57 Rag Samba Member
Joined: October 24, 2006 Posts: 1145 Location: Paradise
Posted: Wed Aug 20, 2014 9:56 pm Post subject: |
Dude I'd stay away from both of them. U get what u pay for. Go get Scat ceramic coated headers. Been using them for the past 6 years nd I haven't even seen one that comes close! They sub it out to AL's headers and the fit is perfect and it's a thing of beauty. And for the last time 1 1/2! _________________ 57 Ragtop
84x94 86C
IDAs |
Motor60 Samba Member
Posted: Wed Aug 20, 2014 10:33 pm Post subject: |
But I thought ONLY scat mufflers fit on scat headers??? |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15307 Location: Deep in the 405
Posted: Thu Aug 21, 2014 5:56 am Post subject: |
Bugpack make a very good quality exhaust. Get the 1 1/2" and Hide-Out muffler. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
vincent9993 Samba Member
Joined: November 09, 2006 Posts: 2025 Location: Montreal
Posted: Thu Aug 21, 2014 7:11 am Post subject: |
For what's it's worth, we run a 1-1/2 sidewinder on our 1776:
- 69mm Counterweighted Crankshaft
- Ported and Polished L3 Heads
- Light Flywheel (10lbs)
- Full Flow Oiling System
- Dual 40 IDF Weber
- 110 Cam
- 8.5:1 CR
We have almost 30,000 miles on that setup and has good power. |
bpritchert87 The Idea Man
Joined: February 26, 2007 Posts: 1507 Location: Wisconsin
Posted: Thu Aug 21, 2014 7:47 am Post subject: |
Here is a reference I have found... Just FYI.. I would stick with 1 1/2" like everyone else has mentioned...
I believe this is from an "Older" hot Vw's article I believe _________________ Knowledge is Power Read and Learn !!!
The Intelligence of a Man should not be measured by his age....
check out my sand rover t bug build! http://www.thesamba.com/vw/forum/viewtopic.php?t=287204 |
Posted: Thu Aug 21, 2014 8:26 am Post subject: |
That's a cool chart! Nice find. |
Posted: Thu Aug 21, 2014 8:32 am Post subject: |
If it idles fine with a 30/31 the cam is puny (Eg: Engle 100 or smaller). So it will run fine with a 1 3/8 or 1 1/2". Going larger will create a mismatch. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Thu Aug 21, 2014 9:51 am Post subject: |
Just found out that my heads are probably 042 heads in a 050 casting. So I might have the 40 x 35.5 valves. And my cam is a hydraulic grind one above stock. Emailed mofoco to see if it's equal to a engle 110. |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Thu Aug 21, 2014 10:03 am Post subject: |
Well, that changes things. So yea a 1.5 is the biggest. Mofoco heads are normally off the shelf as cast, unported. I cant stand not knowing what In an engine, so I would pull the oil pump and heads to look. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Posted: Thu Aug 21, 2014 10:52 am Post subject: |
Like I said, it's not equivalent to a 110 because it would not idle well with the 30/31 if it had that much duration. It's a small cam, and you should go small on the exhaust to match it. _________________ It's just advice, do whatever you want with it!
smitty24 Samba Member
Joined: April 28, 2008 Posts: 2723 Location: Salem, Oregon
Posted: Thu Aug 21, 2014 12:53 pm Post subject: |
and get some real carbs on that engine while you are at it! |
Posted: Thu Aug 21, 2014 7:14 pm Post subject: |
Looks like my cam is equal or comparable to a W100. But in a hydraulic motor. Is this can too small? Sounds like everyone agreed on 1.5 headers. And dual 40s will be installed this week |
mark tucker Samba Member
Posted: Fri Aug 22, 2014 6:48 am Post subject: |
I would use the 1.5 max with that cr. but if you ever decide to go big you will need a new header too, but there cheep so just go with the 1.5 now or bump the cr to about 10.:1,.040 piston to head clearance,check cam&rocker may need to add some ratio&springs. it will run good but then theres runs better!!!so choose wizely as your pocker&butt dyno readout tell's you to do. |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Fri Aug 22, 2014 10:19 pm Post subject: |
So now that we know I have the smaller valves, would the Tri-mil 2-tip exhaust be too restrictive? Looking for loud throaty sound. Anybody know anything about the vintage speed mufflers? |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2388 Location: Seekonk,Massachusetts USA
Posted: Sat Aug 23, 2014 7:15 am Post subject: |
Motor60 wrote: |
Vintage speed mufflers are bigger then,1-3/8 inch outside diameter. Not made for stock engines. _________________ Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan |
Posted: Sat Aug 23, 2014 10:25 am Post subject: |
Ok but the 38mm is equal to a 1.5" header. Why wouldn't it work? |
Posted: Sun Sep 21, 2014 7:40 pm Post subject: |
Anybody see anything wrong with running a 1 3/8 J-Tubes and header with 35.5 exhaust valves? |
