Manfred58sc Samba Member
Posted: Fri Jan 30, 2015 1:19 am Post subject: |
That is correct, you need all the sections. Don't worry, it is part of the learning curve. It was so rusty it would have been very hard to see all the sections. I should have mentioned that beforehand. Once you have all the sections you will be able to see the inter-relationship and weld away. Thanks for the update..love this Bus. I'm really looking forward to doing the mechanical. I'm looking into a type 3 front beam..saw a guy on KCW that did it and it worked well. Any one gone down that road here? _________________ Fat chick owner/operator |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14218 Location: Casa de Oro, California
Posted: Fri Jan 30, 2015 9:41 am Post subject: |
Some factory assembly rockers didn't have the stiffener so technically you could go without it. Don't know the rhyme or reason for not having it vs having it. I like knowing that my threshold can have more weight on it like a ramp or something loaded onto it. |
greasedjesus Samba Member
Joined: August 23, 2014 Posts: 49 Location: Elizabeth, CO
Posted: Fri Jan 30, 2015 11:10 am Post subject: |
I would assume that being a double door you really need the stiffeners on this. I would also assume that's why this one has the 3 piece belly pans as well, for strength. _________________ When life hands you lemons, shut up and eat your damned lemons. |
esde Samba Member
Joined: October 20, 2007 Posts: 5927 Location: central rust belt
Posted: Fri Jan 30, 2015 12:35 pm Post subject: |
There's nothing fancy about the stiffener, if you have access to a sheet metal brake you could make it pretty easily, if you were really chomping at the bit to get welding. It does make the sill area much more rigid. |
Posted: Fri Jan 30, 2015 1:19 pm Post subject: |
Correct on both accounts..the DD needed more reinforcement and it would be an easy section to fab..Doug check your pm's _________________ Fat chick owner/operator |
Posted: Fri Jan 30, 2015 10:18 pm Post subject: |
Got a little more done today. Decided to work on the dogleg on the passenger side since I'm in a bit of a holding pattern for inner rockers.
here's the before pic of the passenger dogleg
found some rust on the inner part of the pillar between the halves of the dogleg where I won't be able to get to it after they new panels are put in
So I took to grinding all teh rust off then welding up all the pinholes, then grinding it all back smooth for a good solid surface to attach the inner dogleg to when I'm ready
The splotches you see are where I started to spray some weld thru primer on only to find it was too cold to spray anything and it just sort of sputtered and stopped. Have to wait for a bit warmer day lol.
Then, before I can even THINK of mounting in the inner dogleg, I get to deal with THIS on the A pillar:
Luckily, I already have some patch pieces for this from KF, just hope they are enough. Anyone out there selling a shop full of metal fab equipment cheap? _________________ When life hands you lemons, shut up and eat your damned lemons. |
Posted: Sat Jan 31, 2015 1:59 am Post subject: |
There about 100,000 shops that have died in the rust belt over the last 20 years thanks to NAFTA. There is lots of that king of stuff floating around on the mid-west auction circuit..we will have to take a road trip! _________________ Fat chick owner/operator |
Posted: Sun Feb 08, 2015 6:31 pm Post subject: |
Cut into the passenger A-pillar today and here's what I found.
could be worse, I GUESS.....
Got the outer all removed and the inner the inner A-pillar was compromised as well.
So out it comes...
then the new funky green test fitted and predrilled. notice how one of the welded points is sort of in the middle of the piece behind it, not right along the edge where I would have thought it was. This gave me a headache till I figured out where the welds were
and 3 and a half freaking hours later, the inner A-pillar repair section welded in.
Now to grind the surfaces and work on lining up the outer repair section and repairing the door hinge mount, tomorrow! I need a strong drink now! This Pillar area is a giant PITA, can't believe how much comes together down here. Hope it all lines up ok when I get that dogleg assembly in! _________________ When life hands you lemons, shut up and eat your damned lemons. |
Posted: Sun Feb 08, 2015 10:55 pm Post subject: |
Bravo!!! _________________ Fat chick owner/operator |
airhead22 Samba Member
Joined: November 23, 2005 Posts: 267 Location: Arizona
Posted: Wed Feb 11, 2015 1:48 pm Post subject: |
Looking good man. 3 hours aint bad at all. Sometimes I just sit and stare for 3 hours and just get a game plan for tomorrow.
Fantastic dedication, keep it up. |
mtnbus Samba Member
Posted: Wed Feb 11, 2015 1:56 pm Post subject: dd |
nice work bud !! |
Posted: Sat May 30, 2015 12:51 am Post subject: |
Bout time I put something new up here after a long cold winter that still doesn't seem to want to end here in Colorado. I am currently nearing fitting the front floor, have the right front inner dogleg in place (mostly) and am now adapting a type 3 beam into the front of this bad boy. Theres a thread over at the KCW website about doing it. http://www.kustomcoachwerks.com/forums/viewtopic.php?f=15&t=8204&start=15#p214021
I'm going to give it a shot, it looks like a pretty decent swap with some minor modifications. The guy that did it doesn't have great pics or instructions, but I've contacted him and he's being super helpful, so I'm going for it. Already have the beam tacked into place and the type 3 trans and spring plate swap done (with much help from Manfred of German Built Restorations) to bring the rear ride height in line with where the front end SHOULD end up sitting after all this. I'll get all my pics of the work I've managed to get done over the last few months soon. Feel free to rattle my cage if I don't! _________________ When life hands you lemons, shut up and eat your damned lemons. |
Posted: Sat May 30, 2015 1:06 am Post subject: |
Here's a little bit of a preview
This is the outer part of the right a-pillar repair panel after it was welded in. It was a little short.
So I took out my trusty mig and just built it up.
This is a pic of the test fitting of the inner dogleg. It is installed now and I'll get the pics of that and the close to finished A pillar repair shortly
novetti Samba Member
Posted: Sat May 30, 2015 5:11 am Post subject: |
Good job with the weld build up! |
mtnbus Samba Member
Posted: Sat May 30, 2015 6:27 am Post subject: dd |
Nice work ! |
Posted: Sat May 30, 2015 7:58 am Post subject: |
Nice work there Doug! Its just too cool see this brave little DD return from its abandoned corner grave at the yard. (I found the 4 lug spacers we need for the rear!). Nice work (and what a nice shop!!), keep it up! _________________ Fat chick owner/operator |
Mapwizard Samba Member
Posted: Sun Jun 07, 2015 2:36 pm Post subject: Winter Went Bye Bye |
A nice day to visit Doug's shop.
Posted: Sun Jun 07, 2015 2:39 pm Post subject: The New Carriage |
Front and rear upgrades.
Posted: Sun Jun 07, 2015 9:15 pm Post subject: |
Womack built off set spring plates were a flawless install for the type 3 trans. The T-3 front beam is coming along nicely. Thanks to Mr. Gas for checking out the trans. 1500 sp in close to completion as well. Thanks for the pics Mike!!! _________________ Fat chick owner/operator |
Mr. Electric Wizard Samba Member
Joined: August 07, 2003 Posts: 2846 Location: Smyrna, TN
Posted: Tue Jun 09, 2015 2:10 pm Post subject: |
Looks like this bus fell into the right hands.
Very cool project. _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper |
