cakelley Samba Member
Joined: September 23, 2013 Posts: 58 Location: richmon va.
Posted: Mon Aug 25, 2014 3:38 pm Post subject: Gotta be something I'm missing. |
1641dp 34 pic carb. I was running a 009 dizzy and it idled perfect but had the flat spot. So I ordered a vacuume advance from mid America installed it today and the car started every time but refused to idle. Since my dizzy is 180 degrees out the vacume was almost hitting my fuel pump. So I took it out and put the 009 back in timed it and the car starts great but won't idle no matter what I try. Please help |
darg Samba Member
Posted: Mon Aug 25, 2014 4:49 pm Post subject: idle |
Might try to adjust the fast idle screw on the carb.Will it idle when you apply a steady push on the gas . |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Mon Aug 25, 2014 5:25 pm Post subject: Re: Gotta be something I'm missing. |
Darg, you don't touch the fast idle screw on a 34pict carb, its all done with the mixture screw and the air bypass screw.
cakelley wrote: |
Since my dizzy is 180 degrees out the vacume was almost hitting my fuel pump. |
You can install the distributor in any orientation you like you just have realign the plug leads to suit, you don't have to line the #1 up with the notch.
one of mine the dist drive was a tooth or 2 too far anticlockwise and the condenser hit the fuel pump so I installed it 90 degrees clockwise to stock.
With the stalling make sure there is no crap caught in the idle jet. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Mon Aug 25, 2014 5:53 pm Post subject: |
good to know on the dizzy install, so it rotor doesn't have to line up with notch. just make sure the plug wires are right. very nice. solenoid is on positive side of coil. i will check my jets in the am. carb is brand new so I didnt think they would be a issue. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Aug 25, 2014 6:17 pm Post subject: |
Read about clutches- "brand new" isn't what it used to be- but back to your problem- If you are trying to run vacuum advance and your choke throttle screw is being used for idle- there is a chance the vac curve is kicking in- this usually results in climbing idle speed but might be a good place to point your timing light when you fire up- that might give you a quick check of your ignition. The two are very similar malfunctions.
Might try the high vacuum created when you slap your hand over the carb when revved to 2000. sometimes clears the crap especially if you back out the adjuster screws first to give the crap a release.
Another way to see whats going down the carb is to use your timing light as a flashlight looking down the throat of the carb- it shows the fuel flow in "stop motion" Get to know what a correct spray pattern looks like so you will recognise a bad one. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Posted: Mon Aug 25, 2014 6:24 pm Post subject: |
Unscrew your idle jet on the right side of the carb and clean it out. |
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Tue Aug 26, 2014 12:23 am Post subject: |
williamM wrote: |
Another way to see whats going down the carb is to use your timing light as a flashlight looking down the throat of the carb- it shows the fuel flow in "stop motion" Get to know what a correct spray pattern looks like so you will recognise a bad one. |
I like that answer
it's up in the venturi vac range
maybe just futz ing around has introduced (or even unconsequential) carb idle circuit issue.
how the fuel filter
maybe its the same crappy fuel as before the new carb,
or some other issue not addressed
is the dwell still correct |
brendo907 Samba Member
Joined: September 13, 2013 Posts: 339 Location: North Pole, Alaska
Posted: Tue Aug 26, 2014 3:44 am Post subject: |
did you accidently unplug the wire for the idle solinoid doo-hicky on the side of the carb? |
Cusser Samba Member
Posted: Tue Aug 26, 2014 7:09 am Post subject: |
brendo907 wrote: |
I think that was addressed earlier, but not as eloquently as you stated.
Cusser wrote: |
Is the electrojet on the carb operating correctly, and connected to the positive side of the coil? |
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Aug 26, 2014 10:38 am Post subject: |
Oh man, proper terms wins again |
Posted: Wed Aug 27, 2014 11:34 am Post subject: |
brendo907 wrote: |
and was calling it an "ignition controlled electromagnetic idle shut off solenoid" all . these years. OR "iceidsos"
Or "ice i do sos." _________________ some days I get up and just sit and think. Some days I just sit.
