggie
One headlight is different than the other not sure which would be correct
P.O. said that one of the chrome window sashes was from a later car??
Anyways let me know what you think and if you can offer some identification of parts and whatnot.
Joel
_________________ 64 N Model Notch,65 OG White Notch
65 Squareback
55 Vert Bug, 62 gulf blue patina bug
Desert Fox Spoiler Buggy
60 crew cab, 64 21 Window Deluxe Bus clone
63 OG Manilla yellow Ghia
73 Thing |
Posted: Sun Aug 17, 2014 9:09 pm Post subject: |
65 Squareback
73 Thing |
Posted: Sun Aug 17, 2014 9:12 pm Post subject: |
65 Squareback
73 Thing |
jason Samba Member
Posted: Sun Aug 17, 2014 10:20 pm Post subject: |
Hood crest, hinge covers, large fuseblock and headlight starting with sb19 is wrong year. I don't remember the cut off for the ribbed verses non door handles. I think because you have over rider holes the non ribbed. Maybe someone else can chime in. Most of your parts are correct except what you mentioned. |
Posted: Sun Aug 17, 2014 10:32 pm Post subject: |
Figured the hood crest was wrong as it's the same that is on my 62 what should it look like? _________________ 64 N Model Notch,65 OG White Notch
65 Squareback
73 Thing |
ovalcr Samba Member
Joined: November 30, 2008 Posts: 55 Location: San Jose, Costa Rica
Posted: Sun Aug 17, 2014 10:36 pm Post subject: |
looks very nice, congratulations !! |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Sun Aug 17, 2014 11:04 pm Post subject: |
#1, Get rid of those plastic hood spring covers, you're car should use a hood prop.
#2, The hi/lo switch will work (it's a 1956-60 style), but a pre '55 would be round shaped
#3, the brake reservoir is a 1956-60 style. A 1953-55 type is attached with bolts
_________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Sun Aug 17, 2014 11:13 pm Post subject: |
Good news, You have the proper 1953-55 deck lid. So the small 1956-60 spring wont work for you.
What a great car. And that paint still looks great after all those years being tucked away. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4573 Location: St Charles, MO
Posted: Mon Aug 18, 2014 9:12 am Post subject: |
RareAir wrote: |
#1, Horn is Hella circa 1961-67
#2, You only need 1 exhaust tip (if you are running a 36hp)
#3, rear view mirrors looks to be 1958-64 |
Those "tailpipes" are Split-Bus tailpipes (one-year-only for the 1959 model year 36hp engine). You should be able to sell those in the classifieds. You need a longer single straight Beetle tailpipe (up through Aug 1955 style) if you'll be running a "correct" 36hp engine. Something tells me you won't be though...
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
davetaylor Samba Member
Joined: May 24, 2006 Posts: 218 Location: Hawesville, KY
Posted: Mon Aug 18, 2014 8:57 pm Post subject: |
I'm betting the front fenders are aftermarket and just didn't have holes cut for any signals. The shape around the headlights looks flatter than it should be, plus I've had several front fenders just like those that never had any holes. _________________ 1954 3-fold ragtop Beetle project
1969 Porsche 912 (sold)
1979 Beetle triple white German Look convertible
1980 Porsche 911 SC Targa (sold) |
Posted: Mon Aug 18, 2014 11:54 pm Post subject: |
Thanks for all the helpful notes. I was thinking the same thin for the front fenders. For the tailpipes you right I'll be listing them up as I'll likely be putting a stroked motor in it.. only time will tell. Here are a couple items I have no clue on where they go...
These clips I have no clue..
On these switches.. are the ones on the left wiper and don't know what the ones on the right would be. Also where should their proper location on the dash be?
The oh crap handle doesn't have an insert in it.. is it supposed to be rubber and what to do here are there aftermarket options?
On the side of the backrest arm there is two screw holes.. any idea?
65 Squareback
73 Thing |
left_coast*9 Samba Member
Joined: March 02, 2009 Posts: 740 Location: Puyallup, WA
Posted: Tue Aug 19, 2014 10:05 pm Post subject: |
Thanks.. Not to get ahead of myself or this thread but these are my two top choices for wheel selection.
Also back to the deck lid spring comment... what should the correct spring look like?
65 Squareback
73 Thing |
Posted: Wed Aug 20, 2014 1:54 pm Post subject: |
Boo-Koo-Z wrote: |
The switches on the Right are your interior light switch. Mounted under the dash, just the Left of the steering column. Car only requires 1 _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Wed Aug 20, 2014 4:00 pm Post subject: |
Good stuff thanks _________________ 64 N Model Notch,65 OG White Notch
65 Squareback
73 Thing |
Posted: Tue Nov 25, 2014 12:11 am Post subject: |
I've been accumulating some bits and pieces to start the build and it's time to start thinking about top and interior. I'm wondering if some of you Northwest guys have a shop to recommend for the Vert Top Installation. Also would consider allowing the shop to tackle the interior as well if the price is reasonable.. but the top is something I definitely don't want to tackle myself. Thanks _________________ 64 N Model Notch,65 OG White Notch
65 Squareback
73 Thing |
