sb001 Samba Member
Posted: Sat Sep 20, 2014 8:04 am Post subject: |
OK- some observations (many thanks to Mr. Duncan who is helping me out with the top end stuff--heads, valves, and other things):
What the crap, my intakes had TWO manifold gaskets installed (can't wait for johnnypan's comment on this one)
Cleaned up oil pump
Before & After:
Distributor mechanical advance was pretty filthy:
Removed, Cleaned and re-greased my points breaker plate
Before & After
Distributor cleaning:
OLD:
NEW
New dust cap (I didn't have one installed)
My distributor cap was also cracked, getting a new one.
Finally, all 4 of my intake valves were cracked:
More to come... _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Sat Sep 20, 2014 9:05 am Post subject: |
Since you just had the intake off the last time it seems some "attention to detail" is in order.. are autostick engine oil pumps available?.. because yours is done.. clean those valves with scotchbrite and post up those valve cracks again.. |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Sat Sep 20, 2014 9:19 am Post subject: |
johnnypan wrote: |
I'm soaking the valves right now.
I'm replacing all 8 valves & guides regardless. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
Posted: Sat Sep 20, 2014 10:04 am Post subject: |
Mr.Duncan wrote: |
johnnypan wrote: |
I'm replacing all 8 valves & guides regardless. |
are you replacing the seats and 3 angle grinding the valves? |
mouser98 Samba Member
Joined: April 12, 2012 Posts: 300 Location: Lugoff, SC
Posted: Sat Sep 20, 2014 10:51 am Post subject: |
johnnypan wrote: |
what do you see on the oil pump you do not like? |
Posted: Sat Sep 20, 2014 11:28 am Post subject: |
johnnypan wrote: |
Mr.Duncan wrote: |
johnnypan wrote: |
Well John, personally no, I'm dropping them off at the machine shop that we use.
Also, yes they are being replaced.
Also- it's the seat that gets 3 angles cut, and the valves get lapped. It's not a performance motor, if we wanted performance, we would cut the angles on the valves too. _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sat Sep 20, 2014 12:54 pm Post subject: |
I'm confused... is Mr.Duncan helping out sb001 on his rebuild or is Mr.Duncan rebuilding his engine too... _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Sat Sep 20, 2014 1:33 pm Post subject: |
Joey wrote: |
I'm confused... is Mr.Duncan helping out sb001 on his rebuild or is Mr.Duncan rebuilding his engine too... |
I'm helping. Those are photos of his parts. Hope that clears it up. _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
Joey Samba Member
Posted: Sat Sep 20, 2014 3:43 pm Post subject: |
Mr.Duncan wrote: |
Joey wrote: |
I'm helping. Those are photos of his parts. Hope that clears it up. |
Yea... And rereading the 1st line on the top of this page... _________________ Joey
Posted: Sat Sep 20, 2014 8:21 pm Post subject: |
mouser98 wrote: |
johnnypan wrote: |
gear wear on the back of the housing,cuts efficiency
seats and valves are cut to match...its how you make a seal with a broad face..first time ramrodding a head job?.....good thing is you aint fucking me.. |
sb001 Samba Member
Posted: Sat Sep 20, 2014 9:36 pm Post subject: |
Question about the oil pump-
the part I sent Mr. Duncan (the part previously pictured a few posts up) was JUST the oil pump section of the pump as far as I can tell-
there was another "section" of the pump I did NOT send him, that actually has the autostick ATF pipes attached to it:
I assume THIS is the ATF chamber, so is the part I sent Mr. Duncan JUST the oil pump section? If so, and if it's worn, would it be any different from a stock oil pump?
(Of course there's always the chance this other ATF pump section I didn't send him is worn as well, in that case obviously the whole thing needs replacing) _________________ I'm the humblest guy on this board.
1600 SP engine
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Sun Sep 21, 2014 2:35 pm Post subject: |
Autostick vs non oil pumps are NOT interchangeable. |
modok Samba Member
Posted: Sun Sep 21, 2014 3:00 pm Post subject: |
Intake valves are not cracked, they were made like that. That is not what a crack looks like.
Can probably use the autostick pump body with different gears and cover. Aren't they the small 21mm gear tho?? is that what you want? |
Posted: Mon Sep 22, 2014 4:53 pm Post subject: |
modok wrote: |
Yes 21mm _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
Posted: Mon Sep 22, 2014 4:54 pm Post subject: |
johnnypan wrote: |
mouser98 wrote: |
johnnypan wrote: |
I trust my machine shop guy, he has been doing it for 40 years and I've never had issues, I follow his advice. He also has been doing this work professionally for 40 years.
Thanks. _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
sb001 Samba Member
Posted: Mon Sep 22, 2014 6:02 pm Post subject: |
Bashr52 wrote: |
Not the WHOLE thing, no.
I am talking about just the internal chamber part of the autostick pump which pumps the oil, with a gear driven off the cam gear, just like a conventional type 1 oil pump-- this part:
unless they are different sizes which I don't know about.
The outer chamber of my pump pumps the ATF fluid, with yet another gear driven in turn off the oil pump gear, at least from what I can tell.
Here is a picture of the outer chamber/cover part of the pump I did NOT send Mr. Duncan, with the ATF pipes still attached:
This section would not be on the conventional oil pump, but it looked like the rest of the pump was very similar to a conventional oil pump. Again unless they are different sizes- I could be wrong. Don't know enough about it. _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Mon Sep 22, 2014 6:07 pm Post subject: |
Well, there are two locating bosses on the ATF side.
Anything is possible... I'll look into it! _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
sb001 Samba Member
Posted: Mon Sep 22, 2014 6:09 pm Post subject: |
Mr.Duncan wrote: |
Anything is possible... I'll look into it! |
Thanks man!
I'll trust your machine guy, 40 years + with no issues, can't ask for more...
How have most of you other folks that have rebuilt engines and are following this thread done the valves? Just curious _________________ I'm the humblest guy on this board.
1600 SP engine
sb001 Samba Member
Posted: Tue Sep 23, 2014 8:29 am Post subject: |
sb001 wrote: |
How have most of you other folks that have rebuilt engines and are following this thread done the valves? Just curious |
Anyone?? _________________ I'm the humblest guy on this board.
1600 SP engine
