Erik G Samba Member
Joined: October 16, 2002 Posts: 13278 Location: Tejas!
Posted: Sun Aug 24, 2014 9:02 am Post subject: |
TMI Products wrote: |
Seems to be running great and not hot |
excellent |
vwfye Samba Member
Posted: Mon Aug 25, 2014 8:28 am Post subject: |
Nice job!
Make sure you have your charging idiot light when the key is to the on position. If it is burnt out, you will not get any charging to the battery! _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
TMI Products Samba Member
Joined: February 14, 2014 Posts: 744 Location: Corona, Ca
Posted: Mon Aug 25, 2014 9:14 am Post subject: |
vwfye wrote: |
Nice job!
Make sure you have your charging idiot light when the key is to the on position. If it is burnt out, you will not get any charging to the battery! |
the light is on constantly _________________ Mario De Leon
1965 Turbo Mustang Fastback
1966 Type 3 Fastback
VW Division Sales Manager
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
vwfye Samba Member
Posted: Mon Aug 25, 2014 9:40 am Post subject: |
ah... VR could be bad. You can check the voltage right off the generator to see if it is the Gen or the VR. _________________ 64 No'back Speedster "Pearl"
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Mon Aug 25, 2014 9:44 am Post subject: |
With the engine running, use a wooden stick to push on the generator brushes, to make sure they're seated and making contact with the commutator. Also make sure the commutator is clean and shiny.
When I bought my Square the brushes had just been replaced, but after about a month the commutator got dirty and the light came on. Turned out the brushes were some really soft compound that clogged the slots in the commutator. A good cleaning and some new brushes and it was just fine. _________________ 71 Elm Green FI A/T Squareback |
Posted: Mon Aug 25, 2014 9:51 am Post subject: |
vwfye wrote: |
ah... VR could be bad. You can check the voltage right off the generator to see if it is the Gen or the VR. |
it looks new(er), but no telling since this car hasn't been on the road since 98. With a little poking around and not actual testing im thinking its bad too. It has 12V in, but not out.
i'll do some more wire tracing and try to get some actual numbers. _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34009 Location: Conejo Valley, CA
Posted: Mon Aug 25, 2014 12:29 pm Post subject: |
Donnie strickland wrote: |
When I bought my Square the brushes had just been replaced, but after about a month the commutator got dirty and the light came on. Turned out the brushes were some really soft compound that clogged the slots in the commutator. A good cleaning and some new brushes and it was just fine. |
Another cause of failure after replacing brushes is a worn commutator without the needed grooves between contacts:
Posted: Mon Aug 25, 2014 8:45 pm Post subject: |
battery voltage (12.3V) at the B+ terminal at the regulator and im getting about 4V at the D+ wire at the generator _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Tue Aug 26, 2014 5:54 am Post subject: |
battery voltage (12.3V) at the B+ terminal at the regulator and im getting about 4V at the D+ wire at the generator |
Do you have a Bentley? Either Brown or Blue? If so, the generator testing proceedure is in it. It's also in the bug version of the Bentley as well.
But, for a quick test, you can pull the belt off (disconnect the battery 1st), and hook up a set of jumper cables to the generator (neg terminal to ground, battery + to the D+ post, the generator should turn over like a motor. If it doesn't, you'll need to remove the generator and go thru it.
I only say that, as I've found that IF it won't run like a motor (polarizing test), then there's usually something wrong with the generator itself. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Aug 26, 2014 11:19 am Post subject: |
Bobnotch wrote: |
I only say that, as I've found that IF it won't run like a motor (polarizing test), then there's usually something wrong with the generator itself. |
I do have a Bentley, thumbed through it a few times already.
So there's 4 wires at the regulator,
one from the battery
one to the generator, D+
one to the idiot light
and one from DF to DF
which wire sends voltage back to the battery from the generator? _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Erik G Samba Member
Posted: Tue Aug 26, 2014 12:11 pm Post subject: |
B+ on the regulator D+ on the Gen
Posted: Tue Aug 26, 2014 1:14 pm Post subject: |
so if I unplug D+ at the generator and get 4V, is that a generator issue? I get 0V at D+ on the regulator. _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Posted: Tue Aug 26, 2014 6:12 pm Post subject: |
so if I unplug D+ at the generator and get 4V, is that a generator issue? I get 0V at D+ on the regulator. |
You'll have to ask someone smarter than me. I know IF you remove the belt and the existing wires from the generator, and use a set of jumper cables, you can make the generator spin like a motor, or it won't do anything. If it's the later (not doing squat), then it needs rebuilding. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Aug 26, 2014 8:57 pm Post subject: |
I didn't test the generator yet,but I did replace the regulator. The light is now dimly lit with the key in the off position. When I start the engine and light does not come on but the battery isnt charging either.
I guess i will take the generator off tomorrow and replace the brushes and test it _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Posted: Thu Aug 28, 2014 11:19 am Post subject: |
got tired of testing things, so I got this
I need it anyway for the stereo system I plan and other electrical things. _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
vwfye Samba Member
Posted: Thu Aug 28, 2014 1:04 pm Post subject: |
remember to bypass that regulator! _________________ 64 No'back Speedster "Pearl"
Posted: Thu Aug 28, 2014 1:59 pm Post subject: |
vwfye wrote: |
remember to bypass that regulator! |
yup, im taking the one I just bought back, 33 bucks back into my wallet! _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
catbox Samba Member
Joined: May 16, 2007 Posts: 865 Location: Portland, Oregon
Posted: Thu Aug 28, 2014 2:19 pm Post subject: |
Where did you get that one from? _________________ "...these cars were preferred by the racers because the strut front suspension results in far superior handling than the regular torsion bar front end..." - Keith Seume. |
Posted: Thu Aug 28, 2014 2:58 pm Post subject: |
catbox wrote: |
Where did you get that one from? |
CB Performance _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Posted: Thu Aug 28, 2014 8:11 pm Post subject: |
The kit took about a hour to install, would've been quicker if it came with instructions. One of the studs has to be removed and replaced with a bolt for the bracket.The battery now reads 14.0V at idle and about 14.5 at about 2000 rpm.
As far as "drivability" issues, I think im done.only thing left is a couple of trim pieces and some interior stuff.
What do I do after it s done??? get another project and start over? _________________ Mario De Leon
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
