Replacement ?
76VwBug1600
76VwBug1600 is offline
PostPosted: Thu Aug 21, 2014 6:58 pm    Post subject: Replacement ? Reply with quote
Was wondering before i purchase this bus how hard of a repair would this be?
this is the only dent on it.
1976 Fuely Bug
1973 Super beetle with 26k Original miles.
1968 1600cc
1973 1641cc
1966 Rat-rod
1981 VrRabbit
Not Just our cars.. They are our best friends.
monkbonk
monkbonk is offline
PostPosted: Thu Aug 21, 2014 7:12 pm    Post subject: Reply with quote
would require cutting out and welding in a donor section at the very least.
1978 Volkswagen Bus 2.0
1973 Volkswagen Beetle Standard 1600dp
1969 Amante GT Roller
aeromech
aeromech is offline
PostPosted: Thu Aug 21, 2014 7:25 pm    Post subject: Reply with quote
You would need to be getting a smoking deal on the bus for it to be worth it
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
76VwBug1600
PostPosted: Thu Aug 21, 2014 7:26 pm    Post subject: Reply with quote
any places i can get these parts from or i would have to cut a poor other bus up ?
1976 Fuely Bug
1968 1600cc
1973 1641cc
1966 Rat-rod
1981 VrRabbit
aeromech
aeromech is offline
PostPosted: Thu Aug 21, 2014 7:30 pm    Post subject: Reply with quote
There are some guys here who cut up buses. I've bought some metal from them. Reach out and ye shall find.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
aeromech
aeromech is offline
PostPosted: Thu Aug 21, 2014 7:32 pm    Post subject: Reply with quote
Do a search under bay window bus for
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...ht=cutting
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
76VwBug1600
PostPosted: Thu Aug 21, 2014 7:36 pm    Post subject: Reply with quote
guys wanting 2500$ but i have him down to trade around 1000$ says it runs has some carb issue..
1976 Fuely Bug
1968 1600cc
1973 1641cc
1966 Rat-rod
1981 VrRabbit
Tcash
Tcash is offline
PostPosted: Thu Aug 21, 2014 7:40 pm    Post subject: Reply with quote
I am going to say on a scale of 1-10 that is going to be a 9.
The section in black is going to need to be replaced. Behind that panel is a battery tray, engine tray, rear valance and an inner skin by the wheel arch.
Good Luck
1967250s
1967250s is offline
PostPosted: Fri Aug 22, 2014 1:08 am    Post subject: Reply with quote
I bet a good sheet metal guy could get most of that out with some dolly work. "It'll buff out" :)
How does it run?
76VwBug1600
PostPosted: Fri Aug 22, 2014 1:10 am    Post subject: Reply with quote
says has "engine problems"
He wants me to call tomorrow.
Gonna work out some details.
1976 Fuely Bug
1968 1600cc
1973 1641cc
1966 Rat-rod
1981 VrRabbit
Millennium Falcon
Millennium Falcon is offline
PostPosted: Fri Aug 22, 2014 3:44 am    Post subject: Reply with quote
Don't forget about the rear bumper, it is also caved in. Maybe broken bumper mounts or part of the rear frame could be broken as well.
"Don't worry, she'll hold together . . . You hear me, baby? Hold together!" -Han to the Falcon
1972 White Campmobile
1700 cc Type IV
Dual Solex 34 PDSIT2/3
curtis4085
curtis4085 is offline
PostPosted: Fri Aug 22, 2014 4:30 am    Post subject: Reply with quote
I would get it for less then 1k. 800 tops. That rep lament doesn't look all tat bad from here. If you find the right metal guy I would imagine labor cost at about $1500. You can find donor or nos metal rep lament for that whole side. Try Gerson at Klasscfab.com or maybe VWheritage. Couldn't hurt to search busdepot site as well as autocraft. I wouldn't pass that bus up but I would offer $500.
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
Joey
Joey is offline
PostPosted: Fri Aug 22, 2014 4:49 am    Post subject: Reply with quote
I agree.
The Bus Depot has the whole corner...
http://www.busdepot.com/84131
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
barefootwestie
barefootwestie is offline
PostPosted: Fri Aug 22, 2014 6:27 am    Post subject: Reply with quote
Donor bus would be my vote.
My Bus Restoration Blog
https://myvolkswagenbus.com/
1973 Westfalia
"Getting better....one repair at a time."
Other VW's owned through the years, in no particular order:
'67 Beetle,
'67 Ghia Hardtop,
'72 Ghia Convertible,
'72 Westfalia
ned
ned is offline
PostPosted: Fri Aug 22, 2014 7:38 am    Post subject: Reply with quote
Just roll it the way it is. They are not all show busses.
busdaddy
busdaddy is online now
PostPosted: Fri Aug 22, 2014 7:57 am    Post subject: Reply with quote
A skilled panel beater could pull that out and massage it back to smooth, doesn't look like it's gotten into anything structural from here and doesn't appear to be rusty, nothing better than OG metal. But someone who says they can and really can't will make a hell of a mess, choose the repairman carefully. Plan B would be a corner from a donor bus.
Pull, hammer or cut doesn't really matter though because either way that won't be cheap to fix properly, and with a sick motor, bad tires and likely all the other maintenance a neglected bus will need like brakes and rubber seals that bus better be almost free even though it looks solid. It'd be a different story if it was in a part of the country where rust happens but in AZ there's still others to choose from nearby.
Слава Україні!
Wildthings
Wildthings is offline
PostPosted: Fri Aug 22, 2014 10:00 am    Post subject: Reply with quote
I think if you cut out the battery tray on that side and stuck a 4x4 block inside the tail light hole you could chain it to a tree and with some persuasion pull the dent out pretty well. Really though with a questionable power train (you might as well assume both the engine and tranny are shot) along with brakes, suspension repairs, etc that bus isn't worth more than its scrap value.
JDub113
JDub113 is offline
PostPosted: Fri Aug 22, 2014 10:45 am    Post subject: Reply with quote
x2
84 Wolfsburg Edition Westy
Manfreds78bay
Manfreds78bay is offline
PostPosted: Fri Aug 22, 2014 11:21 am    Post subject: Reply with quote
500 bucks as is.
1978 2.0L FI Campmobile
1982 AMC Eagle SX4 4.2L FI
richparker
richparker is offline
PostPosted: Fri Aug 22, 2014 1:08 pm    Post subject: Reply with quote
I agree with above $800-$1000. Unless...you were in the North east then that AZ bus would easily be worth $2500. But your not, talk him way down.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build
