bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Mon Aug 25, 2014 9:58 pm Post subject: Rocker Side Play Adjustment Shims |
I was setting up rocker side play the other day using an EMPI shaft kit. I wish I would have had more shim thicknesses, so I looked into a hardware catalogue and found some shims that have the same dimensions. Are .005s too thin to use safely on rocker assemblies, or shoud I go no smaller than .010? I can get a pack of 25 of whatever size for eight dollars.
Are there better shim selections from another company? EMPIs came with .017, .032, and .059. Those measurements were taken after I sanded down the stamped edges. |
Danwvw Samba Member
Posted: Mon Aug 25, 2014 11:20 pm Post subject: |
Aircoolednet and cb-performance carry them but I think most kit's just have 3 sizes in them. .005" would be nice so they could be dialed in better. I think they would work. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
56vwoval Samba Member
Joined: March 21, 2010 Posts: 186 Location: nowhere USA
Posted: Tue Aug 26, 2014 6:16 am Post subject: shims |
What catalog were you looking at? _________________ Remember guys and girls, you can be right or you can be happy with your significant other! You decide which is right at that time! |
Danwvw Samba Member
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Tue Aug 26, 2014 1:22 pm Post subject: |
Mcmaster Carr has 18mm shims down to .1mm thick which is about .003"...
http://www.mcmaster.com/#standard-shims/=tg9lra
click on the metric shims and then go to 18mm size.
If I was going use them to shim a set of rockers I would make sure to put the thins one between the thicker ones, and use the "Spring Steel" shims.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Tue Aug 26, 2014 4:41 pm Post subject: |
A thin shim should work fine sandwiched between the others shims. Would nut use one all alone tho. |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Wed Aug 27, 2014 4:34 am Post subject: |
think how thin the endplay shims are... i wouldn't be worried if it had good oil supply? _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
JasonBaker Samba Member
Joined: February 08, 2010 Posts: 1642 Location: Cleveland, TN
Posted: Wed Aug 27, 2014 6:30 am Post subject: |
I think oil pressure is a given. Having the proper shims just makes for a quieter drive train. |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Wed Aug 27, 2014 6:39 am Post subject: |
modok wrote: |
I agree with Modok. Those .005 shims are pretty flimsy. If for some reason it started to seize and cause a wrinkle it would be all over. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
damicotile Samba Member
Joined: September 16, 2004 Posts: 1069 Location: WOODLAND CA.
Posted: Wed Aug 27, 2014 7:36 am Post subject: |
I have SCAT rockers and when I opened the package the sides of the rockers were not machined smooth and tore up the thin shims.
I ended up machining the sides, used thicker shims and it has not beed a problem since.
I used valve spring shims.
Some of the side play was at .060".
Using those .010" shims will be destroyed if not sandwiched between 2 thicker shims.
Just make sure the sides of the rockers are smooth.
You can smooth them by sanding them on a flat surface with emery cloth and oil in a circular motion. _________________ '73 SB
82x94
W-120 w/ CB light weight lifters
Silicon bronze sleeves
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
A-1 Sidewinder coated
__________________________________ |
Deleted duplicate post. _________________ '73 SB
82x94
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Wed Aug 27, 2014 9:46 am Post subject: |
I used some of the stock shims which were .040+/-.
That combined with the packaged shims which were .032,.020 and .010 got me a little closer to what I wanted.
I measures all the shims, spacers and rockers to make the best fit possible.
So far my valve train is quieter than with the stock parts. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
mark tucker Samba Member
Posted: Thu Aug 28, 2014 12:00 pm Post subject: |
I always reserface the rockers&blocks and add a slight chamfer to the split on the blocks so it dosent dig into the shims.I like thick shims,but ...on occassion used thin shims between the thicker ones. I try for around .008" +-.002"side clearance. but remember the pushrods are at an angle pushing toward the rear of the car so the rear side of the rocker is the side that takes the thrust load.I try to use atleast 2 shims on the rear/thrust side of the rockers perferalby thick hard shims. and this final ajustment shims on the non thrust side. one more item...valve spring shims are not rocker shims,there made to stop roatation!!!! they are non slip shims!!!(the ones that have serations or stampings on the faces) a hardened shim is spring steel, and when bent will spring back,not stay bent.. I also remachine the rocker blocks/shaft end caps so I can use the shim pack I need for the thrust side. |
Posted: Mon Sep 01, 2014 7:45 am Post subject: |
mark tucker wrote: |
one more item...valve spring shims are not rocker shims,there made to stop roatation!!!! they are non slip shims!!!(the ones that have serations or stampings on the faces) a hardened shim is spring steel, and when bent will spring back,not stay bent. |
Who in their right mind would put the serrated side to the side of the other shims?
The VSI's (valve spring insert) are used on the non load side of the rockers thus allowing them to take up the clearance without causing any problems with non-rotation.
I always put the shims on my lathe to polish them using a mandrel I made to anchor them.
I find it comical how one can charge the money for a set of rockers that Scat does and expect the average Joe to install them and expect them to function properly when the sides of the rockers are so rough from casting textures.
I made a mandrel to hold the rockers too so I can polish them up on the lathe. _________________ '73 SB
82x94
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
Posted: Mon Sep 01, 2014 8:07 am Post subject: |
damicotile wrote: |
I made a mandrel to hold the rockers too so I can polish them up on the lathe. |
indeed who in thier right mind would market them as rocker shims.they belong under the spring.not on the rocker shaft. |
Posted: Mon Sep 01, 2014 8:31 am Post subject: |
They aren't marketed as rocker shims but do work as rockers shims if treated right. This is why there are so many mods one has to put into place to make this aftermarket crap to work.
I rarely have a part that doesn't need to be modified to some degree to make it work or last.
To this day I have had no problems with the shims binding or being destroyed.
You just have to use them on the side with the least load.
They are checked each time the valves are adjusted by me removing them and checking for wear.
So far they work fine. _________________ '73 SB
82x94
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
jason Samba Member
Posted: Mon Sep 01, 2014 10:33 am Post subject: |
I bought some rocker shaft shims from bugpack if I remember correctly and they are indeed valve spring shims. So they are marketing them as such. Needless to say they went back. |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Mon Sep 01, 2014 12:12 pm Post subject: |
I have a HF diamond grit block with 4 different grits. When I used the very used 1.25:1 VW rockers I hand ground them flat on the sides - one side had a 1/16" protrusion that was the original unworn surface running against the stands....
I also handground regular steel washers to get the correct sideplay.... _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Posted: Tue Sep 02, 2014 7:58 am Post subject: |
just remember there not hard like a good rocker thrust shim is. although you can heetreet them a bit, be sure to go over them with 6000-8000 wet before usage.I have not used any of them.but Ive seen plenty and laughed at the bp package with them in it then threw it in the trash. scat and empi have good shims(or did last time I ordered them). a .015 HP vsi shim is just fine to use there flay with no serations. i dont recall the numbers for the 3 diferent od&id sizes. |
scotth17 Samba Member
Joined: January 30, 2012 Posts: 335 Location: Bedford Texas
Posted: Mon Sep 15, 2014 7:36 pm Post subject: |
I ordered some of these spring steel shims in .1 and .2 mm from McMaster Carr. They seem to be a good material (as in springy), the surface finish is very good and they are FLAT, no apparent punch operation. I shimmed my rockers to a loose zero with the thinner shims between the old thick shims I had in there. I must say it is so much quieter now and my old adjustment was no more than .005-.006 clearance. The Scat 1.25 rockers have a few thousandths clearance on the shaft and any extra side clearance really lets them move about. I have the Hoover mods and the Scat swivel feet rocker adjusters so I think oil flow will be fine. I think they will be just fine.... |
