elwood5150 Samba Member
Joined: February 21, 2012 Posts: 29 Location: Monument CO
Posted: Fri Aug 22, 2014 12:50 pm Post subject: engine compartment cleanup |
So the engine and trans are out. I want to clean it up and coat it with undercoating or some type of Rhino lining. Any suggestions on what to do?
I hear undercoating gets hot and soft and tends to collect dust. |
JBall8019 Samba Member
Joined: April 09, 2012 Posts: 115 Location: Trumbull County, OH
Posted: Fri Aug 22, 2014 1:12 pm Post subject: |
Elwood, try using oven cleaner before using flammable solvents to remove the undercoating. I also use a heat gun and a scraper as well _________________ John |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Posted: Fri Aug 22, 2014 2:26 pm Post subject: |
Think ya missed the point, Jball.....
Give it a good power wash bath after a soak in simple green/equivalent....
I would Not recommend undercoating, for the points you've mentioned above...
Also, bedliner will Not be a smooth finish, and dirt/oil/ junk will collect in the roughness of the finish and be even harder to clean later on..(..personal experience from my Tucson street rod bug... .)
If ya want something durable, AnD easy to clean, I
D go with POR-15... Crazy durable, super smooth finish, and junk should wipe right off..... _________________ '74 Thing, "Our Thing"....
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember |
Semper_Dad Samba Member
Posted: Fri Aug 22, 2014 3:57 pm Post subject: |
Ditto on the texture. Will make cleaning that much harder. May also hold in heat. FWIW,...MY PO "color matched" the engine compartment to black (current body color). Makes everything seem to disappear (like dropped screws and parts) and generally makes maintenance like working in a black hole. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Ratt Samba Member
Joined: April 15, 2003 Posts: 753 Location: Puyallup, Wa
Posted: Fri Aug 22, 2014 4:20 pm Post subject: |
Ohh a white engine bay, it would be just like the Reactor Compartment on a Nuclear Submarine. Nothing can hide on white!
Once I start on Thing, I am going to use a lighter color I the Engine bay. Something smooth so the dirt and oil wipes right up. I too thought about the rhino liner idea, but after seeing the PITA my buddies jeep was, I changed my mind. |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Sun Aug 24, 2014 7:37 pm Post subject: |
whats wrong with the factory color ? Here is a couple that we ( the Domeck Brothers) has done and this is how we do all of the ones we restore.
MRJEL Samba Member
Joined: June 04, 2012 Posts: 478 Location: Jawja, USA
Posted: Mon Aug 25, 2014 7:01 am Post subject: |
citroen wrote: |
And that's the way they oughta be done! |
Posted: Mon Aug 25, 2014 9:22 am Post subject: |
I like the paint idea. The POR-15 looks good also. I don't have rust in the engine compartment. The car was undercoated at one time but is peeling off. I am going to remove it in the transaxle area. I saw some videos using POR-15 and they painted over it once it was applied. I need something really strong to protect the bottom out here in Colorado. I run this car all year long and they put down some real nasty crap to stop the icing in the winter. Since undercoating seems to peel over time any ideas? |
kubelmann Samba Member
Posted: Tue Aug 26, 2014 4:41 am Post subject: |
Over 15 years ago our 63 Bug Prerunner’s pan was wire brushed to remove anything loose such as paint , dirt, rust and so on. Then we used a roller and pan to coat both sided with Roll On Herculiner.. It has held up nicely for thousands of miles off road in Mexico and also here in Colorado. Herr Kublemann’s pans got the same treatment but POR-15 was used rather than Herculiner. Now 15 years later both cars are still fully coated and protected from the environment. Also both cars can easily have their seats removed and get a deep cleaning fast and easy with a pressure hose and the drain plugs removed... Here is a video that shows the three step process to apply roll on Herculiner....
http://www.herculiner.com/projects/application.php |
