T5Team Samba Member
Joined: May 30, 2012 Posts: 4 Location: Sierra Foothills Calif.
Posted: Thu Aug 21, 2014 10:39 pm Post subject: Which 12v electric fuel pump for Webers |
We are looking for information / recommendations for a twelve volt electric fuel-pump for our T5. It will be feeding Webers (1720 cc 912 motor), and I am told that requires 2.5 PSI. I would rather not use a regulator if possible. The pump will be mounted under the passenger’s floorboard. Any suggestions will be appreciated.
Thanks,
Brian
T5 #114235 |
subhuman Samba Member
Joined: January 22, 2008 Posts: 539 Location: north carolina
Posted: Sun Aug 24, 2014 6:35 am Post subject: Re: which 12v electric fuel pump for Webers |
T5Team wrote: |
Thanks,
Brian
T5 #114235 |
cb performance has a nice 12v fuel pump that is perfect for webers! doesnt need a pressure regulator, ive had mine for 7 years now, not a single issue, it needs to mount as close to the fuel tank as possible, it is designed to push not pull fuel. good luck. _________________ 63 restomod build
http://s431.photobucket.com/albums/qq37/johnnysubhuman/?albumview=slideshow
you can have everything you want, just don't want so much!
"the wrong way always seems the more reasonable."
george moore
1963 type1
2002 Subaru Wrx
never argue with an idiot, they will only drag you down to their level and beat you with experience!
Mark Twain |
T5Team Samba Member
Posted: Fri Aug 29, 2014 10:25 pm Post subject: |
Thanks for the info.
Brian |
tom coughlin Samba Member
Joined: February 16, 2008 Posts: 67 Location: near Boston
Posted: Sat Aug 30, 2014 4:43 am Post subject: elec fuel pump |
I just bought one and found that Zims had the right one, works fine. tom |
T5Team Samba Member
Posted: Sat Aug 30, 2014 10:43 am Post subject: |
Thanks, I just bought the Carter 60504, I'll post the findings. |
