Solex 28 PCI on 1200c 34hp engine
Bugfreak88
Bugfreak88 is offline
PostPosted: Tue Aug 19, 2014 7:38 am    Post subject: Solex 28 PCI on 1200c 34hp engine Reply with quote
Can anyone tell me if I need to adjust original carbs (28 pci) to use them on a dual carb Riechert kit?
I bought them seperatly and mounted them with the Riechert linkage and manifolds. Now the engine won't start
bdub475
bdub475 is offline
PostPosted: Tue Aug 19, 2014 11:31 am    Post subject: Reply with quote
I would think they need to be gone through rebuilt and re-jetted.
Bugfreak88
PostPosted: Tue Aug 19, 2014 11:41 am    Post subject: Reply with quote
What do you mean rejetted?
bdub475
bdub475 is offline
PostPosted: Tue Aug 19, 2014 5:46 pm    Post subject: Reply with quote
If you bought two carbs that were used in single carb applications then each would have jets to supply enough fuel and air for 4 cylinders each. Now you have each carb only supplying 2 cylinders. So I would assume they would be running very rich as they are.
henry roberts
henry roberts is offline
PostPosted: Mon Sep 01, 2014 4:15 am    Post subject: Reply with quote
a little late here, but "making the Volkswagen go" lists the jetting for twin 28PCI's on an express twin carb kit on a 36hp as:
venturi 21.5mm
main jet 105
air correction 200
idle 50
idle air bleed 1.2
E tube 8
acc pump per stroke
.25 to .30cc
not exactly what you need, but it might point you in the right direction.
SpeedUp
SpeedUp is offline
PostPosted: Sun Oct 12, 2014 7:40 am    Post subject: Dual PCI Carbs with 23.5 Venturi question Reply with quote
Hi to everyone
I am trying to find out the right configuration for dual Solex PCI with 23.5 venturis for my 36 hp.
I don t want an engine for races but a good engine i can use at week end, at low, middle and little high RPM sometimes only.
My project is a 36 hp with 77 mm domed pistons, compression ration 8:0, Heads with 3 angle valve, original 64 mm crank, lightened flywheel, Denzel Full Flow Canister, high volume pump, 010 Bosch, Retwish intake manifolds with dual PCI.
Is anyone knows the right jets configuration i must have for dual PCI with 23.5 venturis for my engine ?
