Motor60 Samba Member
Posted: Wed Aug 20, 2014 11:58 am Post subject: 1776, what size header?? |
I have a 1776 built with Mofoco 050 heads (42 intake / 37 exhaust valves). Don't know the cam size. Want to install merged header. Would 1 5/8 be too big? Or 1 1/2" ? Daily driver |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Wed Aug 20, 2014 12:17 pm Post subject: |
With heads that big you should run the 1 5/8. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Joe Bence Samba Member
Joined: March 14, 2004 Posts: 501 Location: San Diego, CA
Posted: Wed Aug 20, 2014 12:57 pm Post subject: |
1 1/2
tell us more about your 1776 |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Posted: Wed Aug 20, 2014 1:53 pm Post subject: |
Jfats is actually right, but for such small displacement a 1½" header would most likely do well. - Unless youre planning peak performance above 7 grand.
T |
57 Rag Samba Member
Joined: October 24, 2006 Posts: 1145 Location: Paradise
Posted: Wed Aug 20, 2014 2:41 pm Post subject: |
Yep. Being that it's a small displacement and a daily driver I'd go with the 1 1/2. All the engines I've had up to 2074 I've ran 1 1/2 inch headers. Hell my engine now only has 1 5/8. I'm assuming that you got the engine from someone else?? Just wondering what size cam is in there and why so big on the valves. Are the heads P&P'd??? _________________ 57 Ragtop
84x94 86C
IDAs |
Posted: Wed Aug 20, 2014 2:54 pm Post subject: |
It's a mofoco 1776 pro street. I'm third owner of this bug since the install. Whatever cam comes in that motor is what it has. 8 to 1 compression. If 1 5/8 will do, then I'll get those unless someone says it's bad idea. It's my daily driver |
57 Rag Samba Member
Posted: Wed Aug 20, 2014 2:56 pm Post subject: |
why dont you pop off the oil pump cover and take a look?? What kinda carbs you plan on running on it?? Those heads are way too big for that engine IMHO. We just used to run some cleaned up P&P'd stock heads here with a good 3 angle job on those. Just dunno how you gonna keep up intake speed. Im really wondering what the original engine builder was building it for being that the compression is only 8:1 as well. Sorry guys just thinking out loud. _________________ 57 Ragtop
84x94 86C
IDAs |
Posted: Wed Aug 20, 2014 3:09 pm Post subject: |
I didn't know I could do that. Going to install dual 40 idfs. What is the con of using 1 5/8? |
Posted: Wed Aug 20, 2014 3:28 pm Post subject: |
FYI I've been running this motor with a single H30/31 carb without issue. Runs good on fwy too. Idles fine. Going to dual 40s now and looking to upgrade exhaust from a bug pack quiet pack with regular header. |
Posted: Wed Aug 20, 2014 4:04 pm Post subject: |
1.5" or 1 5/8 ??? |
RailBoy Samba Member
Joined: March 10, 2008 Posts: 2904 Location: Virginia
Posted: Wed Aug 20, 2014 4:09 pm Post subject: |
Do you want heat? Dansk does one with 1 1/2 inside diameter heater box which is bigger than stock....Kymco RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
Posted: Wed Aug 20, 2014 4:11 pm Post subject: |
Taking out heater boxes for J tubes. |
Posted: Wed Aug 20, 2014 4:20 pm Post subject: |
Anybody? |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Wed Aug 20, 2014 5:00 pm Post subject: |
For a daily-drive, fit the smallest 'extractor' type exhaust you can find to give that small engine all the help you can with gas velocity and torque/drivability |
Posted: Wed Aug 20, 2014 5:27 pm Post subject: |
Anybody else wanna chime in? Called mofoco but no answer. Figured they could recommend a size since it's their motor. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Wed Aug 20, 2014 5:46 pm Post subject: |
Mofoco's 42x37s have such mild porting that they're basically a GOOD set of 40x35s. I'd run a 1 1/2 inch unless the cam has over 260 degrees at .050. |
Posted: Wed Aug 20, 2014 7:40 pm Post subject: |
Kymco or Bugpack? |
Posted: Wed Aug 20, 2014 7:48 pm Post subject: |
Just a preference thing. Kymco doesn't churn out as many as BugPack, so the coating and weld quality might be better with Kymco. Also Kymco's are made in the U.S. |
Posted: Wed Aug 20, 2014 7:50 pm Post subject: |
Since my motor is "small displacement" what do you guys think about installing a Tri-Mil 2-tip ceramic coated. How would that decrease or increase power? I still have my heater boxes installed |
Posted: Wed Aug 20, 2014 8:12 pm Post subject: |
You should not run a 37mm exhaust valve with stock heater boxes. Take them off immediately. Too much heat build-up will overheat the exhaust valves causing some sort of damage. A cheap Tri-Mil will not do much for your engine either. No cutting corners. You have a high performance engine. Either sell it, and bolt all that stock stuff on a stock engine or step your game up. |
