Malokin Martin Samba Member
Posted: Tue Oct 14, 2014 1:18 pm Post subject: |
Monster bus with the history to boot. |
dmuis Samba Member
Joined: September 01, 2004 Posts: 381 Location: Sunny Alberta, Wild Rose Country.
Posted: Tue Oct 14, 2014 1:32 pm Post subject: |
Lind wrote: |
GTV wrote: |
I forgot about those Nexen's, those look great if you're after a stock diameter radial that isn't too wide. |
those Nexens of which people like are no longer available. |
Appears to still be stock at tires-easy.com, which is where most people have been getting them...
195R15C tires options from Tires-Easy.com |
GTV Samba Member
Posted: Tue Oct 14, 2014 1:41 pm Post subject: |
If possible hone and rebuild the master and wheel cylinders! _________________ EMPI Power Rules! |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Tue Nov 04, 2014 9:46 pm Post subject: |
I removed the front floor today, it was rusty and beyond repair. I used a large pair of channel locks to rip the entire floor out and it took me about 3 hours. I need to use the sander some more to make the welds go away still, but it was pretty easy. I didn't even take off the pedals or the steering or anything except the high beam switch. The only spot left is where the shifter sits and I need to grind the heads of the bolts off I guess, they are stuck but good.
_________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
GTV Samba Member
Posted: Tue Nov 04, 2014 11:04 pm Post subject: |
Any word from Bill on the trans? I'm coming up this week... _________________ EMPI Power Rules! |
Posted: Tue Nov 04, 2014 11:19 pm Post subject: |
He called and has the trans all torn down, it needs all new bearings and ring and pinion. I gave him the go ahead on it so I expect him to have it done pretty soon. I need some drums for it now, is there any differences between them for the big nuts?. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
Posted: Tue Nov 25, 2014 9:36 pm Post subject: |
The trans is done! I am going to get it and start my build. I want to get this bus on the road by BBB! _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
GTV Samba Member
Posted: Tue Nov 25, 2014 10:58 pm Post subject: |
I'll be up next week if you want me to grab it... _________________ EMPI Power Rules! |
Posted: Fri Dec 05, 2014 7:26 pm Post subject: |
Ta da.
Schwing Samba Member
Joined: May 10, 2009 Posts: 2506 Location: Centreville, MD
Posted: Fri Jan 02, 2015 9:40 am Post subject: |
Well I was thinking today about my found bus and wonder in my head how much my bus is worth or will be worth when I get it driving. I am thinking I should have extra insurance and thought maybe 10 grand would be the value? I see many buses for sale and I can't find anything to compare really. What do you folks think? _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1784 Location: District of Columbia & Cape Cod
Posted: Fri Jan 02, 2015 10:01 pm Post subject: |
dmuis wrote: |
Everett has a set of the Nexen SV820's for his 1961 DC.
BulliBill has a set of the Nexen SV820's for his 1959 DC.
Did you decide on tires yet? I run the Nexen SV820's on my 59 swivel. They're awesome. I'm running a 67 FF, 34-3 with bigger jet, and it chugs along nicely.
_________________ 77 Westy - Cape Cod Sage
LLAP |
Posted: Sat Jan 03, 2015 9:06 am Post subject: |
Thanks folks, I have not purchased the tires yet, the Nexans sound really good though and I see they are not Chinese so I will get them most likely, or perhaps the Continentals. I did order a KF154 front floor from Gerson now and I am waiting on a few other items to arrive. I will be careful to put the bus together as original as I can so that it will keep that value intact. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
Posted: Tue Feb 17, 2015 6:59 am Post subject: |
This bus is about to be reborn! _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4536 Location: Arizona Highways
Posted: Tue Feb 17, 2015 9:57 am Post subject: |
Red Fau Veh wrote: |
This bus is about to be reborn! |
yep.
it'll be a shorty by the end of the day
_________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
mtnbus Samba Member
Posted: Tue Feb 17, 2015 3:25 pm Post subject: swiv |
Looks great buddy !!! |
Posted: Wed Feb 18, 2015 8:14 pm Post subject: |
She is in the shop with the other sick buses, should be a roller for the first time in decades shortly.
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Wed Feb 18, 2015 8:40 pm Post subject: |
I still hate you. |
Posted: Wed Feb 25, 2015 8:57 pm Post subject: |
The trans is in and I have sand blasted drums and backing plates and today I washed the front beam. The roof is getting straightened out better and today the parking brake handle was removed and the clutch and brake levers also, everything is getting blasted and painted.
