Kubelwagen Chris Samba Member
Joined: May 05, 2014 Posts: 20 Location: United States
Posted: Tue Aug 26, 2014 8:21 am Post subject: Type 82 (Kubelwagen) questions |
Hey guys, I have tons of questions regarding the Type 82 Kubelwagen. Where is the best place to post them seeing as this is a early beetle forum?
Chris |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Tue Aug 26, 2014 8:49 am Post subject: |
EverettB wrote: |
This section and this thread is the place.
Go ahead... |
Firstly, regarding a replacement engine: I know the original kubel had a 985cc engine. Later models ('45) were upgraded to the 1100cc. I can't find a replacement of the original size at all. I have a 1500cc (rebuilt to 1600) can I drop in this engine in my original kubel? Will it physically fit?
Chris |
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 24120 Location: Southeast USA
Posted: Tue Aug 26, 2014 9:18 am Post subject: |
It will physically fit, but just about everyone here will recoil in horror, and urge you to at least fit a 36hp engine, which is easy to find. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
splitjunkie Samba Member
Posted: Tue Aug 26, 2014 9:26 am Post subject: |
12 volt flywheel would be too big. You would either have to grind out the bell housing, have the flywheel turned down to install a 6 volt ring gear or I think there were some 6 volt flywheels that would work. I would recommend finding a good 36hp engine. It won't be correct but will bolt right in and will look a lot more like the original engine. _________________ Chris
Posted: Tue Aug 26, 2014 9:46 am Post subject: |
splitjunkie wrote: |
I would recommend finding a good 36hp engine. It won't be correct but will bolt right in and will look a lot more like the original engine. |
Well then, a 36hp it is. Can you guys turn me on to any resources where these engines can be found? Honestly, I wasn't confident enough to undertake a rebuild. Are we talking swap meets or are there reputable dealers that offer these rebuilt; turn key perhaps? |
Kapt. Q Samba Member
Posted: Tue Aug 26, 2014 11:21 am Post subject: |
Here is a great place for help, it would also be worth registering at:
http://www.vw166.com/forum/index.php
This is a site dedicated to wartime VW's so you will find much good info there after registering (this can take a little while).
The 36hp is a common choice as it can be 'dressed up' to look almost the same as an original and parts are easy to get/find.
Cheers! |
Posted: Tue Aug 26, 2014 11:27 am Post subject: |
Kapt. Q wrote: |
Cheers! |
Excellent! Thanks! |
Posted: Tue Aug 26, 2014 11:55 am Post subject: |
Kubelwagen Chris wrote: |
Can you guys turn me on to any resources where these engines can be found?? |
Try searching The Samba classifieds.
http://www.thesamba.com/vw/classifieds/search.php?...ton=Search _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Tue Aug 26, 2014 3:48 pm Post subject: |
Blue Baron wrote: |
It will physically fit, but just about everyone here will recoil in horror, and urge you to at least fit a 36hp engine, which is easy to find. |
LOL. And so true.........! _________________ John Henry
'57 Deluxe
'56 Single Cab |
Mike Sal Samba Member
Joined: May 28, 2014 Posts: 195 Location: Southern Illinois
Posted: Tue Aug 26, 2014 7:51 pm Post subject: Kubelwagen tops |
While talking about kubelwagens, can anyone point me to good opinions as to what color of canvas I should use to make a new top for my kooble kar reproduction? Seems I've seen several different colors while searching the web, but haven't figured out which would be most appropriate for an early '43 look.
thanks,
mike Sal |
Posted: Tue Aug 26, 2014 11:06 pm Post subject: |
Early 1943 would be grey, they are reproduced in Czech.
Cheers! |
Porsche904 Samba Member
Posted: Wed Aug 27, 2014 3:04 am Post subject: |
Posted: Wed Aug 27, 2014 6:26 am Post subject: Kubel Top Canvas |
Thanks for the info. The kooble kar has slight differences which will not allow a standard Kubelwagen top to fit properly, so I am making my own, using the old top as a pattern. I have a commercial sewing machine and have been doing my own automotive upholstery for several years.
I have seen all different colors of tops (green, olive, olive drab, khakie) on different years of real kubels, but was not finding a consistant pattern. My kar is dunklegelb (I think that's the right way to say it), not grey in color.
thanks,
Mike Sal |
Posted: Wed Aug 27, 2014 9:57 am Post subject: |
On Feb 18th 1943 the Wermacht officially ordered that the basic colour for all vehicles be changed from dunkelgrau to dunkelgelb, however it took a while for industry to gear up for this and existing stocks of parts and paint to be exhausted, so any colour top would probably be considered correct up to late 1943 and perhaps even later. Many parts like torsion bar covers and steering columns can often be seen in grey on yellow vehicles on period pictures.
There is plenty of photographic evidence for grey wheels well into 1944 and perhaps even 1945
Notice the above schwimmwagen also has a dark roof too that is definitely not yellow and the picture is dated sept 1943, the car is obviously still quite new (matching tyres with good tread, no cammo or dents/obvious damage ). Interestingly the brake drums are also still grey and these were painted at the same time as it's drivetrain and suspension so those will also still be grey.
Tops or at least the fabric were probably made by more than one firm for VW so it is likely that there were variations in colour even when new, and perhaps shortages of chemicals/dyes might even have led to more, not to mention the effects of weathering.
There is some evidence for olive drab type colour tops (Had the war continued the Wermacht were actually going to change the basic colour to this, as it made more sense as the main theater of operation was no longer the plains of Russia but Germany itself which was naturally greener).
Here you can see the wide variation:
Personally I wouldn't worry too much as there is no 'absolutely correct'
Cheers! |
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5475 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
Posted: Sun Aug 31, 2014 10:18 pm Post subject: |
Kapt. Q wrote: |
Cheers! |
These two sites might help too:
ww2vw.com
http://vw82.free.fr/ _________________ '67 KG Cabrio (Mickey) ;
'66 Type 3 (Sharky 2)
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; '44 Kubelwagen (replica) TOOB MEMBER #20 |
Posted: Mon Sep 01, 2014 8:57 pm Post subject: kubelwagen web sites |
I tried to sign up to the 166vw site over a week ago & my membership is still pending.....who knows.....
Mike S |
Posted: Fri Sep 05, 2014 8:47 am Post subject: Re: Kubelwagen tops |
Mike Sal wrote: |
thanks,
mike Sal |
I will post a photo of mine. I believe it is supposed to be original. |
Posted: Fri Sep 05, 2014 8:48 am Post subject: Re: kubelwagen web sites |
Mike Sal wrote: |
Mike S |
After registration you are asked to send an E-mail to the administrator here:
http://www.vw166.com/schwimmwagen/e_mail.htm |
s.e.charles Samba Member
Posted: Fri Dec 08, 2017 7:34 pm Post subject: Re: Type 82 (Kubelwagen) questions |
so I don't start a new topic ....
what was the space in front of the cockpit (under the spare tire) used?
was the floor of the cockpit its only access?
could a 5 gallon gas can be fit there on its side - and more importantly, retrieved?
thanks |
