rabbitmania Samba Member
Joined: March 14, 2013 Posts: 81 Location: Ontario Canada
Posted: Wed Aug 20, 2014 2:57 pm Post subject: How many hours to do clutch |
I recently took my '62 Beetle with a 1600dp in for a clutch replacement and not only was it in the shop for a month, I was charged 12.95 hrs to do the job.
What do you think of that? Does that seem right? |
aircoolnut Samba Member
Joined: July 23, 2006 Posts: 157 Location: Spanaway, WA
Posted: Wed Aug 20, 2014 3:11 pm Post subject: |
Time to find another shop. I would say 4 hours tops, less for an experienced shop barring any unforseen trouble. |
Posted: Wed Aug 20, 2014 3:15 pm Post subject: |
Trust me, I'm done with this place. Does a 1600 in an early car really give that much trouble? That's what I'm being told. |
Bob Loblaw Samba Member
Joined: August 17, 2008 Posts: 865 Location: Vancouver Island, Canada
Posted: Wed Aug 20, 2014 3:16 pm Post subject: |
rabbitmania wrote: |
No _________________ sent from a phone using poor grammar and spelling |
Posted: Wed Aug 20, 2014 3:18 pm Post subject: |
Thank you. I knew it didn't. This is madness! |
wayne1230cars Samba Member
Posted: Wed Aug 20, 2014 4:14 pm Post subject: |
12.95 hours to change a clutch?? 3 - 4 hours max. I have done that repair myself in my garage at home in that amount of time. The major time is just the removal and reinstall of the engine. Chances are that as an owner of a 50+ year old car, you may need to do another engine pull at some point. You can save yourself a pile of money if you can maintain and repair your bug. I really don't think having a later engine in an early car would be a problem.
Best of luck. Enjoy your bug. They really are fun. _________________ 1960 beetle
1970 beetle convertible |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Wed Aug 20, 2014 4:21 pm Post subject: |
At bottom is some flat rate information I had saved from years back, don't know the source. But flat rate hours shouldn't really vary as time passes.
This lists 1.5 hrs for engine R&R, so at most 1.0 additional hours (my guess) to swap over new pressure plate, disc, and throwout bearing. Note that it lists 1.0 hrs additional for flywheel R&R and oil seal, so that may have been done if they resurfaced or replaced the flywheel. So that makes 3.5 hours labor for that, not 12.95 !!!
OK, here's all what I had written down years ago, don't know the source:
brake shoes front & rear 2.2
brake overhaul (shoes & wheel cylinders) 5.0
handbrake adjust 0.4
master cylinder R&R 1.2 overhaul (early) 1.8
axle boot 0.6
speedometer R&R 0.4
speedo cable R&R 0.4
ignition switch (late) 1.7
engine R&R 1.5
crankshaft oil seal 1.0
pushrod tube seals 3.5
switch over engine components (e.g. to rebuilt engine) 4.0
tune-up major 1.8
starter R&R 0.7
oil cooler re-seal (early) 1.6
generator R&R (early) 1.2
generator R&R (late) 2.0 _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Aug 20, 2014 5:30 pm Post subject: |
Thanks for the info guys. Yeah, I know I should have tried it myself. I've gained a lot of confidence working on my car but since it's the middle of summer, I wanted the job done quickly and properly. If I had of known it would be down for a month, I definitely would have tackled it. |
Potsie Samba Member
Posted: Wed Aug 20, 2014 5:33 pm Post subject: |
Yeah, wtf? Even if it took them that long, they're supposed to charge for what the job is suppose to take-- not how long it actually took them. Sounds like this shop was not familiar with acvws and you paid for their education. I know it took me forever the first time I put my engine back in.
I don't know what you're bill came to, but a clutch kit, new flywheel, seals, and a couple special tools you need comes to about $200. It probably would take you at least 12 hours if you're new to it. But you really can save a lot of money if you learn to work on your own car. I definitely had/have a lot to learn, but I'm sure I've already saved thousands doing my own repairs. _________________ Knows just enough to be dangerous. |
Posted: Wed Aug 20, 2014 5:49 pm Post subject: |
Next time, I'll give it a go.
The funny thing is, they are supposed to be well versed in air-cooleds. Lol |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Wed Aug 20, 2014 5:51 pm Post subject: |
Call me a skeptic- but there has got to be more to the story here.
Is there a chance that they ordered a 40hp clutch 1st in based on the year of your car- then (dumbfoundedly) learned it had a 1600DP in it? Or have they known all along about the specs of your car? Reason I ask is to adjust labor to account for restock on wrong clutch, extra order time, etc. They may have found a way to divorce you as a client- have you had problems with these guys in the past?
In many words, is there more to this story? Because no VW shop could stay open long enough to have repeat customers with the info in this thread. _________________
EverettB wrote: |
FU#5 |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Wed Aug 20, 2014 6:06 pm Post subject: |
Forget the hours... How much was the bill and what repairs and parts exactly.
No sense in getting all exicted about 12.95 hours...if they charge $20 an hour...
It's all relevant..
3 hours at $78 or 13 hours at $18.... ..its the same cost in labor
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Wed Aug 20, 2014 6:21 pm Post subject: |
The total of the bill came to nearly $1300.
They did originally have the wrong pressure plate and put it back together with it. I was told I was only being charged for the first re and re and not the second PP.
I suspect they are trying to make some of that labour back. |
Posted: Wed Aug 20, 2014 6:32 pm Post subject: |
1300 dollars ? For a clutch job and maybe a flywheel seal....
Yeah...you got fully reamed without any lube....
Dont sit down for a while.
Either there is more to this tale then you are telling or the repair shop are full blown jerks...
Its asses like that, that give the rest of us that work in the auto repair industry a bad rap..... ...
You paid for their screw up 10 fold...
Post up some feedback with the shop name and info in the feedback forum so others will steer clear or at least do their homework before paying those gougers.
Posted: Wed Aug 20, 2014 6:48 pm Post subject: |
I haven't paid for anything yet. I can assure you, it's happened exactly as I said it. |
Posted: Wed Aug 20, 2014 6:52 pm Post subject: |
Very likely. Guessing about a thousand for the labour and the rest in parts. Of course 13% HST tax factored into that amount as well. Another reason to start doing your own repairs. _________________ 1960 beetle
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Wed Aug 20, 2014 6:55 pm Post subject: |
Sounds like a driveway, a few friends and (2) 6 packs _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Aug 20, 2014 6:59 pm Post subject: |
Glenn wrote: |
Sounds like a driveway, a few friends and (2) 6 packs |
I like the way you think. Lesson learned but this isn't over yet. |
Glenn Mr. 010
Posted: Wed Aug 20, 2014 7:03 pm Post subject: |
A stock 1600 in a late model car is at most a 2 hour job... i've done it in 1 hour with a floor jack and 2 jack stands.
A 1600 in a early 60s, is a bit harder and you might have to take the #3 heater box off. If the studs and nuts are clean it comes off in a few minutes. If they're rusted its more work.
I'd say 3-4 hours is a fair price to pay a shop if they know VWs. If they don't then you shouldn't pay for them to learn. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Aug 20, 2014 7:20 pm Post subject: |
The heater boxes aren't even on it. All bolts and everything should have been all clean, this car isn't a typical driver. |
