Skamenir Samba Member
Posted: Mon Aug 18, 2014 2:21 pm Post subject: 66 shifter problem |
Hi guys, finally got the gazelle insured so I could test drive it after the restoration . Only problem is with the shifter, can't downshift from 3rd to second , even double clutching. I replaced the shifter rod bushing, and coupler, during the restore, the shifter was removed, so I could not mark the location. In neutral, no problem, but once running, it's like the gate is gone. I have to go in and out of reverse to find first. Possibly a adjustment problem?
Thanks for any input
Steve |
Posted: Tue Aug 19, 2014 8:36 am Post subject: |
Went on road trip, adjusted shifter for and aft, till it shifted like butter. Now I'm a happy camper! |
Mike Sal Samba Member
Joined: May 28, 2014 Posts: 195 Location: Southern Illinois
Posted: Wed Aug 20, 2014 10:59 am Post subject: shfting |
I'm about to change the front bushing, as the old one isn't even in the bracket anymore.
Are the holes in the shifter / gate large enough to allow adequate adjustments, or do you need to open them up sometimes?
thanks,
Mike S |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Thu Aug 21, 2014 8:37 am Post subject: |
If you mean the holes in the shifter tower, yes they should be large enough for adjustment. I've never come across a stock shifter that needed the holes to be enlarged for it to be adjusted. The bolts should have a flat washer under the heads to cover the hole and spread the load. Since you'll have to be there anyway, you should have a close look at the rear coupler. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Posted: Thu Aug 21, 2014 12:43 pm Post subject: |
Remember to tie a string around the shift tube, thru the bushing, not so bad on a stocker, but the gazelle shift tube is only about 2 feet, what a pita. |
