A crazy but serious idea
strelnik
strelnik is offline
PostPosted: Mon Aug 18, 2014 11:20 am    Post subject: A crazy but serious idea Reply with quote
I have been looking at the accesses in the Thing rear (engine) compartment and I started to wonder:
Has anyone ever just cut the back off and hinged it on, for easy access? Or cut it off and screwed or pinned it back on?
It seems that if there were quick disconnect lines on the lights, the rest would not be that bad, especially with a little planning.
there was a TR-7 in which the entire front clip hinged forward to service anything on the engine or trans.
Just wondering if that wouldn't be a mod adding to serviceability AND coolness?
L'audace! L'audace! Toujours l'audace!
doublecanister
doublecanister is offline
PostPosted: Mon Aug 18, 2014 11:24 am    Post subject: Re: A crazy but serious idea Reply with quote
and one with a "tilt" open no doubt! LOL
That would be cool!
the only mod I have seen is the one Sam has on his THING where the area
below the engine lid can be removed with the bumper.
draw it up!
Popcorn
T
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8
Jonny Rock
Jonny Rock is offline
PostPosted: Mon Aug 18, 2014 12:44 pm    Post subject: Reply with quote
I think the lower apron "bolt on" mod is a better answer. It makes the removal/installation considerably easier, as the vehicle does not have be raised as high to clear the apron.
I have not performed the apron mod on my Thing, but I performed the mod on my Oval. I believe that it is a common mod on the early Buses too.
Turk.380 Premium Member
Turk.380 is offline
PostPosted: Mon Aug 18, 2014 1:21 pm    Post subject: Reply with quote
early Type II's (and late up to '71 I think?) had bolt-on aprons from the factory.
Brian W
St. Louis, MO
'64 SO-33 Hatch Top Westy | '87 Syncro Westy: Subaru EZ30D powered | 2002 VW Winnebago Vista
GI Joe
GI Joe is offline
PostPosted: Mon Aug 18, 2014 1:40 pm    Post subject: Reply with quote
I did the remove able apron, with hidden hardware... Made engine install a breeze, and saved the paint work from getting banged up(on tin And body)..
Check my thread below for pics... Wink
'74 Thing, "Our Thing"....Blue 181
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember
Jonny Rock
PostPosted: Mon Aug 18, 2014 1:47 pm    Post subject: Reply with quote
You are probably correct. I have never owned a bus or removed an engine from one, so I do not have any first hand experience. I imagine the change came with the Type IV engine.
Jonny Rock
PostPosted: Mon Aug 18, 2014 1:53 pm    Post subject: Reply with quote
Looks like it is pretty straightforward.
GI Joe
GI Joe is offline
PostPosted: Mon Aug 18, 2014 2:48 pm    Post subject: Reply with quote
Yessir!! Those tabs slide up under the rear sheet metal and bolts go through from the inside out(nothing showing on outside of sheet metal, aside from the seam. One wide tab per side, with two bolts each for the horizontal surface.
'71 Beetle RPU
www.NLEOMF.com
citroen
citroen is offline
PostPosted: Mon Aug 18, 2014 8:53 pm    Post subject: Reply with quote
this might work
GI Joe
GI Joe is offline
PostPosted: Tue Aug 19, 2014 5:56 am    Post subject: Reply with quote
That'll work Dennis!!? Shocked
@Strelnik, not having Our Thing close, I can't offer too much specifics, but I think it would be cool....
With the earmuffs on a '74, the seam could be hidden behind them(they stay attached to main tub) and then the portion rear of the firewall gets pulled rearward, or hinged Up... Either way would clear everything Very easily ...
You'd certainly get plenty of attention(good and bad) at the shows... I'd do it, but it'll have to wait till I get to my next redo of Our Thing..... That'll be a while!
'71 Beetle RPU
www.NLEOMF.com
strelnik
strelnik is offline
PostPosted: Tue Aug 19, 2014 6:07 am    Post subject: Reply with quote
[quote="citroen"]this might work
Dennis, that's a great idea, but wouldn't it require a hydraulic system to lift the body and then suspend it?
I don't thinbk I could use my Bilstein jack to do that!
GI Joe
GI Joe is offline
PostPosted: Tue Aug 19, 2014 6:12 am    Post subject: Reply with quote
[quote="strelnik"]
citroen wrote:
this might work
Two guys should be able to pivot it up, enough to have someone lock a retention bar that supports it raised..
'71 Beetle RPU
www.NLEOMF.com
strelnik
strelnik is offline
PostPosted: Tue Aug 19, 2014 8:31 am    Post subject: Reply with quote
[quote="GI Joe"]
strelnik wrote:
citroen wrote:
this might work
Hi Dennis,
The advantage to that system is great structural integrity. although it would be necessary to reinforce everything.
But how do you work the detaching of the body? The rest of the time, the body wou;ld be loose, or you'd have to have several main attaching points. There still would be a need for some type of up-front hinge. I think. .
The flip side-- my original thought-- was to hinge only the rear portion to provide access to the engine. Kind of a flip-up thing.
You have no idea how anxious I am to retire and start working on these full time!!!
Does anyone have contact info for the gentleman who owns this Thing?
GI Joe
GI Joe is offline
PostPosted: Tue Aug 19, 2014 8:46 am    Post subject: Reply with quote
There is a John a Tritle on Samba....
He may have sold the drag Thing though.....
http://www.thesamba.com/vw/classifieds/detail.php?id=1201840
Also, if you do the facebook, this came up on my quick search..
https://www.facebook.com/john.tritle.5
'71 Beetle RPU
www.NLEOMF.com
Ron Domeck
Ron Domeck is offline
PostPosted: Tue Aug 19, 2014 9:49 am    Post subject: Reply with quote
Try John at [email protected] Tell him Ron said Hi.
kubelmann
kubelmann is offline
PostPosted: Tue Aug 19, 2014 10:03 am    Post subject: Reply with quote
Herr K may have blown rear seal. If so, I will be doing this type of mod soon. That 1915 goes in n’ out of the Thing about like swapping out a space shuttle launch motor. Without the centre member would come out in one piece. That would be great.
strelnik
strelnik is offline
PostPosted: Tue Aug 19, 2014 1:04 pm    Post subject: Reply with quote
Needless to say, I would be interested.
strelnik
strelnik is offline
PostPosted: Tue Aug 19, 2014 1:05 pm    Post subject: Reply with quote
will do! tyvm!
GI Joe
GI Joe is offline
PostPosted: Tue Aug 19, 2014 5:24 pm    Post subject: Reply with quote
A little misleading angle in this pic, but this 1915 with duals will NOT come out, without carb removal...
Of course, with a full tail end removable, as proposed, you could leave whatever installed and yank it all out in short order! Lol
'71 Beetle RPU
www.NLEOMF.com
mr white
mr white is offline
PostPosted: Tue Aug 19, 2014 8:40 pm    Post subject: Reply with quote
On the topic title not a hi-jack! Roll cage. My thing happens to be in the featured ad for heavy duty repro nato guards for sale. The cage in it is sweet. However I cannot put the hardtop on it as it is. My thoughts are to cut it and use pins so to speak to secure it as it is in that pic and to bring it down and pin it in winter for the hardtop. Any input?? Maybe use sleeves of sorts?
